I need 2 trestles to fit the extra blades to the front and sommer do the saddle correction at the same time. Chassis is sitting 500mm of the ground so they must be on the tall side
Anyone that has a set I could borrow for 2-3 weekends?
Trestles needed
Re: Trestles needed
Morning Stef, I've got the perfect set for you... only problem... they're in Cape Town!
- Gunta
- Real Name: Mark
Re: Trestles needed
Stef you can buy a set from Adendorfs, they are cheap. If you are going to do the saddles you might as well do an axle move at the same time.
- Town: Cullinan
- Vehicle: Ford :Toyota
- Real Name: Barry
- Club VHF Licence: HC237
Re: Trestles needed
Hi Stef
As jy my die hoogtes gee wat jy nodig het sal ek van middag gaan kyk hoe lank is myne en as hulle reg is kan jy hulle leen
Wat ek is is net genade
Wat ek het is net geleen
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
Re: Trestles needed
Barry,die chassis se laagste punt is so 500mm van die grond af so ek skat so 600- 800mm hoort te werkbduk wrote:Hi Stef
More or less the plan, will drill the holes; Just don't have the moola right now to lengthen the prop. Was thinking of using spacers on both UJ'sGunta wrote:Stef you can buy a set from Adendorfs, they are cheap. If you are going to do the saddles you might as well do an axle move at the same time.
- Gunta
- Real Name: Mark
Re: Trestles needed
You can still do the move and you can do the prop later. Sagco's charged me R750 to lengthen the prop.
- Town: Cullinan
- Real Name: Barry
Re: Trestles needed
Oeps amper vergeet.
Stef lyk my myne sal so 600 van die grond af lig as dit jou sal help kan ek hulle vir jou leen.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: Trestles needed
bduk wrote:Oeps amper vergeet.
Dit kan werk...sal die naweek plan maak om by jou te kry, dankie
