Starting with my plans and ideas and need some info on where to find the locking latches for the spare wheel carriers.
Any ideas for the bumper would be nice thanks.
![Image](http://i383.photobucket.com/albums/oo277/johannesvdmerwe/Forum%20Fotos/Odd%20Photos/Locks.jpg)
Tomhatvani wrote:I'm thinking something similar, but incorporating the existing tow bar I have as the base of the swing arm. It's one of those bars with the full width of the vehicle. Will it be solid enough?
Dis reg tjom dankieToyX4 wrote:Johannes, herinner my oor so 2 weke dat ek vir jou n foto van my bumper se latches neem. Ook n gawe plan. Ek kan netnie nou nie, want my bakkie is nie naby my nie, maar oor so 2 weke is hy terug.
Thanks Andy, I agree the latches I posted are some what of an overkill!Mud Dog wrote:That looks like a seriously bulky heavy duty clip in the pic. .... Like overkill. What about the normal 'pin type' tail gate clips like Thys posted here ... viewtopic.php?f=41&t=18451" onclick="window.open(this.href);return false; ..... they come in different sizes and the bigger ones are more than sturdy enough to hold a swing-arm ... and they can be locked as well.
They may be bulky and heavy, but are about the only clips that work properly, the others tend to rattle.Mud Dog wrote:That looks like a seriously bulky heavy duty clip in the pic. .... Like overkill. What about the normal 'pin type' tail gate clips like Thys posted here ... viewtopic.php?f=41&t=18451" onclick="window.open(this.href);return false; ..... they come in different sizes and the bigger ones are more than sturdy enough to hold a swing-arm ... and they can be locked as well.
Goeie punt Mark, sien dit is hoekom ek die plek so baie like, al die slim manne kan help metOOOOMS wrote:They may be bulky and heavy, but are about the only clips that work properly, the others tend to rattle.Mud Dog wrote:That looks like a seriously bulky heavy duty clip in the pic. .... Like overkill. What about the normal 'pin type' tail gate clips like Thys posted here ... viewtopic.php?f=41&t=18451" onclick="window.open(this.href);return false; ..... they come in different sizes and the bigger ones are more than sturdy enough to hold a swing-arm ... and they can be locked as well.
Johannes, spend the extra $$ and get the right thing
Mud Dog wrote:Van daai tipe het ek al 'n paar gesien wat baie netjies lyk en selfs 'n alu plaat agter het wat dan 'n tafeltjie word as dit in die horizontale possissie is .... maar die GROOT downfall is dat dit doners swaar is on te lig. Bianca sal erg sukkel daarmee.
Jy stem saam daai wiel op en af die heele tyd is nie lekker nieMud Dog wrote:Van daai tipe het ek al 'n paar gesien wat baie netjies lyk en selfs 'n alu plaat agter het wat dan 'n tafeltjie word as dit in die horizontale possissie is .... maar die GROOT downfall is dat dit doners swaar is on te lig. Bianca sal erg sukkel daarmee.
Tom, Johannes is 100% correct hereJohannes van die See wrote:Tomhatvani wrote:I'm thinking something similar, but incorporating the existing tow bar I have as the base of the swing arm. It's one of those bars with the full width of the vehicle. Will it be solid enough?
For one spare wheel it should be solid enough, two spare wheels might get a bit heavy.
I'm planning for two so I would much rather build a complete new towbar/rear bumper that can handle the load.
OOOOMS wrote: They may be bulky and heavy, but are about the only clips that work properly, the others tend to rattle.
Family_Dog wrote:The catch used in Bulldog does not rattle. When inserting the lockpin, you push against the 'springiness' in the lever.OOOOMS wrote: They may be bulky and heavy, but are about the only clips that work properly, the others tend to rattle.
Catch thatFamily_Dog wrote:It is rather catchy....
Mine (and I notice quite a few others) have square tubing ..... Thys seems to think that this is better, more sturdy for the jack insofar as much that it cannot 'roll' or pivot, but I think if it wants to go it will go and it will twist / break the tongue on the jack.OOOOMS wrote:Roundbar in die bumper, een aan elke kant, flush finish :wink2:
Definitely, and affect the departure angle as well as affect the load on the rear axle. I've never considered this as ideal, but in certain cases it could be the lesser of other given evils. There's not much bin space on a D/C and if I had to carry an extra spare, I would prefer it at the back (load permitting) than on the roof. Sometimes the need for an extra tank displaces the spare from it's original position .... then where does one put it?hatvani wrote:Johan,
Do you think that the displacement of the two tires so far back with their considerable weights will effect the wear on the rear suspension? I'd think it will significantly alter the original geometry.
The logic behind the round HL jackpoint is a valid one for when you want to jack the vehicle up and push it off the HL Jack in a recovery situation, but at the same time this round HL jackpoint is unstable, because of its roundness when one wants to change a tyre.Mud Dog wrote:Mine (and I notice quite a few others) have square tubing ..... Thys seems to think that this is better, more sturdy for the jack insofar as much that it cannot 'roll' or pivot, but I think if it wants to go it will go and it will twist / break the tongue on the jack.OOOOMS wrote:Roundbar in die bumper, een aan elke kant, flush finish :wink2:![]()
Warrenwarrenaken wrote:Hi Johan,
That fist image you posted? what exactly is it (zoomed out).
I cant see any "arm" on which the wheel would swing, or are you just showing the latch?
Nie n slegte idee nie Mark, ek dink Andre "Dustydre" het so setup op sy lorie gehaad, weet net nie watse axel stub dit was nie, maar nou dat jy dit noem dink ek hell why not, so iets kan die job baie eenvoudig maak.OOOOMS wrote:Johannes, ipv 'n gat te boor binne indi e agter bumper, dink bietjie oor die.....? 'n square / ronde plaat wat met x4 boute bo-op die bumper soos 'n golf of soortgelyke cv met bearing binne wat kan swivel. Dan kan jy dit eenvoudig af haal soos jy wil?
Thanks Thys, ek sal kyk watter een die goedkoopste is, al wat ek nou aan dink is....ThysdJ wrote:Johannes, hulle gebruik gewoonlik 'n citi golf se voorste stub-axle, of jy kan 'n trailer sinne ook gebruik..![]()
Thanks Thys, ek sal kyk watter een die goedkoopste is, al wat ek nou aan dink is....Johannes van die See wrote:ThysdJ wrote:Johannes, hulle gebruik gewoonlik 'n citi golf se voorste stub-axle, of jy kan 'n trailer sinne ook gebruik..![]()
