Lexus V8 conversion vir KZ-TE
Jack KZ-TE
Town: Durban
Vehicle: 2001 Toyota Hilux KZ-TE DC 4x2
Real Name: Jack
Post by Jack KZ-TE »
Hi almal, se asseblief vir my wat die prys van n Lexus v8 engine en gear box is asook al die komponente wat ek sal moet vervang op my KZ-TE as ek dit wil doen..... wil net weet vir nou en sien of ek solank kan begin aan koop om dit te doen .. o ja, waar kry ek die komponente :eh: DANKIE !!!
One day at a time please..
hentey
Town: worcester
Vehicle: 2700i 4x4
Real Name: hentey pople
Re: Lexus V8 conversion vir KZ-TE
Post by hentey »
Ek hoop jy is n ryk man!!!!!
ToyX4
Town: Ottosdal
Vehicle: Rocky's
Real Name: Riaan
Post by ToyX4 »
Jack, as jy die ding reg doen, gaan hy jou so tussen R60 000 en R70 000 kos. Dis nou as jy dit laat doen.
Self doen weet ek nie. IIRC kos die enjin so in die omgewing van R9000, ordentlike radiator(BMW 740) so tussen R2000 en R3000, ECU Dicktator so R3500/R4000, Microtech so R11 000.
Die is wat ek min of meer weet. Hoe akkuraat dit is, weet ek nie.
Ek weet ook nie wat mens alles nodig het vir die ombouing nie. Maar ek is seker die ander manne sal die lys aanvul.
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
Post by Jaws »
:thumbup:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Herman wouldn't the Lexus v8 require a little more than the standard dicktator, like the multi-coil version, R 3500, or wasted spark version, R 2950??
http://www.dicktator.co.za/html/multi_c ... ecu_s.html
B :wink:
Thabogrobler
Club VHF Licence: x223
Post by Thabogrobler »
And since the old gearbox will just stand in your way, I'll pick it up - free, no charge to you!! :twisted:
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Post by BenHur »
snipes wrote:Herman wouldn't the Lexus v8 require a little more than the standard dicktator, like the multi-coil version, R 3500, or wasted spark version, R 2950??
B :wink:
Yes Bretton you are right and Blom/Spartan the Dictator Advanced Units can be pre populated with the right components and coding on the triggering circuit inside just like the Microtech to accept the standard Toyota crank pick up without any interface or modification. Jaco I actually forgot to make a video clip for you of Marius Nel's bakkie's trigerring. It runs a Dictator Wasted spark setup with the magnetic circuit indicated below and 36-1 coding and using my timing light the "tipex" mark on the crank pully is totally stationary at one spot when she idles, it looks like it is paited onto a fixed part. :twisted: :twisted:
IIRC you will also need an external multichannel Igniter ( R650) for a Lexus engine as its coils does not have built in igniters like the 3RZ
http://www.dicktator.co.za/html/ignitor_modules.html
They also make a nice gearbox controller to control the Lexus Autobox for R 2500.
http://www.dicktator.co.za/html/gearbox ... llers.html
Jack KZ-TE
Town: Durban
Real Name: Jack
:o: Ja nee, ek is nou nie so ryk nie. niks fout met my KZ nie.... sal eerder n ou cheapie koop en ombou met tyd...
Dankie julle, mens kan altyd staatmaak op ouens soos wat op die forum is
TKS :thumbup:
BenHur
Real Name: Bennie
Post by BenHur »
Jack KZ-TE wrote::o: Ja nee, ek is nou nie so ryk nie. niks fout met my KZ nie.... sal eerder n ou cheapie koop en ombou met tyd...
TKS :thumbup:
Die engine en autobox self is nie so duur nie die sal jy dalk kan optel vir onder R 10K by die jap engine importers.
Jaws
Town: Sharonlea
Real Name: Herman
Post by Jaws »
Just for interest sake:
I opened up a MR. Turbo system the other day and I saw that they use PIC`s ( http://www.microchip.com/stellent/idcpl ... &nodeId=64 ) as the microcontroller and the Dickatator units employees Atmel micro controllers ( http://www.atmel.com/microcontrollers )
Just thought I would share some useless information.
It`s a pity that that the Dicktator cannot accept a 5V input from a lambda sensor for logging purposes.
:thumbup:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Herman, a properly dynotuned and mapped ECU does not require a lambda probe... it's us that tinker to much after the dyno that makes a mess of it... so in that case a lambda probe could be useful... so far I have left my dyno'd map pretty much as is... and my Dicktator controlled EFi is running beautifully, 93kw from a 4Y 2.2... there is a work around if you want to use a lambda probe, the Dicktator allows for a pot to be connected for fine adjustment(range can be adjusted via software) of the AFR(air fuel ratio), and if you got a display for the lambda probe, then you can fine tune the AFR via the pot.
B :thumbup:
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Post by Bushwacker »
Het iemand al 'n lexus in 'n KZ gesit...wat werk? :problem:
Gunta
Real Name: Mark
Post by Gunta »
That would be interesting since the diff ratio is 4.1 and would be nice and low for that V8.
3RZ
Vehicle: 2004 Legend 35 Hilux 2.7 DC 4x4
Real Name: Willem Grimsell
Post by 3RZ »
I have the KZ's diff ratio as 3.727.
Bushwacker
Town: Vryheid Natal
Real Name: Piet
My Lexus is in, but the tie rod & steering damper on the IFS does not work with the front-sump engin. The SFA part will be done soon.
PS. Fana CAN make a bellhousing & flywheel :thumbup:
Gunta
Real Name: Mark
Post by Gunta »
3RZ wrote:I have the KZ's diff ratio as 3.727.
You may be right which is why at 120km/h the rpm is 2500
Gunta
Real Name: Mark
Post by Gunta »
Bushwacker wrote:My Lexus is in, but the tie rod & steering damper on the IFS does not work with the front-sump engin. The SFA part will be done soon.
Piet did you remove your Kz engine and put in a Lexus and what did you do with the old engine?
conversion man
Town: pretoria
Vehicle: 911 Carreara MB CL 500 MB 500SEC MB 450 SLC CHRYSLER CROSSFIRE CONVERTABLE SFA HILEX JEEP 5.2 V8 FORD RANGER LEXUS
Real Name: Fana
Post by conversion man »
Ek hoop PIET het gedoen wat hy veronderstel was om te doen { nboot gekoop want n diesel engine maak n goeie anker } . Moenie worry oor die sump nie ek sal jou een van my back drop sumps stuur .
chopper
Post by chopper »
Mark,
Ek was ook op daardie enjin se spoor! :P
Dit is na sy broer toe
conversion man
Town: pretoria
Real Name: Fana
As jy n DIESEL wil insit gaan vir n WL 2.5TD uit n MAZDA . Hy kos baie minder en maak beter krag .Ook is dit nie ncomputer diesel nie .n Bellhousing is ook geen probleem ek maak een .
Bushwacker
Town: Vryheid Natal
Real Name: Piet
conversion man wrote:Ek hoop PIET het gedoen wat hy veronderstel was om te doen { nboot gekoop want n diesel engine maak n goeie anker } . Moenie worry oor die sump nie ek sal jou een van my back drop sumps stuur .
Thanx Fana, ek dink dit gaan nodig wees. Weereens dankie vir die perfekte bellhousing. Jy mag maar :thumbup:
Post by Family_Dog »
Useless without pictures_1_.jpg (56.63 KiB) Viewed 5488 times
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Sorry for Hijacking this fret, but the topic is the same.
FD, the picks will follow soon :thumbup:
Bushwacker
Town: Vryheid Natal
Real Name: Piet
The 50mm bodylift is completed, and the 35's fitted. The engin mountings is next :thumbup:
The red arrow shows thet the tie rod and the sump does not go together.
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Has anyone got the fanbelt part number please?
Toybox
Vehicle: Hilex
Real Name: Jonathan
Club VHF Licence: X100
Post by Toybox »
Piet, are you using the pulley the hydraulic fan utilises or have you omitted it?
Bushwacker
Town: Vryheid Natal
Real Name: Piet
I heard that it has a hydraulic pump that has to be stripped out if not used.
I must still buy a fanbelt, so if I can bypass it for now it would be great. maybe someday one can use that pump to drive a hydraulic winch :think:
Toybox
Vehicle: Hilex
Real Name: Jonathan
Post by Toybox »
If you remove the pump but have the aircon fitted, then the fanbelt I use is a 6pk1815 belt. If you keep the pump (remember to strip out the vanes and seal the unit) then you'll need a longer belt...
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Thanx Jonathan :thumbup:
I installed the engin mountings tonight, and will build the surge tank tomorrow evening :thumbup:
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Can someone please tell me how much oil & what oil for the Lexus, and also, what petrol to use :?:
Thanks :thumbup:
Tomorrow I will start with the SAS :mrgreen:
Piet, I googled for the information but could not find it. However, here is a very interesting read on the Lexus V8 motor:
http://www.lextreme.com/1uzfe_info.html
Fuel would undoubtedly be Lead Free.
conversion man
Town: pretoria
Real Name: Fana
Piet if you loose the hydraulic pump the belt will slip when the aircon is on and the lectric fan kick in and cause the alt to draw extra power because of the route the belt goes the contact area on the main drive pulley is reduced . The rigt belt is a 6pk 2245 but that is difficult to find so use a 6pk 2240 .
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Dankie Fana, enige nuus oor die sump :thumbup:
conversion man
Town: pretoria
Real Name: Fana
Het n paar gecast maar moet hulle nog masjieneer .Sal kyk so volgende week.
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Dis gaaf, maar het jy nie dalk van die oorspronklike sumps met die pan agter nie?
Dit hoef nou nie so fancy te wees nie.
Demon
Town: JHB
Vehicle: Hilux 3UZ vvt-i. Disco 3 V8 4.4 L. G Wagon 3UZ vvt-i . Polo 2.0 converted...Volvo S40 2.0
Real Name: Derrick
Post by Demon »
Would say go and get yourself the back sump setup from fana. DONT go get it anywhere else, the casting are all the wrong size. Going thru the surge tank is alot of work and it's full benifits are only felt in sumthing like a race car for the track. The only benifit im hoping for is that the heat of the oil is away from the motor, I run 7 liters of oil as aposed to 5, less oil splash in the sump, less air bubbles in the oil as the oil has time to settel and push the air out ( the oil is more conditioned) and the truck would have to be on it's roof before it starts to suck air.
V8 SOLID
Demon
Town: JHB
Real Name: Derrick
Post by Demon »
Looks like you got sum good space infront of the motor :clap:
V8 SOLID
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Demon wrote:Would say go and get yourself the back sump setup from fana.
I bought the whole setup from him :thumbup:
Demon
Town: JHB
Real Name: Derrick
Post by Demon »
:thumbup:
V8 SOLID
Spartan
Town: Vanderbijlpark
Real Name: Jaco
Post by Spartan »
Piet
Wil jy nie n foto neem van daai mag's wat jy op die bakkie het nie asb.
MOBILITATE VINCERE
Spartan
Bushwacker
Town: Vryheid Natal
Real Name: Piet
:thumbup:
conversion man
Town: pretoria
Real Name: Fana
Daai wiele lyk doubble sharp .
Bushwacker
Town: Vryheid Natal
Real Name: Piet
Thanx Fana :thumbup: , Sê my aseblief, watter throttle cable gebruik ek, want die KZ het mos nie so iets nie :think:
