Performance chip
Predator
Vehicle: Hilux d4d 4x4
Real Name: Riaan
Performance chip
Post by Predator »
ey all the Toyota-holics.
I recently fitted a Performance Chip to my 3.0 d4d Hilux bakkie, primarily for more power when towing.
During my first towing trip, the bakkie went into Limp Mode 3 times, while driving in 3rd gear up a long steep hill. (Vehicle was "labouring". My large offroad trailer weighs around 1ton).
The supplier says it is NOT the chip (that connects directly to the Injectors) but it could be the Turbo which has carbon build up and causes the bakkie to go into Limp Mode under strain. .
Huh?
Anybody have an opinion? ?
Predator
Tenk
Town: Hilux Country
Vehicle: 07 hilux dc 4L v6 manuel, alu canopy, rock/s, full ome sport, Hoppy s/s custom exhaust, 33 grabber muds, compressor, exstra 80L f/t, dual battery,body lift,redpepper bumper,custom sound with sub,afternarket touchscreen entertain unit, dynoteck chip 188kw
Real Name: Pierre
Re: Performance chip
Post by Tenk »
Hallo Riaan ek het my v6 onlangs laat chip by Dynotech in Brackenfell. Hulle is uiters profesioneel en gebruik goeie produkte. Ek kan nie jou probleem oplos nie maar hulle sal jou beslis goeie raad kan gee.
Predator
Real Name: Riaan
Post by Predator »
Dankie Tenk.
Ek sleep weer gedurende die skool vakansie, sal kyk of dit weer gebeur.
Geniet jou 4.0 v6 4x4, ek het die Prado 4.0 v6 4x4 auto gehad - Awesome! !
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Tenk wrote:Hallo Riaan ek het my v6 onlangs laat chip by Dynotech in Brackenfell. Hulle is uiters profesioneel en gebruik goeie produkte. Ek kan nie jou probleem oplos nie maar hulle sal jou beslis goeie raad kan gee.
JA, daai manne by Dynotech KEN hul storie.
my raaiskoot - die chip overfuel, dus skiet die EGT die hoogte in, die Hilux computer tel dit op en gaan in limp mode tot die temperatuur weer gedaal het .... :shock2:
dis een ding om "ekstra krag" te kry vir verbysteek of n bult, maar as jy heeltyd ekstra krag soek .... uhm ja .... dit kan n duur oefening raak ....
Dirka
Town: Doornpoort Pretoria
Real Name: Dirk
Post by Dirka »
+1
” ― J. Kintz
Thabogrobler
Club VHF Licence: x223
Post by Thabogrobler »
Kom ek raai, dis 'n chip wat jy sommer self inplug??
Jammer ou maat, jy het jou geld gemors EN vat 'n groot risiko met jou enjin se gesondheid.
Die regte pad om te loop is 'n chip wat op 'n dyno vir JOU kar ingestel word. Dan word alles gemeet en wat jy weet(gemeet), kan jy bestuur!
Die logika ontgaan my. Jy spandeer R3/4/500 000 op 'n voertuig maar wil R1000 spaar op 'n chip? Wat kos dit om 'n D4D enjin te vervang? R80/100k?
Each to his own....maar ai!
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Thabogrobler wrote:Kom ek raai, dis 'n chip wat jy sommer self inplug??
in all fairness .... those plug and play guys are GOOD salesmen !! :o: :shh:
sadly not everybody understands enough of this topic when they first spend money
FORTUNATELY the bakkie went into limp mode .... some others just keeps on going until catastrophic engine failure ....
bietjie skoolgeld, (hopelik) geen skade
observer
Vehicle: 2011 Toyota Fortuner 3.0 D4D 4x4
Real Name: Jaco
Post by observer »
Is your diesel filter clean?
BTW: I'm also not a fan of these plug and play chips and prefer the Unichip that can control boost and fueling over the entire rev range ;)
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Post by Johan Kriel »
Thought the 3l tow good enough. Well I towed a 3 ton trailer with it and never though I need more power. Yes I chipped a 2.5 but who would not! :D:
Yes If you need to chip get something worth while. Like the Dastek Unichip.
Johan Kriel
Legend 50
