My boet has recently bought a 97 2.8D SFA Hilux which stood still for around 3.5 years and are in need of some TLC.
We are now looking to systematically get it up and running again (going to be a slow process since time is "few"). In trying to get it started we need to get the aftermarket immobilizer to get with the program which it currently refuses. I have a few pics of the culprit and would like to know if anyone is able and willing to identify the type/brand of unit so that we can maybe get it tested and repaired or a new one from the manufacturer. Failing which we will have to dissect it out of the equation.
It looks like a RFID Tag type immobilizer. There is no identifiable branding on the unit.
Thanks guys.
Here are the pics:
Help identifying immobilizer
- Vehicle: Land Cruiser 79 P/U
- Real Name: Drinus
- Unit's RFID Tag
- RFIDTag.jpg (65.43 KiB) Viewed 548 times
- Unit's RFID antenna
- (48.96 KiB) Downloaded 149 times
- Unit's top side
- (50.47 KiB) Downloaded 149 times
- Unit's bottom side
- (57.97 KiB) Downloaded 149 times
- Unit's side with connectors
- UnitSide.jpg (35.6 KiB) Viewed 548 times
- Unit's PC Board
- (60.25 KiB) Downloaded 149 times
Re: Help identifying immobilizer
Don't know it, but if it's giving hassles it's probably best to replace altogether. Usually they are not worth repairing as replacement units are not that expensive.
- Town: Heidelberg
- Vehicle: Hilux 2.5 D4D
- Real Name: Koos
Drinus, op die swart terminal block is daar 4 spade connectors wat van die relays af kom. Dit sal ook die skakels wees wat die voertuig immobiliseer. Ek glo no 1 & 2 en 3 & 4 werk saam, m.a.w. 1 is common en 2 n/o of n/c kontak. Om veilig te wees lei dit uit met 'n multimeter op die agterkant van die PC board waar die relay kontakte gesoldeer is. Brug die terminals uit in pare per relay.
Kyk ook na die topic:
viewtopic.php?f=3&t=14655" onclick="window.open(this.href);return false;
- UnitSide.jpg (58.62 KiB) Viewed 516 times
- Real Name: Drinus
Thanks Andy, probably the route that we will go in the end (or an alarm/immobilizer combo) if we can not get this type. I just thought that we might be lucky to get it ID'ed and a plug-in replacement without having to doddle with the wiring. :roll:Mud Dog wrote:Don't know it, but if it's giving hassles it's probably best to replace altogether. Usually they are not worth repairing as replacement units are not that expensive.
Koos, dit was ons volgende stap, i.e. om te begin torring met die "guts". Gelukkig is ek darem so effens vertroud met die basics van relays so ons sal dit intussen probeer om die Lux tydelik aan die gang te kry. Dankie vir die voorstel.Ou vale1 wrote:Drinus, op die swart terminal block is daar 4 spade connectors wat van die relays af kom. Dit sal ook die skakels wees wat die voertuig immobiliseer. Ek glo no 1 & 2 en 3 & 4 werk saam, m.a.w. 1 is common en 2 n/o of n/c kontak. Om veilig te wees lei dit uit met 'n multimeter op die agterkant van die PC board waar die relay kontakte gesoldeer is. Brug die terminals uit in pare per relay.
