Parts help for 2002 Hilux
- 4x4Grant
- Town: Scottburgh
- Vehicle: Hilux KZTE
- Real Name: Grant
Hi Guys
I am trying to find the following 2 items
1. a bar to hold up the tourney cover on my days 2.7i long wheel base hilux
2. the mounts the fit in the bin that the bar fits into
Does anyone know where i can find these items please
Grant
Grant
Schools don't need all them number calculatin' classes.
The only math folks need to know is
4 x 4 = Off-Road
4 x 4 = Off-Road
- Omo
- Vehicle: Ford Ranger super cab 3.0 xlt 4x4
- Club VHF Licence: HC236
Re: Parts help for 2002 Hilux
Hi Granr. Use these part numbers @ any toyota for the required parts. Torsion bar:pzn65d1033 and for the brackets use pzn65d1034
There a two kind of people. Those who pushes a door when it says pull and they who pull a door when it says push.
- 4x4Grant
- Town: Scottburgh
- Real Name: Grant
Thanks so much for those numbers
4 x 4 = Off-Road
4 x 4 = Off-Road
- merwn
- Town: Kriel
- Vehicle: 1995 Hilux 4x4 DC
- Real Name: Nick
As jy nader was sou ek jou kon help met die bar en brackets ek het van dit
- 4x4Grant
- Town: Scottburgh
- Real Name: Grant
I found a site that sells these brackets and they in KZN. R 3.50 a bracket is not bad in my books.
Now just to find a bar.
Sent from my GT-I9295 using Tapatalk
4 x 4 = Off-Road
4 x 4 = Off-Road
- 4x4Grant
- Town: Scottburgh
- Real Name: Grant
Merwn where abouts do you stay
4 x 4 = Off-Road
4 x 4 = Off-Road
If the bar that you speak of is the same as the way they used to do it long ago, then it's nothing more than a length of 10mm spring steel rod, slightly bowed with a short 90° bend at each end.
Find a place that makes up springs, they will have that stuff in stock, even bend it for you - probably at a fraction of the cost of getting from the stealers.
- merwn
- Town: Kriel
- Real Name: Nick
Mpumalanga Kriel
The bar do not have 90 degree bars on the end, it is more like 110 degree bends.
The idea is that you have to bend the rod to get the end into the 90 degree brackets on the side and that is hat gives it the upwards bow shape.
That's true, maybe not as much as 110°, but what really gives it the bow is that it should be about 12mm longer than the distance between the mounting brackets ... it's then forced to bow to get it to locate. The more it's over sized, the more it will bow when located.pietpetoors wrote:The bar do not have 90 degree bars on the end, it is more like 110 degree bends.
