2.7 D/C body lift
Willem van Schalkwyk
Real Name: Willem Van Schalkwyk
2.7 D/C body lift
Post by Willem van Schalkwyk »
Hi All,
I want to do a body lift on my 2.7 but I got some mixed information.
I don’t want to lift it to high, about 30 - 40mm.
Can someone give me advice on what to do?
Some guys say it is a very difficult job and others say it is easy.
Also how many spacers would I need and what length bolts.
Much appreciated.
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Re: 2.7 D/C body lift
Post by Hoppy »
a standard lift is 50mm, you need 14 spacers, they are R600.00 for the set
once you removed the bolts, take them to a bolt & nut place and get a set that is 50mm longer
Lifting the body is not that difficult, it is all the small things that goes with it. like te radiator, bumper brackets, towbar , gear levers, fuel filler pipes etc.
Thanks Hoppy :thumbup:
Is there anything that I must buy extra for all the small bits and pieces?
coert
Vehicle: hilux
Real Name: coert
Club VHF Licence: none
Post by coert »
Don't know if a body lift is wise, me I will rather go for suspension lift my 2c worth of sh^%%
Donkey
Club VHF Licence: X122
Post by Donkey »
Remember to get a longer fuel hose, I used normal radiator hose, the breather still had slack. Once you do a body lift, the spare wheel under the bin, the holes where you take it up/down, will misalign.
Tumelo Maketekete
Thanks guys!
I want to fit 32" tyres.
I already have OME suspension but don’t want to go for the extended shackle option.
As I understand this will make the car more unstable when towing??
Hiluxfan_111
Town: Muscat and Midrand
Vehicle: 2.7 Hilux 4x4
Real Name: Roelof
Post by Hiluxfan_111 »
Hello Willem
On my single cab there are two diagonal supports under the load bin. I'm not sure if the double cab also has them.
You also need to add a spacer under these. Otherwise the bin may get damaged with a heavy load.
(57.44 KiB) Downloaded 490 times
Thanks for the help.
I have manage to get away without a body lift but might still lift a bit later.
The wheels scratches on full suspension travel but that will go away with time :twisted:
Will post a pic with before and after.
(107.06 KiB) Downloaded 374 times
(115.26 KiB) Downloaded 374 times
Froll
Town: Vioolsdrift
Real Name: Roger
Club VHF Licence: N/A
Post by Froll »
Looking good. :thumbup:
smokintyres
Town: Windhoek
Vehicle: Hilux 4.0 V6, relatively standard; for now...
Real Name: Gernot
Post by smokintyres »
Looks good!
I put 31" tyres on my 2.7 before I could afford the lift, the noise of the tyres catching on turns soon made me dish out the extra cash on a suspension lift. Always worried that the tyre may eventually tear something off or may get cut... I would definitely look into the body lift if I were you.
Since you mentioned towing: Never, ever drive in 5th when towing and when not towing, do not change to 5th, until you are traveling at at least 120km/h. Massive strain on the gearbox, especially 5th gear.
coert
Vehicle: hilux
Real Name: coert
Post by coert »
Intressante opinies het ook body lift oorweeg maar daar teen besluit toe oorweeg ek daai ball joint lift en diff drop ding. Doen toe so bietjie navorsing en teen altwee besluit, eintlik swambo se besluit sy sukkel al reeds om in en uit te klim so ek het dit maar gelos en net groter bande op gesit om die "pampoen" so bietjie te lig. (my 2c worth of Sh^%$)
ismail
Vehicle: Hilux '03 2700i SC 4x4
Real Name: Ismail
Post by ismail »
those MTR's are wider, on my hilux had bf muds 32" didnt touch at all, but the 32" MTR does touch and thats with the same std rims on both.
I surf more than I work
