Speed,interresting read
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Ever wonder why a Top Fuel dragster gets a rebuilt engine after each run?
Stay with this- even if you aren't a 'car nut', this is stunning.
* One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR's Daytona 500.
* Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second;
a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
* At the stoichio metric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. Which is typically the output of an electric arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough sufficient force to blow the cylinder heads off the block in pieces or split the block in half !!
* Dragsters reach over 300 MPH +... before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free,
& NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of t he run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin 'chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . .
quicker than a jet fighter plane . . . quicker than the space shuttle....or snapping your fingers !!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta).
The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
Let's now put this all into perspective:
Imagine this...........You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile s trip as you pass. You have the advantage of a flying start. You run the 'Vette hard, on up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH.... The 'tree' goes green for both of you at that exact moment. The dragster departs & starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that seares and pummels your eardrums & within a mere 3 seconds the dragster effortlessly catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it – from a standing start, the dragster had spotted you 200 MPH.....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
That, my friends.....is acceleration.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- jacques kotze
- Real Name: Jacques
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
Re: Speed,interresting read
I want one....
DAM now that is fast.....
I think if you had a nice wimpy breakfast cooked in all that oil you would be seriously and that would be from pulling it up onto the start line....
[rimg=206x128]
[rimg=206x128]
Now that is some serious stats. But even with that... my bakkie still beats him off road... hehe
- Bosfebok
- Town: Roodekrans
- Real Name: Otto
- Club VHF Licence: X248
Awesome stuff.
Otto X248
20.5" LED BAR
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
20.5" LED BAR
90l Water Tank
Slide Drawer System
Safari Snorkel
Diff breathers
- kfxnando
- Town: Germiston
- Real Name: Fernando
All true
Just a few years old
Nowdays there are sub 4sec passes
At some big events the distance has been shortened to 300m for safety reason due to the speeds being attained
That was about 4 years ago, so no sure if the 300m has become e the standard or been dropped
Current standard time to rebuild the motors completly is 21minutes
At some tracks there were 4 lanes
So imagine 4 times 8000hp screaming down the track
- Ou Legend
- Town: Kuruman
- Vehicle: 1987 Hilux SFA 4x4
- Real Name: Stefan
Baie interessant,dankie.
- Modder Tekkies
- Town: Malmesbury
- Vehicle: 2.8 Gd6 Fortuner 4x4
- Real Name: Ferdinand
- Club VHF Licence: HC252
Dan moet jy 'n 2L Cortina bakkie sien op 'n Vrydagaand in Parow
- Town: grassy park cape town
- Vehicle: 99 s/c hilux 4x4 2.7i long range tank & dual battery; 2003 nissan x-TRAIL (4X4)
- Real Name: charl
het julle al n XR6 gesien op sy hey day op stranfontein pavilion se teer blat met skreeunde wielle
- hansman
- Town: pretoria
- Vehicle: hilux sfa
- Real Name: hans
Hello Manne
Nou is my spoed gebreek.Daar is op my battery gepiepie.Hoe kan julle dit aan my en Vaaltyn doen. Ek het altyd vir Vaaltyn gese HY is die vinnigste donkie op aarde en nou lees ek van hiedie wille goed.
In alle eerlikheid dit is voorwaar wonderlike statestiek en ongelooflik wat die kerels anderkant die water uit suierenjins haal.
Dankie vir die lekker leesstof
Groete :Hansman &Vaaltyn(sal anderpad kyk by verkeerslig langs n dragster)
- kfxnando
- Town: Germiston
Just remembered something else
Those dragsters dont have a radiator or a cooling system as road going cars do
The gaps in the engine block are filled with so e gel to help with the cooling
Maybe not enough time to warm up
And the fuel being dumpped into those monsters also helps keep things cooler
- Donkey
- Club VHF Licence: X122
:wth:
Tumelo Maketekete
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Luxter sal darem n duin klim met een van daai!
