The 'Two Corsa fans on 3RZ radiator mod"
- Kaspaas
- Town: Wellington
- Vehicle: 1998 Land Cruiser 105series GX
- Real Name: Cobus
Hey guys/gals , decided to do a short write up on this conversion as there is little info on the forum.
Right, first things first : "I are boer" so excuse the bad Inglisjh!
The dimentions of the fans are 290mm (h) and 350mm(b).
The 3RZ radiator is 550mm (h) x 550mm(b) that is with the tanks(top & bottom) included.
Little things I realised through the build.
- There is only one Corsa LITE aircon fan with a cowling. It seems to be the 2003 -2005 model, but remember its the LITE!
- The success of this conversion is dependent on how close(flush) you get the fans to the radiator. (Between 1-2mm gap.)
- Remember to put some sort of self adhesive foam strip between the cowling and the radiator 2-3 mm thick, otherwise the constant vibration of the fans will damage the little "fins" of the radiators.
- You wil have to remove all the brackets from the radiator and build your own. There are two reasons for this, firstly to get the fans as close as possible to the radiator, and secondly to get the fans fixed to the radiator.
- Relocation of the Aircon Rad is a must if you are going with a slightly longer enjine. (7MGE & 2JZ).
- Cutting the font end of your van to accommodate the fans is going to be necessary.
- If you do cut the front end (thus weakening the bonnet hitching point), I will advise you to install "bonnet pins" otherwise the bonnet might fly open!
Okay , this is what material I used for the bracket
- 2m x 20mm angle iron (2mm thick)
- 6 x 6mm bolts with lock nuts.
- 5m x 2.5mm selfadhesive foam strip.
- 2 x 50mm x 20mm flatbar
- 2 x 100mm x 500mm flatbar
- little bit of black paint
The angle iron is for the bracket that fixes the fans to the radiator. (This will differ between models and makes)
The bolts for fixing the fans to the bracket
The flat bar is to fit the whole "shebang" to the front end. (This will differ between models and makes)
Cost sheet on January 2013
The fans where R650 each. Mine are OEM GM fans (I included a picture with the part number.)
The 3RZ radiator was R850 but this was pirate. (Toyota OEM is a joke!)
I had all the metal bits already, and the foam strip was R 19.50.
And finally the end product!:
If you need any more dimentions or have any questions, feel free to ask!
Edit:
I'll have too cred's too Mark Gunta and Everdt Bulletjie-3!
This is actually Marks design!
Thanx guys!
Edit:
Thanx guys!
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: The 'Two Corsa fans on 3RZ radiator mod"
baie mooi, sal daai plan onthou
Nice en goed gedoen Cobus.. As daai 2 fans begin suig dan raak Kaspaas sommer ligter op sous..
Nou kan jy jou gat lekker koel waai..
- Club VHF Licence: X93-
Dankie Cobus vir die intressante inligting.
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Nice neat job, well done.
Very nice write-up Cobus! This goes into the "Hall of Fame", where I save many interesting projects on my PC.
- Town: LANGS DIE ORANJE RIVIER
- Vehicle: 1994 2.2 Hilux
- Real Name: Lehan
Goeie werk ou Pel. Lyk goed. Een van die dae kan ons gaan duine ry.
- Kaspaas
- Town: Wellington
- Real Name: Cobus
Ek dink nie julle het 'n idee hoe die fans suig/waai nie!!!!!!!!!!!!!!!!!!!!!!!!!!!
- sir shrek
- Vehicle: '09 Hilux D/C 4.0 V6 AKA 'BULLET' Hilux D/C 7M-GE aka SIR SHREK(SOLD) Jetta MK5 2.0TFSI
- Real Name: Claude
Hi Cobus
Het jy nogsteeds die fan setup in jou bakkie en werk dit nogsteeds effektief?
3" suspension lift 31" bfg muds dual fuel tanks custom bushbar 7M-GE
Rear Diff Lock Custom made snorkel
UGLY LIKE SHREK,STRONG LIKE RUSSIA
- Kaspaas
- Town: Wellington
- Real Name: Cobus
Hey Claude, hy loop soos stroop!!
Twee NoordKaap somers in die rooiduine oorleef, en huidiglik twee keer 'n week in erge Diep-Kaapse verkeer, naald beweeg niks, soos in niks nie!!
- sir shrek
- Real Name: Claude
My Hilux is tans nog besig met n drie jaar lange hibernasie maar ek moet hom nou wakker maak.
Ek gaan nog baie vrae vra. Vertal my asb van jou fuel pomp setup want die hibernasie het my pomp vermoor. Ek wil sommer nou nuwe generasie pomp en setup insit
- Gunta
- Real Name: Mark
You can use an inline vw fuel pump.
