Help! 4wd light flashing
- Town: Midrand
- Real Name: Nishan
I have been towing a trailer with a car on it from joburg to mooi river. Around bergville the 4wd green light on the dash started flashing.
Any idea what it,means?
Real drivers use three pedals
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Re: Help! 4wd light flashing
Had the same problem with my D4d. Light flashing and then when you swicth the ignition of and on again ir stops for a while. Acording to toyota it was the silinoid that ingage the front diff that was faulty. They replaced it and problem solved.
- Town: Midrand
- Real Name: Nishan
I see that it could also be caused by the gearbox oil gettin too hot
will monitor and see.
It wants you to drive offroad more often...
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
If you put it in 4wd, does the light still flicker on does it stay on?
- Town: Midrand
- Real Name: Nishan
The clutch is now slipping. The light has not come on again. I haven't tried 4x4 mode yet
Will change clutch on thursday provided I can find a mac and get the kit
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Last year I also needed my clutch replaced this time of the year, and because everyone was closed had it replaced at Zwartkops racetrack, however the never replaced the pilot bearing or skimmed the flywheel, now it still makes a prominent sonbesie sound.
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Town: Midrand
- Real Name: Nishan
There is no winning with the sonbiesie sound. I had replaced the clutch before coz of that sound and it came back after 2000kms. Then the new clutch started slipping so I put the original one back. That's the one giving shyte now. Buying Another kit and fitting on thurs. That light comes on after about 70km of driving. Gearbox is slightly noisy now. Gonna change fluids as well. Hopefully that helps
- Town: Midrand
- Real Name: Nishan
Ok, so here is the story. Replaced clutch kit, rear seal on transfer box, and gearbox oil.
The 4x4 lights is still flashing after about 50km of driving. Seems like 4x4 is not engaging.
Thats not a prob for now. Are the two symptoms related? Can i drive back to gp like this?
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
Just put it in 2x4 and you should be fine.
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Town: Midrand
- Real Name: Nishan
Cool. Thanks. Any suggestions on a 4x4 gearbox specialist in joburg? I want to have it all checked
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
I only know of Propshaft and Transmission World in Midrand. But has anyone checked the front solenoid?
ORRA CALLSIGN X120
(2011 JKUR)
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
- Town: Midrand
- Real Name: Nishan
Nope, haven't checked the solenoids. I don't know how. But the worrying part is that the gearbox is humming. I explained it to my mechanic buddy and he says it could be the main shaft bearings. Will get it stripped and checked when I'm back in gp. I'm worried that I need to tow the trailer back to gp. 'Ll be empty though
- Town: Midrand
- Real Name: Nishan
i found this near the transfer box. what is it?
- (134.49 KiB) Downloaded 1384 times
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Looks like a breather. Quick fault finding tips. Check the center bearing ( turn propshaft by hand to see if bearing is moving freely). Disconect front propshaft to ensure noise is comming from back drive train and not from front end. ( Will also help to protect front diff. )
- Town: Midrand
- Real Name: Nishan
Thanks for the advice all
I'm thinking of taking the bakkie to "gearbox and diff centre" for them to diagnose and repair
has anyone here used them before? any feedback?
http://www.gearboxanddiff.com/index.htm
- Town: Midrand
- Real Name: Nishan
some feedback
i visited the gearbox and diff centre. spoke to a nice chap by the name of Andy.
we did a test drive and he concluded its not the diff making the noise but rather the front wheel bearings.
will replace both soon and feedback.
wrt the 4x4 light flashing i think its just coincidence that it started around the same time as the noise.
The 4wd does engage still but the light does not come on when it does. will get the solenoids checked/replaced.
- Shumba138
- Town: Villeurbanne
- Vehicle: None
- Real Name: Stephanie
I'm having the exact same problem. And the indicator doesn't go on when I switch to 4wd.Vlak vark wrote:Had the same problem with my D4d. Light flashing and then when you swicth the ignition of and on again ir stops for a while. Acording to toyota it was the silinoid that ingage the front diff that was faulty. They replaced it and problem solved.
Is it an issue to keep driving like this, I mean with he indicator flashing while on 2wd??
Thanks!
Stephanie, it's best to have it checked out and repaired. If you experience a stiffness in the steering and / or hear the tyres scrubbing when turning on a hard surface like asphalt, then it means that the 4wd is in fact engaged and you should not drive it like that. Serious damage can be done.
- Shumba138
- Vehicle: None
Yeah no the 4wd definitely doesn't engaged, cause I would have felt it on the highway!
Actually the indicator doesn't come in when I'm in 4wd...
- Oosie101
- Town: Roodepoort
- Vehicle: 2007 Toyota Hilux 4.0 V6 AT
- Real Name: Nicolaas
- Club VHF Licence: X298
Mine did the same thing, ADD got some water in it. 4x4 would not engage and 4x4 light kept flickering when driving in 4x2. Add was taken out and repaired, 4x4 engages now but light does not come on anymore. Check out our post under the workshop stickies
