SPRING SPECIAL !! ALU CANOPY !! SPRING SPECIAL !!
- Gysie
- Events Coordinator
- Vehicle: Toyota
- Real Name: Ciske van Gijsen
Hi All,
Spring Special to all forum and club members !
Double Cab ALU CANOPIES!
Option 1: R 11 500
- One Door per side
- Glass cab slider up front
- Glass in rear door
- Rear Door full width
- All mill finish Alu
Option 2: R12 500
- One Door per side
- All doors and panels Anodized finish
Option 3: R 12 500
- Two Doors per side
Option 4: R 13 500
- All doors and panels Anodized finished
Please note all above options you have a choice of Tread plate or Smooth Plate also note that canopies can be delivered anywhere at a small additional cost.
Additional Extra's:
- Complete Alu Table mounted inside canopy R 1650
- Roofrack R 1450
Option 1: R 11 500
- One Door per side
Option 2: R12 500
- One Door per side
Option 3: R 12 500
Option 4: R 13 500
Additional Extra's:
- Roofrack R 1450
- Vigo Double Door Corner View.JPG (119.46 KiB) Viewed 4579 times
- Hilux SFA Single Door Side.JPG (148.25 KiB) Viewed 4579 times
- Hilux SFA Rear View.JPG (133.97 KiB) Viewed 4579 times
- Hilux SFA Open Canopy.JPG (146.2 KiB) Viewed 4579 times
- Hilux dcab Canopy1.JPG (125.64 KiB) Viewed 4579 times
- Nissan Navara Double Door Side.JPG (154.85 KiB) Viewed 4579 times
Life does not consist of the cards you are dealt but in how you play the cards you are dealt!
http://www.gomad4x4.co.za
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
Re: SPRING SPECIAL !! ALU CANOPY !! SPRING SPECIAL !!
Hi Ciske,
How much for a IFS double cab canopy with option 3, but with windows in the side doors as well? or if you think option 1 will be better for this.
- Gysie
- Vehicle: Toyota
Hi Ters,
It is your choice - if you want solid glass you will be looking at R 350 per door if it is the small doors and R 550 if it is the long side doors each.
- 4x4Maniac
- Town: Centurion
- Real Name: Werner
- Club VHF Licence: X120
Sjoe Gysie jy maak dit moeilik vir my...
Jy het nou seker my thread gelees ne?
Kan n mens die slotte vertikaal draai? En die hinges kan jy daai kry waar die skoef in die hinge versteek is? lekker dikkes, soos op Pieter se bakkie?
Wat is die anodized alu? Is dit dieselfde prys vir checkered vs smooth?
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
(2011 JKUR)
KC Spotlights
Previous:
Baie goeie anbod Ciske!
Hoekom het ek nie net 6 maande gewag nie? O ja, dan sou my vakansie nie so lekker gewees het nie..
- Gysie
- Vehicle: Toyota
Werner,
jy kan die kant slotte horisontaal insit maar ek sit altyd op n lang deur 3 slotte die ander probleem is partykeer is jou shock bracket inlyn met die slot dan neuk dit jou rond.
Die hinges kan jy by Pieter kry hy het nou net laat weet hy het voorraad in gekry.
Anodizing is n soort coating wat op gesit word - hy maak hom grys van kleur en beskerm die alu so bietjie veral op smooth plaat krap hy nie so erg nie. Koste ek betaal dieselfde vir smooth of treadplate
Skreeu maar as daar nog iets is ek help graag !
Thys,
Jy het nogsteeds n bargain gekry want jy is mos my CHOMA
Thys,
- ismail
- Real Name: Ismail
Good prices, how much for option 2 on a single cab IFS please.
I surf more than I work
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
Baie netjies, Ciske
Looks very nice.... one day when I win the lotto....
- Gysie
- Vehicle: Toyota
Hi Ismail,
Single cab canopy with anodized doors R 15 000 please note the single cab I put two doors per side standard. Hope this helps.
Ciske... as ek nou eendag die geld by mekaar kan skraap... hoeveel sal daai een kos soos op die D/C SFA met glade plate wat ge-anodise is?
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
hi ciske
is die R 15 000 vtp op die nuwe single cabs ook asb
Toyota Hilux 3.0 D4D 4x4
- Gysie
- Vehicle: Toyota
Andre,
dus is vto alle single cabs behalwe Cruisers hulle is so bietjie grooter en hoeer as ons bakkies.
Groetnis
Groetnis
- KOBUSL
- Town: WOLSELEY
- Real Name: KOBUS
En ons NOG langer gewag hetThysdJ wrote:Baie goeie anbod Ciske!
Verstaaaan jy Kobus, 'n Spring special is 'n Spring special...Hy kom elke jaar op dieselle tyd
Ek het die Autumn special gemis..
Ma Springs is mos hier bo op die Rand
Yes Cassie, so ek beveel aan jy hou uit tot Ciske die Benoni Specials uitbring..
- Gysie
- Vehicle: Toyota
Nee Thys Benoni is nog duur jy moet wag vir Danville special !
- Town: Roodepoort
- Vehicle: Hilux 3.0 D4D 4x4
- Real Name: Gerbrand
Verskoon my dom vraag, wat is die verskil tussen anodised finish en All mill finish Alu?
Kan mens vra dat die dak bv 'n dikker plaat aluminium is? Sodat as jy die tent direk daarop wil mount?
As mens 'n dakrak kies, kan ek dit later afhaal?
Dankie
Dankie
- Gysie
- Vehicle: Toyota
Gerbrand,
jy kan verseker die dikte kies maar my dak is sterk genoeg om n tent direk op te sit - ons loop bo op die dak ! Die roofrack maak met 4 boudte vas so jy kan hom op en af haal soos jy lus het.
Skreeu maar as daar nog ietsie is
GerbrandBrand wrote:Verskoon my dom vraag, wat is die verskil tussen anodised finish en All mill finish Alu?
mill finish is soos hy van sy ma af kom.. of ten minste die fabriek..
Anodising volgens Wikipedia is die volgende:
Anodizing, or anodising in British English, is an electrolytic passivation process used to increase the thickness of the natural oxide layer on the surface of metal parts. The process is called "anodizing" because the part to be treated forms the anode electrode of an electrical circuit. Anodizing increases corrosion resistance and wear resistance, and provides better adhesion for paint primers and glues than does bare metal. Anodic films can also be used for a number of cosmetic effects, either with thick porous coatings that can absorb dyes or with thin transparent coatings that add interference effects to reflected light.
- Danman
- Real Name: Danie
Dagse... wat sal die delivery na pretoria wees?.
ek stel belang in opsie1
Dankie
Danie.
Dankie
Danie.
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
My Gomad canopy is al twee jaar op my bakkie, ek laai enige iets op en in, geen probleme, hier toets die kinders behoorlik sy dak-konstruksie, na twee dae se swaai is sy dak nog reguit.
- DassieHassie
- Town: Germiston
- Vehicle: Hilux 2.4 22R D/Cab 4x4
wow goeieprys, wat sal dit kos om 'n opsie 4 in Jhb te kry?
Mens kan seker die dakrak ook later bysit, sou jy later besluit jy het hom nodig?
Groetnis
Groetnis
Evil thrives when good men do nothing
Ek moet se my GOMAD canopy het homself mooi gedra op ons Kaap tot Kunene trip. Gelaai met minstens 100kg op die dak oor baie slegte sinkplaatpaaie en 2spoor paadjies het hy sonder enige skade die 7000km afgele.
Nie net gebou om mooi te lyk nie maar prakties bruikbaar ook.
thys@teamoffroad.co.za
- Town: Roodepoort
Dankie vir die antwoorde! Dit maak nou meer sin
- Gysie
- Vehicle: Toyota
Morning,
Courier Cost - I courier on an average 2 canopies per week to JHB. Average cost on a Double Cab is R1450. But to be honest I havent spent much time on getting better prices. I must actually sit and neg. better deals for the courier.
If anyone has a contact with couriers let me know.
- Hoppy
jy het die verkeerde "coulor scheme " gekies, kyk hoe mooi lyk myne met die gladde plateThysdJ wrote:Nie net gebou om mooi te lyk nie maar prakties bruikbaar ook
- Gysie
- Vehicle: Toyota
Hoppy, julle VENTERS moet ook op alles klim en klouter!
Thanks vir jou en Thys se komments dit help as klient praat oor hulle ondervinding met n persoon se produk dit help ook vir ons as vervaardigers om terugvoering te kry sodat ons kan aanpassings maak soos ons voorentoe beweeg. As jy vat van wanneer Hoppy sin gebou is tot nou het daar al baie verander.
Het gister weer een van my kliente gesien wat ek 5 jaar terug n kappie voor gebou het sjooeeee ons het omtrent gevorder in design en profiles om die produkte mooier te maak.
Ek sit elke dag en probeer meer en meer verbeter op my produkte.
Groetnis
Groetnis
- arnize2
- Town: Wellington
- Vehicle: 2008 Toyota Hilux 3.0 D4D D/C 4X4
- Real Name: Arno
Ek sit elke dag en probeer meer en meer verbeter op my produkte.(Quote)
Ja, daar het baie verander vandat ek my kappie 3 jaar gelede laat maak het, MAAR my kappie werk uitstekend en het ek al baie komplimente gekry!!!!
Nou weer in Zim met hele vrag hout bo-op gery. Maak niks aan die kappie se dak nie. Ek kan ongelukkig nie anders as om Ciske se werk aan te beveel nie.
- Town: sedgefield
- Vehicle: 1996 2.4 petrol 4x4
- Real Name: mark
Hi Buddy,
Ever thought of making a canopy height lower so when you put your roof top tent on it,its as hi as your roof height.
Foor less wind resistance,you do not need all that packing space.Also would not be top heavy?
- Danman
- Real Name: Danie
Vrek my dinges jeuk nou!!!!
Ek het nie nou die geld nie...maar kan moontlik so oor maand of twee dalk 'n bonussie losslaan.
En om dinge erger te maak, gaan ons einde van die jaar lambertsbaai toe.
dan kan ek mos gou kaap toe ry en hom gaan optel......besluite,besluite.
sal maar staal borsel gaan koop en krap totdat ek verseker is van die geldjies.
- Rooies
- Town: Strand
- Vehicle: 1994 2.4i (22RE) D/C Raider 4X4
- Real Name: Rudi
Danie jy moet gaan hard krap, ek het nou al na n paar kappies gekyk en ek kan jou se Gysie sinne is tops. Kan nie wag om myne te gaan optel nie.
(hopelik so binne die volgernde paar dae behoort hy klaar te wees, dis nou te se as Gysie nie nou met te veel werk toegegooi is met die pryse nie.)
ROOIES: 1994 2.4i (22RE) Raider D/C - 200 000kms - Brospeed Branch & Powerflow Exhaust
MIKEM Suspension & Gabriel Safari Shocks - "31 BF Goodrich AT - GOMAD Aluminium Canopy
Melvill & Moon Seat Covers - Safari Snorkel - Bushwakka Weekender Offroad Trailer
- Gysie
- Vehicle: Toyota
More Rooies, moet nie stress nie joune sal klaar wees die week. Hy is amper daar deure en frame is klaar.
Buddie - ja ek het al n kappie gebou wat laer is sodat die rooftop tent so 10cm uitsteek bo die bakkie se dak. Ons wou laer gegaan het maar dan raak die kant deurtjies heeltemal te klein.
Arnize - thanks weereens vir die mooi woorde - dit is lekker as n klient soos jy wat sy bakkie gebruik terugvoering gee. Geniet die trip en jou verjaarsdag is mos nou binnekort hier erens in die KAAP area
