Rev Counter not working
- Breet1989
- Town: Blantyre
- Vehicle: Hilux 3000D
- Real Name: Breet
Hi.
Can someone please help me, i have bought myself a Toyota Hilux DC 1999 3000D (5L) but the Ref Counter isnt working.
Can someone please inform me where the Pickup is located on the motor, or provide me with a Repair Manual for my Bakkie, so i can start working on the little repairs myself.
*Toyota Hilux DC 3000D (5L) 1999 - Stock Standard*
- Town: randfontein
- Vehicle: quashqai
- Real Name: mike
Re: Ref Counter not working
Agter op altenator gemerk (W)
Marked on the back of the alternator (W)mikama wrote:Agter op altenator gemerk (W)
- Breet1989
- Town: Blantyre
- Real Name: Breet
Morning All.
I have checked this morning for that wire, but I cant seem to find it! the only thing that is on my alternator is a plug with 3 wires, 1 always have power 12 -14V and the other 2 also have 12-14V if the motor is running!
Will post a picture of the alternator so you guys can have a look.
- My Alternator
- Alternator.jpg (41.61 KiB) Viewed 12045 times
- Skilpad4X4
- Town: Middelburg
- Vehicle: 2004 Toyota kzte
Re: Rev Counter not working
Hi Breet Look at the back side of the dieselpump there is a 3pin connector 2 wires comes from the side of the pump where your pick up is and the other wire comes from the solenoid if the check the resistance of the pickup it must be +_28 ohm also check revcounter it self hope you can do so
- Breet1989
- Town: Blantyre
- Real Name: Breet
thanks Skilpad!
Will check it out tommoz, i opend my dash board and checked the ref counter! everything looks good.
Let me explain what i saw, there is 3 connections on the ref counter on the blue board on the back, one is the IGN (i think its ignition), a ground (Brown) & one i have no idea but its black on the entry point it says "TM.P", i followed the wires thru the dash and it comes out of the right side close to the injector pump, both the Black (TM.P) & Ground (-) are not connected at all! will go and take a few photo's now and show you what i mean.
and i think there is a couple of parts missing as well if i studied the repair manual correctly
BRB with photo's
PS* Im in malawi - hard to find a good mechanic, if there is any
BRB with photo's
- Breet1989
- Town: Blantyre
- Real Name: Breet
HI, here is the photo's !
Hope it can help in some way
- compressed 3.jpg (31.64 KiB) Viewed 12014 times
- Compressed 2.jpg (80.44 KiB) Viewed 12014 times
- Compressed.jpg (82.96 KiB) Viewed 12014 times
- Gunta
- Real Name: Mark
Are you sure the rev counter itself is working?
- Breet1989
- Town: Blantyre
- Real Name: Breet
i dont know, if you can tel me how to test it i will.
But all seems fine with it! nothing broken on the coil.
- Gunta
- Real Name: Mark
You have to send the cluster into someone that can hook it up and check it out. You wont be able to check it yourself. I will speak to a mate of mine who is an auto elec and find out where the pick up is and let you know. But I think your problem might be with the cluster itself.
- Breet1989
- Town: Blantyre
- Real Name: Breet
oh okey thanks Gunta, but as i replied on a earlier post! there is a Black wire that is hooked part of the ref counter, but is not connected! have a look at the picture's above (black = TM.P) not connected & the Brown (Grnd) with both leads to the ref counter unit but not connected anywhere.
- Gunta
- Real Name: Mark
I will come back to you on that.
- Breet1989
- Town: Blantyre
- Real Name: Breet
Thanks for the effort
- Gunta
- Real Name: Mark
Maybe you can contact Benhur, see this topic
viewtopic.php?f=44&t=621" onclick="window.open(this.href);return false;
Also you can download manuals here
http://daemon4x4.org/portal/downloads.php" onclick="window.open(this.href);return false;
