Does anyone have the dimensions for the baseplate to fit under a 40l Engel?
I would like to make a slide, but would like the fridge to clip into the base.
Any other ideas will be appreciated.
Slider for 40 l Engel
- HiluxJunkie
- Town: Middelburg MP
- Vehicle: 2001 Hilux DC 4x4 2.7i Raider
- Real Name: Simon
- Club VHF Licence: N15
Re: Slider for 40 l Engel
I made a frame from 20x3 angle iron and used plywood to fit into frame. I carpeted the plywood board. I then drilled holes through the board and angle iron frame and put eye bolts through. I then used two rathchet straps to tie it down on frame/board. I then used some furnlock sliders and bolted the frame/board to the sliders. Then bolted the sliders down on bak. It is very sturdy and fridge does not move. Board and angle iron R100. Sliders R 265. Bolts,garpet glue and straps R100. Patio door lock to lock slide in position R45 .
- Town: Centurion
- Vehicle: Fortuner 4x4
- Real Name: Frank
Ek stem stuur fotos asb
- HiluxJunkie
- Real Name: Simon
Aag OK tog !
Hou net op NAG! Sal pics opsit van so 'n paar goed wat ek gedoen het vir die Dec trip
- Vehicle: 93 SC Hilux 4Y
- Real Name: Clinton
I made mine with furnlock sliders, angle iron and 4 thin slices of 60mm tubing to make "footholders" for the rubber feet of the Engel to fit into.
Spacing of the feet center's is 210mm width and 480mm length.
Very nice slider Clinton! Thanks for the pics.. I'll also be building one like that soon..
- Tonto
- Town: Paarl
- Vehicle: 96 Hilux 2.4 efi DC SFA, Gomad canopy,
- Real Name: Andre
Now thats what I call a good design
Thanks Clinton
Thanks Clinton
