Wheel Spacers
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Wheel Spacers
This morning received my 30mm wheel spacers from Maugene Engineering in Pretoria.
Still figuring out exactly how I am going to attach it. I am guessing that it will bolt to the hub using the existing nuts. The wheels will bolt to the spacer using bolts (not my favourite method).
Know what you don't know.
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Re: Wheel Spacers
Yip, that's how mine are done (hub to spacer, spacer to wheel). Just make sure everything is nice and tight and check them occasionally for cracks.
If I may ask, are they Alu or steel? and cost?
- Town: Springs
Re: Wheel Spacers
They are steel, and I paid R320 (excl VAT) each.
I am thinking Red Loctite for the spacer to hub?
- Toybox
- Vehicle: Hilex
Re: Wheel Spacers
I've never used because the face of the rim will prevent the nuts from coming off. Then again it can't hurt....
Also make sure that the studs you use are long enough once they're pressed into the spacer. I had a colleague lose a back wheel on route to Moz because there wasn't enough enough thread exposed for the nuts...
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
Re: Wheel Spacers
hi julle
sorry ek kllink dom maar wat se verbetering is daar
Toyota Hilux 3.0 D4D 4x4
- Town: Kathu
- Vehicle: Ford Courier 4x4
- Real Name: Rudolf
Re: Wheel Spacers
Dit lyk vir my na n netjies werk wat hulle gedoen het. Is dit moontlik dat ek dalk die nr van daardie plek kan kry wat hulle vervaardig het.
- Town: Springs
Re: Wheel Spacers
Andre, al wat hulle doen is hulle skuif die wiel 30mm verder uit sodat daai 265 bande niks skuur of skaaf nie.
Rudolf, welkom op die forum. Jy kan met Quintin praat: http://www.maugene.co.za/" onclick="window.open(this.href);return false;
- andrevt
- Town: sasolburg
- Real Name: andre
Re: Wheel Spacers
...baie dankie moet jy die wiel boute vervang............?
- Town: Kathu
- Real Name: Rudolf
Re: Wheel Spacers
Baie dankie ek het nou nie n hilux nie maar ek eet,drink en slaap 4x4 net soos al die manne op die forum.
- Blackadder
- Real Name: Thinus
- Club VHF Licence: X82
Re: Wheel Spacers
Dis seker net ek, maar ek raak altyd kriewelrig as die manne begin praat van spacers op wiele. Hoe veilig is dit regtig...???
- Blackadder
- Real Name: Thinus
Re: Wheel Spacers
Ek kannie lekker op die foto sien nie. Is daar skroefdraad gesny in die kleiner gate...???Traveler wrote:Still figuring out exactly how I am going to attach it. I am guessing that it will bolt to the hub using the existing nuts. The wheels will bolt to the spacer using bolts (not my favourite method).
- Town: Springs
Re: Wheel Spacers
Die spacer bout vas aan die hub met die gewone wielmoere. Hulle pas in die groot gate. Dan vat jy gewone wielboute en jy bout die rim aan die spacer vas. Ek sal rooi loctite gebruik op die oorspronlike moere.
Ek is nou al vir hele paar jaar aan die parte kant van die motorbedryf asook die goedkeuring van parte. En is heeltemal tevrede met die veiligheid asook betroubaarheid van hierdie spacer. Ek gaan eFfektief my offset verander van 0 tot +30. Meeste deep dish mags verander dit na +40 en +50. Op +40 sal jou wielbearings se lewensverwagting met so 2% verminder word.
Ps. Ek gaan net die spacers gebruik as die 265's skuur. As nie, dan verkoop. Ek hulle. Ek het eerder die spacers beskikbaar as om hulle te moet bestel en dan twee weke rond te ry met bande wat heeltyd skuur.
- Blackadder
- Real Name: Thinus
Re: Wheel Spacers
Aaaahh....Jy glo aan daai hele "Voorsorg is beter as nasorg" ding...???
Very clever...
Very clever...
- Town: Springs
Re: Wheel Spacers
Hier is twee foto's wat wys hoe die spacer aan 'n rim vasbout.
Dit gee die perspektief vanaf die binnekant, asook vanaf die buitekant.
- Blackadder
- Real Name: Thinus
Re: Wheel Spacers
Oh ok...dit maak meer sin. So jy het presies die selfde boute wat die wiel vas hou...Ag nee wat...dit lyk veilig genoeg...
- Town: Springs
Re: Wheel Spacers
En as die 265's nie skuur nie dan sit ek hulle op die mark, of ek sit hulle op die rak.
- Town: Springs
Re: Wheel Spacers
The spacers being attached to the hub on Saturday morning.
- IMG00040-20101030-0813.jpg (21.46 KiB) Viewed 2375 times
