brake saga
lukestrugnell
Town: JHB
Vehicle: Fortuner
Real Name: Luke
Club VHF Licence: M18
brake saga
Post by lukestrugnell »
Right so a mechanic friend of mine was here the last weekend and I thought we sorted out my brakes.
After adjusting rear and bleading the system they were feeling great.
Got in today and they pap again!
Does this mean there is an air leak somewhere? The system is no leaking fluid so am a bit confused.
Help!!!!
Cookie Monster
Town: Port Elizabeth
Real Name: Justin
Re: brake saga
Post by Cookie Monster »
Hi Luke maybe the master cylinder is leaking internally
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Re: brake saga
Post by SYRON CONVERSIONS »
Climb into your vehicle, drivers side, put your foot on the brake pedal, make sure the vehicle is in neutral, start the engine, does your foot go down with the pedal?
Do you have toe board clearance on the brake pedal?
When you adjusted the brakes, was the handbrake release off all the way, which wheel did your friend bleed first if you are sitting in the drivers position?
Did you check the rear brake wheel cylinders if they were leaking, sometimes the front brake calipers can also leak.
simoan
Scooter
Town: JHB
Real Name: Scott
Re: brake saga
Post by Scooter »
SYRON CONVERSIONS wrote:Climb into your vehicle, drivers side, put your foot on the brake pedal, make sure the vehicle is in neutral, start the engine, does your foot go down with the pedal?
I concur with Simon.
Did you overhaul anything?
If you pump the brakes without the car running do they get harder? With them hard do as Simon suggested, your foot should only go down slightly, if it goes all the way, your master cylinder is most probably the cause.
How is the seal between the master cylinder and the brake booster?
Make sure all your bleed nipples are secure!
lukestrugnell
Town: JHB
Vehicle: Fortuner
Real Name: Luke
Re: brake saga
Ok I have just blead the brakes again and feeling good, all the nipples are tight now and if it happens again it must be master cylinder right?
Before i did what you said: When I start the pedal does go down a bit but not completely to the floor.
Nope didnt overhaul anything just adjusted rear and put new pads on front and blead the system.
What about the Load proportion valve do you need to bleed this? could that be the leak? No obvious signs of fluid leaks there?
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Re: brake saga
If the brake pedal did not go down slightly when you started the engine, this would indicate that you have a problem with the vacumn booster, however it seems to be working fine, sometimes the diaphram inside the booster can leak, the load proportion valve basically allows more braking when the vehicle is loaded, if it was leaking fluid you would see it, but I do not think this is your problem.
Check for a leak, remove the rear drums first.
Then check the front rubber hoses.
simoan
Charlie Brown
Town: Alberton
Vehicle: 2.2 SFC Hi Lux
Real Name: Charles Pearce
Re: brake saga
Post by Charlie Brown »
Also look at viewtopic.php?f=44&t=746, a post by BenHurBull.
Great information
Charlie Brown
Re: brake saga
Post by CasKru »
HEy boys, I saw some, what I believe to be, good news.
Check this link
http://72.34.32.141/~snakerac/product_i ... d109d32b3a
It seems they are createing a bolt-on disc brake kit for a SFA's rear brakes :)
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Re: brake saga
Yes you are correct, I saw this a few years back, have they finally got it correct.
simoan
Re: brake saga
Post by CasKru »
No idea but I will surely investigate it :mrgreen: :mrgreen: :mrgreen:
SYRON CONVERSIONS
Town: Tamboekieland
Vehicle: SFA HILUX
Real Name: SIMON
Re: brake saga
Just make sure that you specify which axle your vehicle has in it, maybe their axles are different
simoan
Re: brake saga
Post by CasKru »
Thanks for the heads up. Will do.
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Re: brake saga
Post by BenHur »
Cassie
Not to brake up (pun intended) your air castles again, but again forget about it fitting your van's gearmax diff, the chances are very slim. In any case remember Linda stops working end of march en dan is jy ok 'n armgat soos ek. :twisted: :twisted: :twisted: I don't think a brake kit at R11,550 plus postage is going to sell like hotcakes here in SA.
Re: brake saga
Post by CasKru »
Hey Bennie,
Wat meen jy wanneer Linda ophou werk gaan ek armgat wees. Ek kan net dan nogsteeds een wees. :(
Nee ag ek kyk maar net so na die dinge wat moontlik is vir as ek dalk perongeluk eendag so ou gelukkie slaan met 'n skip wat dalk op die regte plek anker enoll.
Sal maar op die ou einde van die dag 'n anker saam met my in die bakkie vat en as ek nie betayds gaan kan stop nie, hom ook maar uitgooi! :)
Nardus
Vehicle: Hilux 1989 4x4 Dc
Real Name: Jaco
Club VHF Licence: XR98
Re: brake saga
Post by Nardus »
Wow what a web site i drive a Hilux 1989 DC with a Ford v6 motor my problem is i replaced the rear brake shoes they also bond the linings and i replace both the slave cylinders and infront replace all the seals on the calipers it took 2 months to bleed the brakes no time to bleed next day weak brakes almost no hand brake there are no leaks on the system please help i am looking for a diagram on how and where al the springs hook onto on the rear brake drums to check mine thank you
Scorpion
Town: Emmarentia
Vehicle: 1988 Hilux 4x4 D/C with more attitude than Mike Tyson
Real Name: Johann
Re: brake saga
Post by Scorpion »
Welkom, Jaco! Iemand hier sal jou kan help - dit belowe ek. Vra vir Bennie om dit uit te sorteer. Hy doen verniet werk aan Hilux'e, solank jy dit aan hom in jou testament bemaak... :shock: :twisted: :twisted:
1978 Land Cruiser HJ45
ToyX4
Town: Ottosdal
Vehicle: Rocky's
Real Name: Riaan
Re: brake saga
Post by ToyX4 »
Scorpion wrote:Welkom, Jaco! Iemand hier sal jou kan help - dit belowe ek. Vra vir Bennie om dit uit te sorteer. Hy doen verniet werk aan Hilux'e, solank jy dit aan hom in jou testament bemaak... :shock: :twisted: :twisted:
En hy moet ook jou Hilux op minstens 2 trails vat, net om sy werk te fine tune :twisted: :twisted:
Welkom Jaco. :!: :!:
freeflyd
Vehicle: 89 2.2 Hilux DC
Real Name: Dawie du Plessis
Re: brake saga
Post by freeflyd »
I had huge problems with brakes on my Hilux. I even took it to Toyota to try and sort it out, but they only made it worse. I got it to be OK, or so I thought, and then...
Eventually I found this guy:
Paul Labuschange
Menlyn Brake and Clutch
012 998 7795
374 Roslyn Rd
Waterkloof Glen
No other person will ever be allowed to touch my brakes! This guy was a wizzard!
legend35
Vehicle: Hilux 2700i
Club VHF Licence: HC262
Re: brake saga
Post by legend35 »
Luke,step on the brake pedal til it locks.Then release a little bit and press down slowly .if it goes down more tan the first time ,then it is the master silinder seals that bypass.if you step on it hard and it still goes down ,check for torn seals on master and slave silinders and leaks on all the silinders.
legend35
Re: brake saga
Post by legend35 »
Welkom to the forum Jaco.stick around,somebody will help you on your problem.
Scooter
Town: JHB
Real Name: Scott
Re: brake saga
Post by Scooter »
Jaco, pick a rear drum spring set up........
RN36, RN46 models.pdf
(94.49 KiB) Downloaded 108 times
YN63 model.pdf
(147.36 KiB) Downloaded 82 times
YN 65, YN 67 models.pdf
(86.32 KiB) Downloaded 125 times
Nardus
Real Name: Jaco
Re: brake saga
Post by Nardus »
Groete aan almal. Net n vraag as jou brake booster intern lek sal die vakuum pyp na die enjin die rem vloeistof deur die enjin suig en die voertuig sal begin rook nie waar of sal die een rigting valve dit verhoed ?
