leaf spring quick test
- Musselcracker
- Vehicle: 1989 SFA D/C
Does anyone know of a quick home test you can do on to check your leaf springs?
I have just bought a bakkie and the leaf springs are looking a little tired... or what I think from my totally novice opinion. Is there any little trick I can do to check them?
Perhaps I shall post some photos on here to have some professional opinons!
- Maddoglips
- Town: P.E.
- Real Name: Zane
Re: leaf spring quick test
Chris
I don't know of any physical test you'll be able to do at home, but if they appear to have a "W" shape to them, they are worn and tired.
In other words if it appears that the centre portion by the axle is pushing higher then the sides of the springs, they are worn.
Pics will always help with predictions
Zane
Zane
- Musselcracker
thanks Zane
come to think of it they may just be the case....
i will nip out now at tea time and take some pics with the cellphone quick
- Musselcracker
here with the pics
- Maddoglips
- Town: P.E.
- Real Name: Zane
Hi M8
Looking at those pics, I'd have to say they are tired
But I drove for a while on mine like that as it can't do damage so there's no need to rush to replace if you don't have the means to replace at the mo.
If you are thinking of replacing with another brand of springs, I would recommend Mikem, as I fitted these with a 50mm lift, and what a difference, even Swambo was impressed as we could leave the kidney belts behind when going out, oh and there service is brilliant.
Cheers Zane
Cheers Zane
- Musselcracker
could i not just get the springs re tensioned and perhaps add one more?
- Maddoglips
- Town: P.E.
- Real Name: Zane
You could retension, but as alot of guys will tell you, they don't tend to last.
With in a few months the springs have returned to the old position, aswell, the cost of retensioning is so close to buying new, it doesn't make sense.
I was quoted roughly 800 for retensioning and 950 for new blades from Springwell here in PE, don't know if they have a branch near you to find out.
For the bit extra, I went to Mikem like said before, and now have piece of mind.
Just remeber, you gotta go with what suites you and your needs, do abit of phoning around and see what you come up with.
Zane
Zane
- Selous
- Vehicle: 95 Toyota Hilux D/C
- Real Name: Paul
Hi Zane
Sorry to poach on this thread but my leaf springs are looking almost the same.
Did you pay R950 for a total set??
By the way I sent my motor for a recon and am back online
- Maddoglips
- Town: P.E.
- Real Name: Zane
Paul Glad to hear M8
The cost quoted was per spring pack so you looking at 4k roughly for standard pirate built springs with a 12 month warranty.
This is with out labour,buying bushes and shackles either, don't have to do shackles every time, just depends on condition of yours.
Zane
Zane
- Rebel 4x4
- Town: Port Elizabeth
- Real Name: Thomas
Not worth retension....
My uncle had his done 2 years ago, first trip to Baviaans and it "sagged" again, also from the Springwell crowd.
retension = no
Extra blade = no
Been there got the t-shirt, only a temp fix :!:
Extra blade = no
- Danman
- Real Name: Danie
Hi Chris,
Also when replacing the front springs look at the state of the saddle.
Mine(sorry hopalong's) saddles are frowning adding to the w effect.
m2cw
m2cw
- Musselcracker
Thanks guys
I need some phoning around here is about what I came up with for just leaf springs
Old man EMU: Hillcrest durban = approx R10 000
Mikem = Approx R 9000
Iron man = Quoted R11 300 (including shocks)
Pretty much just FYI... I think they will last a bit longer, and now I know what to keep an eye on!
How flat are those front springs suppose to be?
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Hi Chris.
If you are a diy man it you can do it your selfe.
Done mine in middle may. Drive 16 km a trip to
Home on a bad gravel road. Did the george's valley 4x4
As we'll and I'm happy no sagging yet.
See treat: viewtopic.php?f=92&t=12176" onclick="window.open(this.href);return false;
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Forgot to metion about the friction pads. Make sure they are still in good condition
- Musselcracker
friction pads..??
where are those
where are those
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Once you strip your leaves apart you will see a black round patch which
Secure into the a small hole of the leave neaby the end. The compoud looks like a type of break shoe compound or type of graphide.
- Town: Gordons Bay
- Vehicle: Looking for a Hilux
- Real Name: Mark
I can only offer my rusty, sagged and scrap springs, I have decided to go with Mikem suspension, really like the idea of greasable shackles and pins. Hoping to fit next week and will let know how they ride.
Matshwane......you Legend!!!!
1989 Toyota Hilux 2200
450 000km and still keeps going strong!
