Questions for Hoppy On a newer model Lux engine conversion
- Spartan
- Town: Vanderbijlpark
Allan
I see you mention that the Lux with the V8 conversion on sale has ABS brakes and air-bags.
What did you do computer-wise with the ABS and air-bags or does the air-bags, ABS, timing and fuel work from different ECU's so that you could use a after-market ECU to do the timing and fuel
MOBILITATE VINCERE
Spartan
Spartan
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: Questions for Hoppy On a newer model Lux engine conversi
The engine and immobilizer unit shares one harness and ecu, cutting it out and replacing it with an aftermarket unit did not affect anny other electronics
- Spartan
Thanks Allan
MOBILITATE VINCERE
Spartan
Spartan
- Hoppy
I prefer the lexus in an ifs, you can safely use the power without worying about handling, stability and stopping.
The mechanical noise levels are much lower than the 2.7
The suspension raised 15mm after the conversion, so the motor is lighter
We used the perfect power system, it was a female dog to tune, but never missed a beat in 3 years, says a lot for a system.
And the tuner...says a lot for a system
- Spartan
What ECU did you use, OK OK ek vra net
MOBILITATE VINCERE
Spartan
Spartan
Wil jy nou die doktor word?Spartan wrote:What ECU did you use, OK OK ek vra net
- Spartan
HEY HEYOOOOMS wrote:Wil jy nou die doktor word?
MOBILITATE VINCERE
Spartan
Spartan
- Hoppy
Perfect Power
Beware, it is dificult to tune, but very stable
- Spartan
Local or importHoppy wrote:Perfect Power
MOBILITATE VINCERE
Spartan
Spartan
- Town: JHB
- Real Name: Derrick
Import and in that case a Apexi power FC is the sh*t you want running. Reads all the sensors including knock, tps, maf ....ect. it's plug and play and you can tune it with the hand controller. Set you back around R 8000 but I would say it's worth it. Add up all the computers you have to buy here to run the vvt and and and and when you look again you dont have space left in your load bin because of all the computers Add up the bang shoot and whats the rand total ?
When I upgrade it will be a power FC, same size as my standard ecu box
- Power FC
- S_6054[1].jpg (9.24 KiB) Viewed 1977 times
V8 SOLID
- Spartan
Ok koop jy nou een en dan vertel jy ons hoe werk dit maar jy mag nie jok nie al wat ek van hom like is dat dit die knock sensors kan maak werkDemon wrote:Import and in that case a Apexi power FC is the sh*t you want running. Reads all the sensors including knock, tps, maf ....ect. it's plug and play and you can tune it with the hand controller. Set you back around R 8000 but I would say it's worth it. Add up all the computers you have to buy here to run the vvt and and and and when you look again you dont have space left in your load bin because of all the computers Add up the bang shoot and whats the rand total ?
MOBILITATE VINCERE
Spartan
Spartan
- Town: JHB
Guys here in JHB that say they can map the Apexi but ya not to sure, will have to see and maybe it's a case of
V8 SOLID
