Did I find a lexus motor for my KZTE?
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
I have found a lexus motor with bellhousing & flywheel for my KZTE in Gesiena near Pretoria from Fana van Zyl.
fanavanzyl@gmail.com 08free75two1six55
It will be bench tested, new rear oilseal, new cambelt, new plugs, injectors cleaned, and a spitronic management system. all for R20500.00,
I will only have 4 wires to connect to the vehicle as I was told.
How does that sound? :wth:
Re: Found a lexus motor for my KZTE
Hardware...
Price...
Easiest conversion ever...
What about Radiator, etc...
Price...
If you talking about the 2000 and on model I would stay with the KZ radiator. I had the 5L engine (real rubbish)and bought the kz radiator to fit my UZ Worked no problem. The only differance in the two were the bottom tanks.
- Bushwacker
- Real Name: Piet
Yes, I use the existing KZ radiator with 2x 14" fans in the front.
The bell housing & flywheel is R6000.
the engin is R6500.
Spitronic is R3500.
I know the 8 sparkplugs are expensive too.
The oil seal & cambelt is genuine parts.
The rest I'm not sure of, Labour etc. But the fact that the engin is tested is cool.
PS. it includes oil & filter
the engin is R6500.
Spitronic is R3500.
- Rian
- Vehicle: Ford Courier - Vw Caddy - Isuzu kb250 - Mazda 250td/i - Mercedes Benz C230 Compressor sport
- Real Name: Rian
BMW 740I V8 RADIATOR 40MM CORE :shifty:
Yea..The BMW radiator is an option. The adventage of the KZ radiator is it is there in the first place and there is no mod required. The BMW fans are really worth looking at, there is a three speed available and it is of very nice quality. If you go that route you can set up the first speed for the A/C and use the other two for engine cooling. But they do cost around R2200
- Rian
- Real Name: Rian
If you don't want to battel with overheating its the way to go! I fitted one in my Hilux with 2 x 14" fans at the back of the radiator & believe me no overheating problems not even while 4x4 ing in the mud on a hot summers day.
I dont do 4x4 so wouldnt know how that would affect things but ill tell you this, I pull a trailer that weighs one ton, load three onto it. Half to three quater ton on the back of the hilux and pull it up the passes in Nelspruit with not a sign of overheating. Personal preferance really
- Bushwacker
- Real Name: Piet
Is the spitronic the right way to go?
It will most probably be the easiest out of the box installation as they make an installation kit specific for the Lexus with all the tooties included and some extra bells and wistles but I believe in the reliability of the Dicktator system and until I see otherwise from Spittronics wrt reliability I will continue to recommend Dicktator which has been running the same stable version of the ECU for a few years already.Bushwacker wrote:Is the spitronic the right way to go?
- Bushwacker
- Real Name: Piet
Re: Did I find a lexus motor for my KZTE?
I received this email from Fana:-
Die fly wheel en bellhousing kos R6000.00 en ja ek weet daar is n ander firma wat R4000.00vra soos iemand al reeds op die forum genoem het maar as hulle huis werk gedoen was sou hulle agter gekom het daai housing kan net n 235 mm clutch se flywheel vat en nie 260 soos myne nie .Dan die engine kos R6500.00 en ja daar is seker ook ouens goedkoper maar geen besigheid verkoop mos nou n ding vir wat hy kos nie .Laaste is die oprigg van die engine vir R8000.00 wat .insluit n management [geinstalleer} nuwe rearmain olieseelen cambelt {agente parte } nuwe plugs ,olie en filter asook injectors skoon gemaak en fuelpressure getoets en engine dan ge start en gehardloop .Jy kry dus n engine wat klaar gestart het en reg loop om te ry en met net drie drade om te konekteer en al die gesukkel uit ge sort { en glo my dit klink maklik maar vra maar ouens wat dit al n paarkeer gedoen het jy sukkel partykeer jou gat af }. My besigheid se.naam is ADAPTOR EN CONVERSION CENTRE . Ek is gelee in Ella str 588 Gezina Pta . Ek doen die soort goed al baie .jare en gebruik moderne tegnologie om die goed temaak .Elke conversion se mate en gate se. koordienate meet ek op die drie demensionele meetmasjien by WNNR en boor dan die .gate op n CNC .MASJIEN .Ek sny ook spline shafts e.n doen ally welding .verder cast ek my eie housings vir verskeie conversions .In back wheel drive ..gebruik is daar nie n engine en ratkas wat ek nie kan match nie {glo maar ek het al snaakse goed gematch ]Jille is welkom .om tebel vir inligting of raad op 0837521655 enige tyd van 06H00 in die oggend tot 22H00 saans Maandag tot Saterdag
.....wat.Hi Fana
.....wat.Hi Fana
OK, so do you want me to proof read it and fix all the spelling and grammatical mistakes and then send it back to you?
- Bushwacker
- Real Name: Piet
:wth:
This is serijas...
This is serijas...
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Almost a year later I've had no problems with my Spitronics. As long as the installation was done properly you shouldn't have a problem... I've seen Fana's guys soldering and shrink wrapping looms before so I wouldn't worry....
Piet
Ja ek weet Fana like meer van manual as auto maar het jy al 'n auto conversion oorweeg, ek meen daai 15-20Hp op topend is regtig die moeitewerd om te verloor vir al die gerief en gemak van 'n autobox. Jy bou mos nie 'n dgarster nie.
EK sal nie eers dink om 'n Lexus op 'n manual te hardloop nie, V8s en autoboxe is soos pap en boerewors. Ja jy kan jou pap seker met like it lean viennas ook eet en niks cholestrol kry nie, maar niks beat pap en boerewors nie:thumbup:
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Piet sal jy moet `n body lift doen om die Lexus engine in tekry? En diff ratio gaan jy dit ook verander of hou jy jou bestaande gearbox en diff op die KZTE?
- Bushwacker
- Real Name: Piet
Bennie ek hou nie van auto nie. Dis al.BenHur wrote:Piet
- Bushwacker
- Real Name: Piet
Gert, die ratkas bly, ek gaan 'n sfa conversion doen,en die as 35mm vorentoe skuif. dit hoort genoeg te wees vir die 33" maxxis bande. As dit nie is nie, sal ek die body met 50mm lig.Gertc wrote:Piet sal jy moet `n body lift doen om die Lexus engine in tekry? En diff ratio gaan jy dit ook verander of hou jy jou bestaande gearbox en diff op die KZTE?
Die diff ratios moet verander. die Diesels s'n is baie anders as die van petrol.
Ek het 'n stel '86 diffs hier op 'n plaas gekry vir R7000.00.
Volgens Fana kan ek daardie diffs se ratios net so los
- Rian
- Real Name: Rian
Sorry I missed on this descussion.
2 questions ?
How was the engine "bench tested" ??
How was the injectors "cleaned" ??
2 questions ?
- Bushwacker
- Real Name: Piet
You will have to contact Fana on 0837521655 or fanavanzyl@gmail.com for the answers, I havn't bought the engin yet
- Rian
- Real Name: Rian
Very interesting?
Would you not like to know that
I gues I am just Annoying sorry asking.
Cheers
Cheers
- Town: JHB
- Real Name: Derrick
Are you using the kzte tank for fuel? watch out for rust build up
V8 SOLID
- Rian
- Real Name: Rian
Good point!
Daar is altyd water in diesel
- Town: JHB
There you are Mr Rian
Not water mate more a case of the tank being made of steel and petrol chows the surface and desiel not
V8 SOLID
- Town: JHB
I think toyota changed to plastic in the later models. No harm in taking a look at the tank on this mod. We dont want the guy to go and change his fuel filter every week now do we
V8 SOLID
- Rian
- Real Name: Rian
Dis waar ek bly ma stil as ek nie seker is van iets nie. Wil nie my naam met 'n sleeper slaan nie.
- Town: pretoria
- Vehicle: 911 Carreara MB CL 500 MB 500SEC MB 450 SLC CHRYSLER CROSSFIRE CONVERTABLE SFA HILEX JEEP 5.2 V8 FORD RANGER LEXUS
- Real Name: Fana
.Rian jy maak n injector skoon..deur ultrasonic cleaning of deur die petrol in reverse deur hom te blaas
- Bushwacker
- Real Name: Piet
Never crossed my mind. It could cause serijas problems :wth:Demon wrote:Are you using the kzte tank for fuel? watch out for rust build up
- Rian
- Real Name: Rian
Fana
Nee ek maak nie die goed skoon nie het nie 'n idee hoe nie, wou net weet hoe doen jy dit.
Ek sit nuwes in.
Ek sit nuwes in.
Of jy neek injecter cleaner in die fuel rail en crank die engineconversion man wrote:.Rian jy maak n injector skoon..deur ultrasonic cleaning of deur die petrol in reverse deur hom te blaas
Piet ek weet nie so mooi van daai tank en petrol vreet storie op Hiluxe nie, ek weet van paar ouens wat hulle OE diesels vervang het met pertol engines sonder dat hulle nuwe tanks ingesit het.
Eric is Shorty se tank gechange of nie?
Rian maar ek weet nie waaroor worry jy oor vuil injectors nie jou aftermarket system kan in elk geval nie die engine behoorlik beheer nie so dit sal nie saak maak of jou injectors vuil is nie nie, isntalleer eerder 'n spraygun agter you throttle body en spray petrol af die keel dit werk ook mosRian wrote:Oke :Geek:
- Rian
- Real Name: Rian
Ou Ben
Ek worry nie veel daarooor nie want die brandstof vervaardigers gooi in elk geval ook produkte in om die goed skoon te hou.
Die spray gun se nozzle gaan dalk te groot wees
Man ja ek like die spraygun idee, jy koppel die die throttle kabel op die sparaygun se trigger en koppel 'n servo op die stelskroef wat die spraypatern size stel en voila 'n aftermarket Fuel Stratified Injection system vir jou VolkswagenRian wrote:Ou Ben
Sal dit op die Interceptor werk? Moet dit 'n Toyota spraygun wees? Of miskien Ford?
- Scorpion
- Town: Emmarentia
- Real Name: Johann
Net die beste vir jou Ewald - Chana!
1978 Land Cruiser HJ45
Dit moet 'n PTA Tool Centre ene wees want as jy die ene by addendorf koop is hy inferior quality, alhoewel hulle uit die selle fabriek in China kom verlaag die kwaliteit aansienlik met 'n addendorf sticker opV8 Interceptor wrote:Sal dit op die Interceptor werk? Moet dit 'n Toyota spraygun wees? Of miskien Ford?
Nope! Nog 100% standaard diesel/petrol conversion!BenHur wrote:Piet ek weet nie so mooi van daai tank en petrol vreet storie op Hiluxe nie, ek weet van paar ouens wat hulle OE diesels vervang het met pertol engines sonder dat hulle nuwe tanks ingesit het.
- Bushwacker
- Real Name: Piet
Thanx Eric, so the tank stays. What about the fuelpump.
What type will suit best?
The petrol type...Bushwacker wrote:Thanx Eric, so the tank stays. What about the fuelpump.
- Bushwacker
- Real Name: Piet
EWALD!!!whatshiet!!
- Town: JHB
Chat to Redhummer he had a problem with his 5L to v8 mod. If it were me i would check what tank it is. You want your truck to run for 10 years and not six months. Slam it if you like no worry
V8 SOLID
2.5 Kombi pomp is die gewildste keuse.
Demon
As Eric Says his little shortwheel base has been running with a petrol to diesel conversion for a few years already and no tank issues yet
Demon
- Bushwacker
- Real Name: Piet
Am I missing something hereDemon wrote:All righty then dont bother with the tank dude
- Gertc
Piet ek het gewonder of dit nie beter gaan wees om `n 4 x 2 tekoop en dan in `n 4 x 4 te verander nie. Jy gaan in elk geval nie jou geld trug kry nie. en om `n duur 4 x 4 heeltemal te strip en ander voor en agter diff in tesit en dan nog die engine ook teruil kan jy net sowel n 4 x 2 body gebruik.
Wat gaan jy maak omtrend jou ABS? kan dit maak pas word op SFA? of gaan jy dit verloor?
- Bushwacker
- Real Name: Piet
Gert Ek wou die KZ verkoop, maar kon nie my prys kry nie. Ek gaan probeer om die ABS te red as dit moontlik is. Die ABS werk nie op grondpad nie, en waar ek vandaan kom gaan al die paaie uiteindelik grond word
Piet,
Daar op Piet Retief is daar 'n auto electrician, Hansie, hy het sy 2.7 'n lexus hart gegee, met 33 duim bande, die hele werke.
Ek verstaan sy winkel is reg langs 'n bande plek?
as jy nie regkom nie, kan ek dalk met bietjie moeite sy nommer in die hande kry.
On second thoughts, Johan Terblance van Pongola het 'n Lexus in 'n sFA ingebou.
- Bushwacker
- Real Name: Piet
Dankie Thabo, as jy die man se info kan kry sal ek bly wees . Ek was juis vandag by Johan se shop in Pongola, die Hilux was toe nie daar nie. Hy het probleme met sy Geotek sisteem.
3 Words and a number....Holley 4 barrel carburettor...
So gaan jy daai holley van jou smous as ons die intercepter EFI?V8 Interceptor wrote:3 Words and a number....Holley 4 barrel carburettor...
