Problems with Hilux Vigo
Introduce yourself and Meet the rest of the crowd
theresa
Town: Port of Spain
Vehicle: Toyota Hilux Vigo
Real Name: Theresa
Post by theresa »
Hi Members,
I am new to this Forum and I am seeking help. My family purchase a new Hilux Vigo a year ago and have been having problems. The dealer changed the Turbo thus far but the problem is still there. Here is the problem, white smoke comes from the exhaust when you accelerate and them come to a stop e.g at a traffic light. In addition to this there is a black water like substance runs out when the vehicle is parked. If the substance is left on the tiled area, it becomes gummy the next day. The vehicle is not burning oil and performs well. The dealer is trying to tell us that there is nothing wrong but we find it very difficult to accept. Member suggestions and advice will be appreciated. We live in the Caribbean.
Re: Problems with Hilux Vigo
Post by pietpetoors »
Welcome to the forum Theresa
Does it use water?
Normally white smoke = engine oil burning.
If driving short distances the black water might be condensation and because the inside of the exhaust is black due to diesel fumes the water becomes black. But if you drove a far distance and water is still coming out from the back it is not normal.
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
pietpetoors wrote: Thu Jun 22, 2017 12:35 pm Welcome to the forum Theresa
Does it use water?
Thank you for responding. We have been monitoring that and it does not need water.
GRWLR ZN
Town: Richards Bay
Post by GRWLR ZN »
Good day Theresa,
Welcome to the forum.
I assume that this is a new vehicle? All new vehichle's exhaust systems are fitted with catalytic converters.
The function of these are to convert the harmful exhaust gasses into water vapour and less harmful gasses.
Like Pieter said, if you travel mostly short distances it is normal to have some water present, but even with a catalytic converter fitted it should go awayif you travel longer distances.
Massive puffs, or a constant column of white smoke could point to a more serious problem. Oil burns white,however it will have a blue-ish to grey-ish tinge to it and will smell quite bad.
A bit of "steam-ish" white smoke is not to worry about.
Very hot and humid weather conditions can also contribute water vapour build up in the exhaust, especially when the vehicle is parked overnight.
Welcome Theresa! :thumbup:
I'm not a diesel head, but if it's water it can only come from four places - window washer, air conditioner condensation, leaking coolant or condensation from the exhaust due to ambient moisture over night or due to leaking coolant passing through the motor. From what you describe as it bring "gummy", neither of those possibilities seem likely unless it's coming from the cat and I'm wondering if it's not possibly diesel fuel related. :think:
Where in relation to the vehicle dies this discharge occur? Engine area? Centre or rear of the vehicle? Have you checked from underneath to see where it's coming from?
What is the mileage on the vehicle? Black smoke is normally from excessive fuel and white smoke is from oil - it could well be that there is a turbo problem again or even a problem with the valve stem seals. You say it's not burning oil, but how often do you need to top it up?
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
GRWLR ZN wrote: Thu Jun 22, 2017 3:42 pm Good day Theresa,
Thank you for your response. To answer your question, it is a new vehicle. The present mileage is 16,000 km and the problems has been there from the start. The vehicle smokes constantly when it is under load like going uphill, no loss of power, no overheating, never had to top up oil.
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
Mud Dog wrote: Thu Jun 22, 2017 3:48 pm Welcome Theresa! :thumbup:
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
Thank you for you response. The discharge comes from the exhaust. The vehicle's mileage is 16,000 km and the problem has been there from the start. We never had to top up with oil. Today I had to go to a client who lives on a hill and the vehicle smoked all the way up, no loss of power, no over heating.
GRWLR ZN
Town: Richards Bay
Post by GRWLR ZN »
Do you fill up at the same filling station every time?
Have you ever had to run with the fuel tank very low for a while?
Obelix and Dogmatix
Town: ROODEPOORT
Real Name: Quentin
Post by Obelix and Dogmatix »
Okay, shot in the dark but is the diesel pump properly calibrated? if it is over fuelling it could also cause a lot of smoke. may be worth a check.
And good Luck
God made man before
woman so as to give him time
to think of an answer
for her first question
Post by Mars »
I think the water out the exhaust is due to condensation. If it does not use any oil at all then it is a diesel fuelling issue in all likelihood.
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
Obelix and Dogmatix wrote: Fri Jun 23, 2017 8:47 am Okay, shot in the dark but is the diesel pump properly calibrated? if it is over fuelling it could also cause a lot of smoke. may be worth a check.
And good Luck
Thanks, I will have the calibration of the fuel pump checked. If the calibration is out, will the smoke be white?
GRWLR ZN
Town: Richards Bay
Post by GRWLR ZN »
theresa wrote: Fri Jun 23, 2017 12:44 pm
And good Luck
No, overfueling will cause black smoke. It is highly unlikely that the calibration will be out after 16000kms.
The only time that there would be any "white smoke" from fuel is when there is compression without combustion.That is then the diesel/petrol vapour coming from the exhaust, but your vehicle runs fine.
Is it A LOT of smoke or steam, or wisps and twisps?
Another shot in the dark could be water in the fuel itself, but you say engine performance is fine. None-the-less..
Check the diesel water seperator and drain it. To be entirely certain that there is no water in the diesel, drain out about 500ml into a coke bottle or similar, seal it and let stand over night. if there is water present the next day, have all the fuel drained and use a different filling station.
If there is no water present in the diesel at all and there is no other signs of other fluid use, perhaps have the dealer double check the catalytic converter. A by product of its function is water vapour, maybe it is over catalysing. It is possible that there might be an additive to the fuel there that is causing the over reaction, if that is the problem.
GRWLR ZN
Town: Richards Bay
Post by GRWLR ZN »
Let me just be clear, when i say drain out a bit of fuel, it must be from the fuel tank and not the filter or water seperator.
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
GRWLR ZN wrote: Fri Jun 23, 2017 2:40 pm Let me just be clear, when i say drain out a bit of fuel, it must be from the fuel tank and not the filter or water seperator.
Thanks for all the information and advice. I will have all these things checked out over the weekend and I will get back to you with the findings.
theresa
Town: Port of Spain
Real Name: Theresa
Post by theresa »
Hi guys,
Thanks to all who participated in the discussions concerning my Hilux Vigo and the smoking problem. You were all very helpful. Obelix and dogmatix suggested that I check the calibration of the fuel pump. Well the dealer calibrated the fuel pump and the injectors and the problem is gone. They were not taking me seriously until I made a video showing the vehicle going up a hill and that did it. The vehicle is at 17,000 KM so I do not know whether the dealer received it like that or whether someone tampered with it. Thanks again to all. :celebrate:
Happy to hear that it's sorted now. Happy motoring. :winkx:
Post by Mars »
Glad you have it sorted. Thank you for the feedback
Return to “Meet the People”
