cresida gli6 swap 1uz
sichichoo
Town: gauteng
Vehicle: 1985 cressida gli6 2.0
Post by sichichoo »
need help installing a 1uz into gli6 cressida any help in sa nd hw much
sichichoo
Town: gauteng
Re: cresida gli6 swap 1uz
Post by sichichoo »
wt will i need to do it
Welcome aboard George! :thumbup:
If you get a 1UZ complete with auto box and management system, you already have most of what you will need. You will obviously have to change engine mounting positions (perhaps even the mounts themselves), change the length of the drive-shaft, do some exhaust and air intake modification (if you're doing it yourself then you'll need suitable piping and bends for both). You will also need a HP fuel pump if the one you have isn't suitable (but it should be). Radiator should also be upgraded (Lexus does not like to overheat) so you will need radiator hosing and clamps as well.
I'm sure there's a whole lot of little extra bits & bobs that you will need for the electricals, but the guys that have done these conversions can advise you better.
sichichoo
Town: gauteng
Post by sichichoo »
thanx Mud Dog!!!!
please explain more about the " exhaust and air intake modification" meaning I cant use the one already in the car?
and which radiator to buy and will it fit in a Gli6 cressy
You should be able to use your standard exhaust end and airbox ..... you will just have to do some redirecting of both. Just have a look at the various "Lexus conversion" threads here (do a search) and see what radiator options there are. You could also just ask 'Silverton radiators' for their advice and even ask them to match (and fit, if you like) one for you.
sichichoo
Town: gauteng
Post by sichichoo »
Can u please hala me the number fr silverton radiators soo I can give them a buzz... I wonder abt the diff ratios and the fuel linings o that has to be redone again.. most of the guys in the forum have only done it on Hilux's haven't found any 1 who dd it on a cressy
Big D
Vehicle: SFA Hilux 2.2 BFi
Real Name: Deon
Post by Big D »
Huh? Can you retype that in English please? nd hw? wt? Hala? fr? abt?
I think you could Google: "Silverton radiators" and get the number??
O yes and welcome to the HILUX forum. Here you will find info on any HILUX that you are looking for. Guys will happily assist with any HILUX questions. Here we are all part of the HILUX family. :think:
sichichoo
Town: gauteng
Post by sichichoo »
any cressida forum u knw of fr south africa
Cres
Town: JHB
Vehicle: Cressida 2JZ , Lexus IS200 Sport , Hilux s/c 3.0D4D 4x4, Hilux d/c SFA 7MGTE
Post by Cres »
Hello
There is no sa forum what do you want to know? im not to bad on these cars
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Post by Hoppy »
I supply 1uz motors and boxes complete with engine and gearbox management systems, we start and tune them, you can fit it and conect a few marked wires and drive.
The gli 6 gear ratio will work fine and you can use the 3.0 Cressida Radiator, it should be a straight forward conversion, there is lots of space
aev@iburst.co.za
sichichoo
Town: gauteng
Post by sichichoo »
wow>> Hoppy.. I tot I had to replace the whole radiator and the drive shaft and the diff
will I have to change the engine mounts
sichichoo
Town: gauteng
Post by sichichoo »
plus there's lots of space,, idk about suspension wont the engine be? heavy on the car
sichichoo
Town: gauteng
Re: cresida gli6 swap 7mge
Post by sichichoo »
I have decided to go the 7mge route as it is less complicated to the 1uz, have bought engine and cant find ECU please help need Manual ECU not Auto
sichichoo
Town: gauteng
Post by sichichoo »
Um Still looking for a ECU Please help GUYS
Get an after-market Spitronics ECU .... more versatile than the standard one for the 7MGE. You will of course have to have it mapped and dyno'd, but that will be a worthwhile exercise in the longer term. You can even have two maps programmed into the ICU that you can change between with a switch on the dash .... one for town driving and the other for the open road for example. Should help a bit with power and fuel consumption. It will also be cheaper than trying to get a standard one from the agents.
sichichoo
Town: gauteng
Post by sichichoo »
Hi Mud Dog
where would you recommend I get one, and is possible to use a Cressida ECU with a Supra 7mge, I just found out that I have a supra 7mge, and not a Cressy one :(
I'm sure that you could use the Cressida ECU but it's old tech and won't give you the benefits that the newer stuff can. Spitronics should be available from most spares outlets.
sichichoo
Town: gauteng
Post by sichichoo »
Hi Mud Dog
please advise the Benefits of the Dictator ECU Vs Gotech VS Spitronics I can not make a choice :shock2:
Here's where you might want the advice of someone that works with these units regularly, but my take is this.
Dictator used to be the best units available but some time back they lost their software guru to Unichip and since that time they have fallen way behind everyone else. Their units are still good but basic. You will have problems with idle control - no real adjustment available for this and depends on the idle control valve you fit.
Gotech are up there with Spitronics but have had reliability issues.
Spitronics is a far more versatile unit that allows for far more detailed mapping in more areas. For example you can map at rev increments of 100rpm minimum whereas Dictator for example only allows a minimum of 750rpm. There's the multiple map ability that's very useful and they're robust, generally problem free. You will have to get someone that knows their oats to map it, but then the same really appliers to any brand.
sichichoo
Town: gauteng
Post by sichichoo »
Hi Mud Dog
Making a decision on which ECU to take is very hard, the Gotech goes for R3500.00 & R1500.00 for install, the Dicktator goes for R2000.00 and the Spitronics is R4500.00 without install,, I need the lamda & knock sensor function on it. really confused
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Do not skimp on the control unit. It will cost more in the end !!
Spitronix
sichichoo
Town: gauteng
Post by sichichoo »
Yea Chris I am avoiding cost at the end as this is just a project car.
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Nothing wrong with the Dicktator. I've done a few 4Y efi conversions using this EMU with excellent results. Used it on my own bakkie too. There are quite a few 7/5mge conversion running on Dicktator for many years. I think you'll need the wasted spark version which is a bit more expensive.
sichichoo
Town: gauteng
Post by sichichoo »
Hi Monster Truck
Please explain why would I need a wasted spark version? isn't that for the 7MGTE?
sichichoo
Town: gauteng
Post by sichichoo »
starting to take the 1ge apart and installing the 7mge, wish me luck :dance1:
Post by pietpetoors »
Good luck, post pics
sichichoo
Town: gauteng
Post by sichichoo »
dam this is hard work taking a smoking break
pietpetoors wrote:Good luck, post pics
+2
sichichoo
Town: gauteng
Post by sichichoo »
Finally found a gearbox that bolts on to the 7mge, phew!!! been having problems finding parts,, I don't know which clutch fork and slave cylinder to use with the 5mge gearbox... pics will be coming soon.
sichichoo
Town: gauteng
Post by sichichoo »
I finally removed the 1ge, I dropped the 7mge in and having clearance issues with the cross member,, can I shave it off to allow clearance,, fone site won't let me post pics
sichichoo
Town: gauteng
Post by sichichoo »
7mge is in now
sichichoo
Town: gauteng
Post by sichichoo »
Image Link Broken
Sent from my GT-I9100 using Tapatalk
sichichoo
Town: gauteng
Post by sichichoo »
Can any recommend if I should modify the cross member
sichichoo
Town: gauteng
Post by sichichoo »
Image Link Broken
sichichoo
Town: gauteng
Post by sichichoo »
Image Link Broken
Cross member issue
sichichoo
Town: gauteng
Post by sichichoo »
Image Link Broken
Wen the sump was sitting on the cross member,, I have clearance
eduan
Town: warmbath
Vehicle: toyota hilux 2.0L VVTi
Real Name: eduan
Post by eduan »
Hi. Sorry. I just wanted to find out if anyone here knows a guy in harties that can do a conversion?
sichichoo
Town: gauteng
Post by sichichoo »
What i have been up to since, now she starts :yahoo: :celebrate:
sichichoo
Town: gauteng
Post by sichichoo »
More pic
Sump moded to fit on crossmember
Radiator looking Rad man  :cooldude:
sichichoo
Town: gauteng
Post by sichichoo »
blow the 7mge!!! :thumbdown: now i have purchased a 2jge vvti. swap is 80% completed
:D: Looks like you're a sucker for punishment ..... the 7MGE conversion was almost completed and looking good! :D:
