Where the hec is the indicator unit?
Where the hec is the indicator unit/relay on my IFS Hilux?
I switch it on, I hear the tik tok behind the dash. I can feel the tik tok on the fuse box under the dash but I cannot see the thing. Do not feel like stripping the whole dash to look for it. Anybody have an idea where it is?
Re: Where the hec is the indicator unit?
Pieter, hope this helps.
Pieter... sover ek weet is dit in daai kick panel by die fusebox.
On the SFA it's under the drivers side kick-panel, yes. Not sure about the IFS.CasKru wrote:Pieter... sover ek weet is dit in daai kick panel by die fusebox.
Eish, seems like I will have to remove the whole fusebox. Thanx for the help
OK, so in order to get the the flasher unit you must loosen the fusebox and pull it forward.
I marked it with the red arrow.
I replaced it today with our new LED Flashers which fixes the problem of fast flashing LED replacement lamps.
One day when Alex added the new stock to the web site I will be able to tell you where to get those, so watch this space.
You have a lot of dust inside the kick-panel!
It's a Hilux, not a platkar.
I don't have that much dust behind mine and it's no stranger to dirt roads either - ride with the vents closed and the windows open.
I do the opposite when it is a very dusty road. Put the vents on full blast and close the windows in an attempt to build + pressure in the cab.
It is strange that there is so much dust because the only door that normally shows dust on the door rubbers is the left rear and this panel is located at right front.
- smokintyres
- Town: Windhoek
- Vehicle: Hilux 4.0 V6, relatively standard; for now...
- Real Name: Gernot
Hi Pieter, by any chance can you remember which of the units (FLASHERCF14 or FLASHERCF13) you used for your Hilux? Also it appears there are two units or am I mistaken?
Yes, it was CF14
- smokintyres
- Town: Windhoek
- Real Name: Gernot
Thanks, will order one right away
