A while back a sound started at the front of the vehicle, something like a sonbesie, i took off the fan belt and checked all the pulleys, and all of them turned easily.
Now, some times there is a new sound, a whoe whoe whoe type sound. Gears feels notchy, but the vehicle does not feel different.
The clutch must get replaced sometime, but can this noise be from it.
Thanx
Weird Sounds from Hilux
- IhanvanVuuren
- Town: Vereeniging
- Vehicle: 2008 D4D DC 4x4 Hilux
- Real Name: Ihan
Re: Weird Sounds from Hilux
Sounds like release bearing to me??
- Vehicle: 2.8GD6 Double CabHilux 4X4
- Real Name: Rian
Also do a search on "sonbesie" on the site.
- IhanvanVuuren
- Town: Vereeniging
- Real Name: Ihan
Bearing worn but can still go or immediate replacement?
Die problem is nie die thrust bearing wat raas nie. Dit is 'n sipmtoom van die clutch problem. Word jou clutch ook al harder om te trap? Kyk bietjie hier viewtopic.php?f=3&t=36846
Jy kan hom maar ry met die sonbesie. Die ander geluid wat jy beskryf. Is dit gekoppel aan die wiel spoed of die enjin spoed?
- IhanvanVuuren
- Town: Vereeniging
- Real Name: Ihan
Dit is die enjin, as bakkie stil staan en warm gery is, is hy daar! Maar ook net as dit baie warm is, in die oggende as ek by die werk kom dan is die bakkie stil!
Clutch fork / release bearing problem.
