Rear Diff lock will not kick in
SKRIK NIKS
Town: krugersdorp
Vehicle: hilux 3.0kzte
Real Name: jan venter
Post by SKRIK NIKS »
2003 kz-te rear diff lock will not kick in
Check all the wires at the back for power and eart ,founded that no power comes true to the motor
i have checked all feuses all ok
where can i check next ,any advice wll help
SKRIK NIKS
Donkey
Town: Johannesburg
Club VHF Licence: X122
Re: Rear Diff lock will not kick in
Post by Donkey »
Relay? :think:
Alternatively on the transfer case there has to be a switch which supplies power to the actuator when activating 4x4
Tumelo Maketekete
Masekind
Town: Lichtenburg
Vehicle: 2005 Hilux 4x4 v6, LR tank, ARB Bumper. (iJzer)
Real Name: Drikus
Post by Masekind »
Het hy n vacuum pypie?
SKRIK NIKS
Town: krugersdorp
Nee dis n 4x4
Dis die een met net die plug met al die drade
SKRIK NIKS
Masekind wrote:Het hy n vacuum pypie?
The KZ has an electric locker (actuator motor at the diff). ;-)
MCHILUX
Town: Centurion Gauteng
Vehicle: Mazda Rustler 16v
Real Name: Jan
Post by MCHILUX »
Check in the right hand side kickpanel there is a ecu for the 4x4 system they tend to get water in and fail
george
Town: Velddrif
Vehicle: Triton 3.5l V6
Club VHF Licence: HC107
Post by george »
Donkey wrote:Relay? :think:
Mine also came loose once
Post by Mars »
Ek is nie seker van die KZTE nie maar met die D4D kan jy net die "difflock" in "low range" gebruik. Die ander manne het goeie voorstelle hier gegee.
Post by pietpetoors »
The KZ's diff lock will also only kick in when in low range. Jan see if you do this mod if it is still not working:
http://www.hilux4x4.co.za/hilux-diff-lock-mod/index.php" onclick="window.open(this.href);return false;
The mod at link below enable the diff lock to be activated even in high range.
Huismoeles
Town: Bellville
Vehicle: V8 Disco 1
Real Name: Dirk
Post by Huismoeles »
Sal daai move op die nuwer ry goed ook werk bv op my 08 v6 fortuner??
My diff lock werk ook net op low range
Ek glo as jy die regte draadie in die hande kry ja.
Moet maar soek op die internet of jy artikel kry vir die nuuter modelle
OOOO, OK, sommer op ons eie site:
http://www.hilux4x4.co.za/diff-lock-mod ... /index.php" onclick="window.open(this.href);return false;
oorspronklik van die post, net jammer die fotos het verdwyn:
http://www.ttora.com/forum/showthread.p ... ge=4&pp=30" onclick="window.open(this.href);return false;
Huismoeles
Town: Bellville
Vehicle: V8 Disco 1
Real Name: Dirk
Tx pieter
