Vrae oor Ford v6 engin
Andries
Town: Dordrecht
Vehicle: '94 2.2 4Y Hilux S/C, '87 2.2 4Y Hilux D/C
Real Name: Andries
Post by Andries »
Ek is tans besig om n' Ford v6 engin te restoreer, kan iemand my dalk se waar die no1 piston is, dit links voor of is dit regs voor , of kan een my se waar kan ek online manuel vir Ford kry met speks baie dankie. :?: :?: :crazy: :crazy: :wth: :wth:
Riceburner
Town: JHB
Vehicle: D2 V8
Real Name: Darryl
Re: Vrae oor Ford v6 engin
Post by Riceburner »
legend35
Vehicle: Hilux 2700i
Club VHF Licence: HC262
Post by legend35 »
Andries,sover ek weet is dit links voor as jy voor die voertuig staan.
Andries
Town: Dordrecht
Real Name: Andries
Post by Andries »
Dankie vir die info. :thumbup:
Op die webwerf is daar nie juis spesifikiasies nie, of info oor firing order, ens. nie, of kyk ek dalk in my ooglede vas. :lol:
Vleispyp
Town: Kuils River
Vehicle: Gwm 2.8 4x4
Real Name: Charl
Post by Vleispyp »
net n tip!as hulle se lings of regs bedoel hulle as jy binne die kar sit!!vra my ek het n
v8!sterkte :thumbup: :thumbup:
GWM 2.8 4x4 Wie is jou China
Sifu-Lux
Town: Mount Vernon Illinois
Real Name: Andrew
Post by Sifu-Lux »
Andries, I rebuilt a V6 two years ago. Ask if you need any info, maybe I have it.
Here is the piston layout and specs
Pistons
3 O O 6
2 O O 5
1 O O 4
Front of engine
Number 1 piston is the front left bank piston
INLET VALVE CLEARANCE (HOT) 0,30 mm
EXHAUST VALVE CLEARANCE (HOT) 0,55 mm
OIL PRESSURE (HOT @ 2000 R/MIN) 280-430 kPa
STATIC IGNITION TIMING - SEA LEVEL 14 deg BTDC
STATIC IGNITION TIMING - ABOVE 800m 17 deg BTDC
CONTACT BREAKER GAP (BOSCH) 0,45 mm
DWELL ANGLE 30 ~ 34 deg
IDLING SPEED 800 R/MIN
FIRING ORDER 1-4-2-5-3-6
SPARK PLUG NGK BPR 6ES
SPARK PLUG GAP 0,65 mm
Sifu-Lux....I will miss you
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
I can mail you the Essex V6 manual from the Ford Cortina Workshop manual which I used.
PM me your email address.
Sifu-Lux
Real Name: Andrew
Post by Sifu-Lux »
Andries,
Setup for valve clearance as follows:
Valve Open ------------- Valve to Adjust
1 and 6-----------------10 Ex. and 7 In.
8 and 11-----------------5 Ex and 4 In.
2 and 3------------------9 In. and 12 Ex.
7 and 10-----------------6 In. and 1 Ex.
4 and 5-----------------11 In. and 8 Ex.
9 and 12-----------------2 In. and 3 Ex.
Remove rocker covers and spark plugs
Turn engine until the valves in the first column of the above table are fully open
Adjust the corresponding pairs of valves in the second column
Cyl and valve numbering V6.JPG (29.12 KiB) Viewed 8815 times
valve adjusting v6.JPG (34.18 KiB) Viewed 8819 times
Rider
Town: Richards Bay
Vehicle: 1987 Toyota Hilux 4x4 d/c 40mm body lift, KZ-TE Diff with Diff lock, Snorkel, 31" AT tyres , Powered by FORD 3.0 V6 uprated.
Real Name: Luke
Post by Rider »
hi andrew could you please email the manual aswell plz lol i bought my v6 the other day to put in my hilux
PROUD OWNER OF A TOYOTA HILUX AKA AMA-HIPZ
scout
Town: White River
Vehicle: 91 Hilux dc -pro comp , arb bb , winch , 33'' muds
Real Name: Jonathan
Post by scout »
so franco changed your mind?.
looks like there will be a view outlaws with the v6 toyfords :lol:
" Yes I know we are lost , but we are making good time "
Stubs
Town: Onrusrivier Hermanus
Vehicle: 89, Hilux D/cab 3.0L V6 Ford !!
Real Name: Stuart
Post by Stubs »
bring it on is what I say !!! :dance1:
Rider
Town: Richards Bay
Real Name: Luke
Post by Rider »
lol yeah he finially convinced me
519franco
Town: Richards bay
Vehicle: 87 Hilux 3L v6 Ford
Real Name: Franco
Post by 519franco »
Rider wrote:lol yeah he finially convinced me
like i always say iam allways right/\...lol
luke you can foto copy the pages out of my book
FORD> Full Off Road Damnation
Sponser: MY DAD
Rider
Town: Richards Bay
Real Name: Luke
Post by Rider »
thanks good idea
scout
Town: White River
Real Name: Jonathan
Post by scout »
hey luke
have started with your v6 yet?
legend35
Post by legend35 »
Always liked a V6 Ford.Still got a Granada XL coupe :thumbup:
519franco
Town: Richards bay
Real Name: Franco
Post by 519franco »
scout wrote:hey luke
his puting it on hold nw, he wants a small car
Sponser: MY DAD
