Extreme shudder on steering column. Please help!?
- Juvster
- Town: Centurion
- Vehicle: 1999 Toyota Hilux 2.7i D/C 4x4
- Real Name: Juvan
Hi Guys
I hope you can give me some advice on my '99 2.7i Hilux.
There is a real bad shudder on the steering column in 1'st or 2'nd gear when I hit low revs and come to a stop. This shudder seems to be getting worse.
It's now almaost at the point of me taking my hands of the steering wheel when I come to a stop because the rattle/ shuddering becomnig unbearable.
As this shudder is only on low revs in 1'st and 2'nd I don't recon it has anything to do with wheel alignment or ballance?
Any advice would be appreciated!
Thanks!
Thanks!
1999 Lux 2.7i D/C 4x4
- ARB bumper
- OME suspension lift
- Dual battery system
- Safari Snorkel
- BFG Muds
350 000km's and still going strong!
- ARB bumper
- Safari Snorkel
- BFG Muds
Re: Extreme shudder on steering column. Please help!?
IF it's only under braking it could be warped brake discs and worn ball joints
- Juvster
- Town: Centurion
- Real Name: Juvan
Hi Cassie,
No not only under braking. This shudder is present on pull away and when slowly moving forward in first in low revs.
- ARB bumper
- Safari Snorkel
- BFG Muds
- ARB bumper
- Safari Snorkel
- BFG Muds
Do you only feel it on the steering or in the seat as well? Bent axle?Juvster wrote:Hi Cassie,
- Juvster
- Town: Centurion
- Real Name: Juvan
No just the steering column.
- ARB bumper
- Safari Snorkel
- BFG Muds
- ARB bumper
- Safari Snorkel
- BFG Muds
The only thing I can think of is balancing and maybe a bent axle or rim
- Juvster
- Town: Centurion
- Real Name: Juvan
Thanks Cassie. I'll look nto aal the possibilities
- ARB bumper
- Safari Snorkel
- BFG Muds
- ARB bumper
- Safari Snorkel
- BFG Muds
Quick check you can do to see if it's the wheels/tyres is just to do a back to front swapJuvster wrote:Thanks Cassie. I'll look nto aal the possibilities
- Rieks
- Town: Outjo
- Vehicle: 3.0 D4D
- Real Name: Rian
I will start with the easy& relative cheap stuff - balancing, alignment and check your tyres for flat spots or bubbles.
can also be a rim, so change with spare and see if it still shutters.
- Juvster
- Town: Centurion
- Real Name: Juvan
Dankie manne! Ek sal loer hierna. Maar ek het so idee dit is of die clutch of dalk 'n bearing.
- ARB bumper
- Safari Snorkel
- BFG Muds
- ARB bumper
- Safari Snorkel
- BFG Muds
- jacques kotze
- Town: Nelspruit
- Real Name: Jacques
As jy onlangs deur modder gery het moet jy in die binnekante van jou rims kyk vir modder wat droog geword het, dit kan jou wiele uit balanseering uit gooi.
- Juvster
- Town: Centurion
- Real Name: Juvan
Ek het nou gou 'n toets gaan doen. Hy hou op met shudder sodra ek die clutch intrap. Dit sê vir my net een ding.......gearbox?
- ARB bumper
- Safari Snorkel
- BFG Muds
- ARB bumper
- Safari Snorkel
- BFG Muds
- Blaps
- Town: Rustenburg
- Vehicle: Hilux 4x4 Ford V6
- Real Name: Ben
:wth: Check your Mountings on engin & gearbox
m2cw
m2cw
Go, just go.... Somewhere.... Out There...
