Klap geluid
- Smurf
- Town: Boksburg
- Vehicle: '93 hilux 4x4 d/c (2.2).31"bfg muds,long range fuel tank,tjm front bumper,canvas canopy,duel battery system,tnt branch+ss exhaust.
Klap geluid
Het onlangs n klap geluid agter gekom as ek stuurwiel vinnig draai Die klap geluid is nie BAIE hard nie en klap net so half draai voordat stuurwiel lock (vol draai). Het geklink asof dit by regter voorwiel is en begin toe uitmekaar haal om te kyk. Als het reg gelyk behalwe 2 seels wat biekie "uitgeware" was. Het 2 seels by toyota gaan koop R190 vir altwee, 1 seel wat olie van diff en hub skei en 1 wat op hub sit om grease in te hou. Bearings lyk goed, cv lyk goed, als skoon gemaak en weer grease gegee en weer aan mekaar gesit. Klap geluid nogsteeds daar
Re: Klap geluid
I've also heard a klap geluid when insulting the wife while driving in the bakkie... and it hurts!
Could be a worn CV joint??
- Smurf
- Town: Boksburg
Re: Klap geluid
Ive learned not to insult the wife while driving! CV looks fine. It also only happens when turning the wheel quickly
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Re: Klap geluid
Then it must be the wife's head knocking the grab handle when turning quickly........happens all the time in my van....and is normally followed by the other "klap geluid" mentioned by "B"!!!Smurf wrote:Ive learned not to insult the wife while driving! CV looks fine. It also only happens when turning the wheel quickly
Sorry, if it's not the CV or ball joint..... I've got no idea!!!
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Re: Klap geluid
Check the ends of the drag link, they sometimes run dry cause binding on the balls. It's also possble that either the j-arm or pitman arms balls are worn out of round, in which case you can have them re-engineered and replace the drag link(quality aftermaket ones are available). A common klap noise on the SFA hilux is from the leaf springing 'rubbing' vertically under strain(turning), most often when the U-bolt nuts are not tight enough... check them with a torque wrench, IIRC 120nm...
Re: Klap geluid
Oh... and one last thing... if you've replaced/modified your suspension, or put in extended shackles... check that the j-arm side(wheel hub) of the drag link is not fouling against the top of the U-bolt, this is common on SFA's with lifted suspensions. The draglink can be bent up, on the j-arm side, a bit to correct this... with no negative after effects... just be careful to bend it in the correct axis/plane!
Kulula is much preferred over One-Time!
- Smurf
- Town: Boksburg
Re: Klap geluid
Initially thought it was the leafe spring rubbers, but they all good. Will start again by checking the u bolts. thanx MR B ..
Hopefully not something MAJOR. Will let jou know what i find after the weekend.
- LouisZ
Re: Klap geluid
Check the leafspring bushes. Also the Torque rod bushes(between axle and chassis).
- Kat
- Town: Kraaifontein
- Vehicle: Hilux SFA
- Real Name: Eugene
Re: Klap geluid
Hallo mr B
If the pitman arm balls are out of round, how do they fix this, do they weld it up and re-machine it?
Thanx Eugene
Thanx Eugene
Re: Klap geluid
Ja, that's basically what they do.Kat wrote:Hallo mr B
Thanx Eugene
Re: Klap geluid
No, on mine they drilled out the old ball and shaft, and then engineered and welded in the new ball and taper shaft... it's like brand new again... this is better that welding up and machining... the also used a high grade steel for the ball so it should last another 20 years! I had this done on the pitarm and well as the j-arm, and then installed a new draglink... all in all the whole fix-up cost around R800(incl new draglink)
- Andre du preez
- Town: somerset west
- Vehicle: hilux 2.2
- Real Name: Andre
Re: Klap geluid
Was die bakkie voor die klapg.. opgetel vir ander werk. My bakkie was vir iets in kan nie onthou nie. Het ook so gemaak. Dit klink dom maar vat wap en spyt die leafsprings soos in goed skoon. Wat vir my vertel was is daar kom maar sand grond en baie klien goed tussen Leafsprings in en wanneer jy draai en die vere beweeg gebeur dit.
