Normal worklight to "super" worklight?
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
We all know that a good worklight can be very handy. However, the downside to all the nice benefits is plain and simple. It has no respect for battery life and limited power reserves. That is where LED technology becomes very attractive. And Andrew Faber sells an impressive range of quality LED driven worklights.
What to do if you already have a worklight???? It is money already spent.
This is my solution, bought these LED H3's in 12v on eBay and now waiting for delivery.
- Attachments
- H3%20LED.jpg (17.49 KiB) Viewed 4712 times
Know what you don't know.
Re: Normal worklight to "super" worklight?
Interesting .... and cost? I wonder what their lumen output is by comparison to the standard H3 (halogen)?
- Town: Springs
Energy consumption is 3W and they are intended for foglights and spotlights so they should not be too anemic.
Cost including shipping is $9.00 for two.
That's not too harsh. Pity the local suppliers are not 'up to speed' with the latest products. So much easier to buy locally and have availability when replacement is required.
- Town: Springs
It is easier to drive to your local store and buying a local H3; absolute fact. And it is much faster and more convenient.Mud Dog wrote:That's not too harsh. Pity the local suppliers are not 'up to speed' with the latest products. So much easier to buy locally and have availability when replacement is required.
Advantage from a cluster LED is that it is extremely unlikely for the complete unit to blow all LED's in one moment. You will notice they are going one by one; unlike a Halogen. Therefore having 2 H3's in LED should last me a long time. I know of at least one seller in Boksburg that sells H3 LED's, but they are R150-00 each if memory serves me correct.
Consumption on the LED's is far less than Halogen.
Led's are generally not brighter than Halogen. Reflectors like spot lights are specifically designed to reflect the light applicable to the application. Light is a very complex phenomenon, move the designed philliment and the application differs. The reflective ray from the reflector is the visible source and if the angel is incorrect the application will differ.
A simple example is a Mag light, with an adjustable head. By moving the reflector housing forward or backward will provide a spot or a flood effect.
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
Heinrich, hoop nie ek bars jou bubble nie. eK het 'n Hella werk lig en het by Andy een van daai globes gekoop. Die lig is maar baie teleurstellend want die reflector si nei reg ontwerp vir daai gloeilamp nie -ek is terug na my H3/4 gloeilamp.
By Andy? ... of by Mark, of was dit dalk 'n ander 'Andy' gewees.....Uys wrote:Heinrich, hoop nie ek bars jou bubble nie. eK het 'n Hella werk lig en het by Andy een van daai globes gekoop. Die lig is maar baie teleurstellend want die reflector si nei reg ontwerp vir daai gloeilamp nie -ek is terug na my H3/4 gloeilamp.
- Town: Springs
Andy Faber (AndyF) from 4x4Community M_D.Uys wrote:Heinrich, hoop nie ek bars jou bubble nie. eK het 'n Hella werk lig en het by Andy een van daai globes gekoop. Die lig is maar baie teleurstellend want die reflector si nei reg ontwerp vir daai gloeilamp nie -ek is terug na my H3/4 gloeilamp.
Uys, ek het hulle eintlik aangeskaf om te gebruik in misligte, maar besluit om hulle te toets in die werkslig sodra hulle hier aankom. As hulle nie lekker werk in die werkslig nie dan koop ek 'n LED werkslig op eBay.
Heinrich, as jy dit kry kom maak 'n draai een aand, ek het 'n digital lig meter dan kan ons speel en toets en natuurlik 'n vleisie oppi kole gooi
- Town: Springs
Daai is 'n lekker plan.OOOOMS wrote:Heinrich, as jy dit kry kom maak 'n draai een aand, ek het 'n digital lig meter dan kan ons speel en toets en natuurlik 'n vleisie oppi kole gooi
Ek weet dat ligte kan vreeslik verskil tot met verskillende gloeilampe (praat nie eens van verskil tussen LED en Halogen nie). Rede hiervoor is omdat jy die brandpunt van die gloeilamp in verhouding verander met die fokuspunt op die interne reflektor.
Ons sal maar sien hoe werk hy terwyl ons 'n tjoppie tan.
Traveler wrote:Daai is 'n lekker plan.OOOOMS wrote:Heinrich, as jy dit kry kom maak 'n draai een aand, ek het 'n digital lig meter dan kan ons speel en toets en natuurlik 'n vleisie oppi kole gooi
Heinrich, nou dat ek na die kopstuk sit en kyk van daai LED H3 pic wat jy gepos het, sien ek dalk 'n ander probleempie. Die ontwerp van 'n Halogeen spot se glas lyk heelwat kleiner as die van die LED, en gaan dalk 'n probleem wees om deur die gleuf te kry?
- warrenaken
- Town: JHB
- Vehicle: 3.0 KZ-TE 4x4
- Real Name: warren
- Club VHF Licence: X04
I have been using a 9LED globe in my work light for awhile now and they are great. Yesterday I got my 68LED the exact same as the one above (Heinrich's one), the are claimed at 220 lumens. Will fit this weekend and let you know.
Toyota Hilux KZ-TE
- Town: Springs
Mark, dit sal nie probleem wees nie. H3 is 'n ISO industry standard, al die ligte wat H3/H1/H4/H7/H8 gebruik moet aan dieselfde dimensies voldoen met fixtures wat volgens die standaard voorgeskryf word. Bv. 'n H3 12v en H3 24v moet ook almal dieselfde specs voldoen. Nou voordat iemand my dit probeer uitwys, die H-spec het niks te doen met die size van die reflectors of die fisiese size van die lig nie. Dit is 'n standaard vir die gloeilamp.OOOOMS wrote:Heinrich, nou dat ek na die kopstuk sit en kyk van daai LED H3 pic wat jy gepos het, sien ek dalk 'n ander probleempie. Die ontwerp van 'n Halogeen spot se glas lyk heelwat kleiner as die van die LED, en gaan dalk 'n probleem wees om deur die gleuf te kry?
- Town: Springs
warrenaken wrote:I have been using a 9LED globe in my work light for awhile now and they are great. Yesterday I got my 68LED the exact same as the one above (Heinrich's one), the are claimed at 220 lumens. Will fit this weekend and let you know.
Thanks Warren
H, jou misligte gebruik 'n H10 lamp (daai wat water ingekry het)?Traveler wrote:Andy Faber (AndyF) from 4x4Community M_D.Uys wrote:Heinrich, hoop nie ek bars jou bubble nie. eK het 'n Hella werk lig en het by Andy een van daai globes gekoop. Die lig is maar baie teleurstellend want die reflector si nei reg ontwerp vir daai gloeilamp nie -ek is terug na my H3/4 gloeilamp.
220 Lumens is = to a 25 watt oven light (which is little)warrenaken wrote:I have been using a 9LED globe in my work light for awhile now and they are great. Yesterday I got my 68LED the exact same as the one above (Heinrich's one), the are claimed at 220 lumens. Will fit this weekend and let you know.
a 40 watt candle lamp produces 440 Lumen
- Town: Springs
Nee, hulle gebruik H3. Ek weet want ek het al 1 van hulle vervang.
- Town: Springs
Het jy dit al met jou lux meter gemeet??OOOOMS wrote:220 Lumens is = to a 25 watt oven light (which is little)warrenaken wrote:I have been using a 9LED globe in my work light for awhile now and they are great. Yesterday I got my 68LED the exact same as the one above (Heinrich's one), the are claimed at 220 lumens. Will fit this weekend and let you know.
JaHet jy dit al met jou lux meter gemeet??
Kop stuk vergelyking:
- Town: Springs
Daai wit ene is nie H3 nie?? (kan sien daai liggie waar jy hom probeer fit is H3) het jy hom probeer insit met 'n hammer?
Waarom ek daai vraag vra oor Lux lesing vs. rated is dat ek in die verlede al gesien het dat 1 gloeilamp met spesifieke lumen rating kan verskillende resultate gee in verskillend ligte omrede die reflectors se performance verskil.
Ja nee Mark... daai globie wat jy daar beet het is 'n wedge tipe globe wat onder andere in die Tazz se brieke gebruik word.
Ek weet dit is 'n T10 net vir illustrasie doeleindes (13 LED)Traveler wrote:Daai wit ene is nie H3 nie?? (kan sien daai liggie waar jy hom probeer fit is H3) het jy hom probeer insit met 'n hammer?
Laas week het ek , 'n 18 LED briek lig getoets teen die standard 25 watt halogen. En die 25 watt halogen is helderder by omtrent 15% in vergelyking met die LED. Met my 4 oe getoets.
Jy is heeltemal reg oor die reflector toets. 'n 55 Watt H3 halogen lamp sit 930 Lumer uit.
Sit hom in 'n spotlight reflector en jy kan bv 1500 lumen kry, directional.
Sit dit in 'n spotlight, 'reputable 'soos lightforce (selfde lamp) en jy kry 8500 lumen kry.
It's all about the reflector!
- Town: Springs
Absoluut.OOOOMS wrote:It's all about the reflector!
Clearly :wink2:
- Gunta
- Real Name: Mark
And much better looking too...
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Can I put two of those in my BakkieCasKru wrote:Another example of a reflect-her
- warrenaken
- Town: JHB
- Real Name: warren
So tried to fit my bulb this evening and it does not fit :evil:
The problem is not only what Mark was showing above (I think....) but also the length of the bulb itself, so have had to stick the 9 led back in. So now Mark will have to test it for me coz I can look into the oven but not my light!
Toyota Hilux KZ-TE
Warren do you have a pic of the work light? And where the standard lamp fits in or is supposed to fit in?
- Town: Springs
OOOOMS wrote:Warren do you have a pic of the work light? And where the standard lamp fits in or is supposed to fit in?
H-denomination is industry standard for the fitting, not the length of the globe.
- warrenaken
- Town: JHB
- Real Name: warren
Ok, so the worklight is one of thoes standard hella type one, and the bulb is too long from the fitting to the glass, as shown below (a picture is worth a thousand words!).
The second problem is the "hole" to put the bulb in is a square hole(yellow)and narrower than the top (neg), so the fatter round cluster (red) of LED's does not fit through, as in the second pic.
Toyota Hilux KZ-TE
Tx Warren, those also look like 2/3mm LED's, if you can rather try and source 5mm or larger LED's 10mm LED's are super bright :wink2:
- Town: Springs
Warren, that is the six sided LED?? I've bought a set of them and a set of the 4 sided ones as well.
- warrenaken
- Town: JHB
- Real Name: warren
I have the 4 sided led in at the moment, they are 5mm as far as i know. still throws a good beam if it is dark, the problem is when there are other light sources, it seems to get drown out a bit.
something like this
something like this
Toyota Hilux KZ-TE
Think these will fit through the hole?
Warren, what is the length your work light can take?
Does all the work lights use H3 globes or does some use H4 or H7 as well?
Would you prefer warm white, cool white or just white?
- Town: Table View - CT
- Vehicle: 4x4 3.0KZ-TE 2002
- Real Name: Lourens
Piet, het jy hierdie H3 lampe in jou voorraad?
Indien nie , is dit hier naby te koop.?
Lourens
Lourens
Lourens, hulle is nog nie hier nie, ek moet nou juis weer voorraad van kar ligte bestel en wil kyk wat ek moet byvoeg tot my bestelling, dit is hoekom ek vra
