Deep cycle battery Box - Advice needed
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
The time has finally arrived that I bought a the national luna split charging system, and now i'm about to fit it.
The deep cycle battery is to be mounted on the r/r wheel arch in my SFA. Reason is to keep the weight on the axle and also this is an unused space that is perfectly filled by the battery. Having looked at the various boxes available, I am now in two minds.
I would rather build a box from wood & Steel and fit the battery in the box than buying a plastic unit for R 250-00.
The reason for putting the battery in a box is to prevent it from being damaged, getting wet when I open the side doors of the canopy and also to enable me to keep it covered which looks just so much neater.
Now having given this a lot of thought, I would like to know form those that has fitted a battery, what's the in's and out's of mounting the battery.
- HiluxJunkie
- Town: Middelburg MP
- Real Name: Simon
- Club VHF Licence: N15
Re: Deep cycle battery Box - Advice needed
My box is bolted to the bak and the battery fits snugly into the box. When lid is closed, it is secured. No extra brackets inside box to hold down battery.
- HiluxJunkie
- Real Name: Simon
I have seen what damage battery acid did to a 12v fridge when the battery leaked..........plastic box will be better......unless you can somehow seal the wood box inside with some acid proof coating that will prevent leaking.Toro-Adventures wrote:The time has finally arrived that I bought a the national luna split charging system, and now i'm about to fit it.
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
I did the plastic box thing. Bolted its sides inside the drawer system.
Know what you don't know.
in the event of a "sudden stop" that battery is has a LOT of inertia !! Bolt it down properly ....
I agree with the battery acid and plastic holder story ..... so I went for a completely sealed battery and mounted it on wood.
PLEASE remember to "cover" the top of the battery. You dont want something to cross out the terminals.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
hi Johan
Here is a pick of mine.I will have to get another pick of it opened.
Inside I secured it withe the standard bracket from Midas.I also put some foam at the bottom for shock absorbent.
- george
- Town: Velddrif
Nog so 'n prenkie. My hande werk lyk maar rof maar die setup werk
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Hoekom nie n national luna draagbare split charger gekoop nie?Dit is baie nuttig in die opsig dat dit in die voertuig asook buite die voertuig gebruik kan word.
Johan, 'n gewone plastic battery boks kos seker nie R250 nie. Meer soos R120....
- JohanM
- Town: Meyerton
Mark,
EK het een gesien vir R 120 maar die boks is te flimsy vir waar ek die battery wil mount. SO nou sal ek maar een bou met 'n spesiale tray in en 'n drain indien die battery sou wou sweet of so iets.
Ek hou mos van difficult wees....
Reg so, het jy al na GertC se unit gekyk? Lyk goed
- JohanM
- Town: Meyerton
Ek sal weer gaan opkyk, want ek onthou so installasie was baie netjies gedoen gewees.OOOOMS wrote:Reg so, het jy al na GertC se unit gekyk? Lyk goed
Mark Waar en hoe kyk ek na GertC se opset?
My keuse is nou tussen so 'n self-doen jobbie of NL se kas wat 'n hele paar Rand gaan wees :wth:
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
Myne is 'n staal kassie met "softboard" lining binne en 'n sliding deksel met plek vir 'n slot. Het my lux so gekoop...
Sal pics opsit vanaand as iemand belang stel.
Johan, hoekom maak jy nie 'n staal kassie met die R120 flimsy plastiek ding binne in nie? :wink2: best of both worlds...
- JacoJB
- Town: Melkbosstrand
- Vehicle: 2011 Fortuner D4D 4x4 out
- Real Name: Jaco
Johan
Het jy al gekyk na die Nasional Luna se Draagbare of los Battery stelsel.Ek weet dit is bietjie duur maar as jy in ag neem dat dit reeds met alle koppelings(hella,sigaret en brad harrison) sowel as kabels kom assok `n sekeringskakelaar is die koste nie so hoog nie.Ek het myne nou al 5 jaar en het dit in 3 verskillende voertuie gebruik en bly nog steeds baie tevrede daarmee.Gaan loer gerus hier vir meer oor die produk http://www.nationalluna.com/PPPack.htm" onclick="window.open(this.href);return false;
Hoop dit help
Groete
Jaco
Hoop dit help
Groete
Jaco
Tinus, hier is nog info:
viewtopic.php?f=41&t=5527" onclick="window.open(this.href);return false;
- JohanM
- Town: Meyerton
Jaco, ek het daarna gekyk, maar die setup gaan nie so lekker vir my werk nie omdat ek die battery permanent wil mount en later ook dan 'n lekker sterk inverter ook permanent mount in die canopy. Die hele setup word so gedoen omdat die voertuig net gebruik word vir 4x4 ry, overlanding en lang safari's....JacoJB wrote:Het jy al gekyk na die Nasional Luna se Draagbare of los Battery stelsel.
Die portable unit sal heel moontlik later sy plek vind in die Fortuner as hy die volgende boskar word....
- witmamba
- Town: Sasolburg
- Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
- Real Name: Hans
Johan, hier's 'n foto van die een waarmee ek besig is. In plaas van 'n fuse gaan ek 'n 5 of 7 ampere "dc breaker" insit. Verder het dit 'n hella, 12v lighter en 'n harrison konneksie, 'n 500w 220 volt inverter, en nog 'n harrison koppeling na die hoofbattery toe. Ek gaan die bokse self opmaak en hopelik teen 'n baie goedkoper prys as N.L. se produk kan verkoop. Wag nog net vir die breakers.
Life only starts . . . . where comfortlevels end
- Stubs
- Town: Onrusrivier Hermanus
- Real Name: Stuart
Hi Johan, I had a dedicated aluminium box made up for me at ALUCAB. I have the 2 hella plugs and NL fridge plug mounted on top of the lid, the lid itself is rubber lined to prevent terminal interference. Inside I mounted the battery on a piece of wood also. The battery is perfect fit and does not move around even off road. the lid is held on by two clamps which allow for it to be locked. Secondly I mounted it just infront of the wheel arch next to my sliding try. Simple straps and floor mounting strips with hooks to hold it all in place. This allows for it to be taken out easy etc...I then have about a 400 mm cable lined running to my plug connection just next to the load gate so that it can be completely disconnected from the main battery etc. cheers stubs
