Strange sound on SWAMBO's Suzi
- Town: Port Elizabeth
- Vehicle: 1990 SFA Hilux
Lux friends,
SWAMBO has a 2001 Suzuki Grand Vitara 2.5 V6 with 160 000 trouble free KM on the clock.
It’s a great little lady’s 4x4 with nice vooma and it did not give us any problems.
I cannot comment on the 4x4 capabilities because SWAMBO nurses her baby :?
Last night I drove it to the shop and noticed a slight noise (the radio must be switched off) from the rear end of the vehicle. It sounds like a wheel bearing, but the sound does not come and go when cornering. I also noticed it to be more prominent when the vehicle free wheels and less noticeable when under power.
My thought is that it might be a pinion bearing on its way out or slightly unbalanced propshaft or even road noise from the tyres (they are 235/16/60 some hoener brand starting with a K)
Any ideas / suggestions will be appreciated. If SWAMBO is happy, she leaves me alone to do nice things like fishing, drinking beer and playing with my Lux.
Re: Strange sound on SWAMBO's Suzi
Could be just about anything back there. Most sounds are more evident without the sound of a revving motor and wheel bearings are'nt neccesarily louder when cornering.
Don't tell her about it and leave the radio on her favourite station!
Any ideas / suggestions will be appreciated. If SWAMBO is happy, she leaves me alone ....
Andy,
Your reply just made my day.
Great advice, THANKS!
Jokes aside, you're gonna have to try and trace it .... it may be something serious that has safety implications. Perhaps if she drives while you sit in the back and try to determine if it's coming from the centre (diff / universals / prop-shaft etc.), left or right (wheel bearings / brakes / tyres). Perhaps even put the back axle on stands and run it in gear while you have a listen underneath.
P.S.
I've said before, one of the most useful and inexpensive pieces of equipment is a mechanic's stethoscope to pin point strange sounds. Midas used to keep ... about 40 bucks or so ....
P.S.
Andy,
Thanks! very useful tips. I will try everything with one exception - a friend will be behind wheel while I am listening!
Will let you know!
Will let you know!
Useful in the bedroom as well... with a bit of imagination...Mud Dog wrote:...one of the most useful and inexpensive pieces of equipment is a mechanic's stethoscope to pin point strange sounds. Midas used to keep ... about 40 bucks or so ....
:wth: Don't tell me that you're into that nurse uniform stuff!!RustyRod wrote:Useful in the bedroom as well... with a bit of imagination...Mud Dog wrote:...one of the most useful and inexpensive pieces of equipment is a mechanic's stethoscope to pin point strange sounds. Midas used to keep ... about 40 bucks or so ....
If it is more prominent when free wheel than under load my first guess would be universals on the prop shaft. We did the bearings on my Hilux's diff the other day and those made more of a noise under load and was quiet when free wheeling.
I would start with the universals.
Our Platkar had a similar thumping sound coming from the boot when I was transporting the M.I.L. recently.
It was however, quickly remeded by simply increasing the amount of Chlorophorm used
Thanks again for all the tips!
I folwed the stethoscope advice and traced it to a rear brake shoe binding against an oval brake drum. It seems as if the self adjuster got a little confused when the drum got oval.
Everything is fixed now and SWAMBO is happy! I didn't try that nurse trick in the bedroom yet!
Happy that you got it sorted, Johan.
