Replacement of Center Carrier Bearing
- BeesII
- Town: Vereeniging
- Vehicle: 94 Hilux; 2700i,Double Cab
Hi,
I would like to replace the center bearing of my 94` Hilux.
How do I go about to do it and do I need special tools to get the flange removed and inserted back again?
Please help!
Cheers
Chris
Please help!
Cheers
Chris
Re: Replacement of Center Carrier Bearing
Never had to do it, so I would't know, but someone here will. Just give it a little time and check back later.
Yes you'll need a drift/bearing puller to remove the old bearing. Once you've disconnected the mating surfaces you can (mark before dis-assembly) you can either take the bearing and shaft to an engineering to pull off the old and fit the new or try it yourself.
There's a castle-ated nut to remove (like inside the front hubs) which needs careful handling if you are going to use the same nut again, best get a replacement from the Stealers.
Otherwise real straight forward, Stealer one is expensive, Gemini/Commercial Carrier Bearing (Complete Assembly) is cheaper and of adequate quality, around R250.
Take peekchaz Bru asblf
- BeesII
- Town: Vereeniging
Thanks but I`ll rather dismantle the driveshaft and take it to a Eng. shop for replacement.
I`ve already bought the bearing from the Agent...ok Stealer, but only the casing and bearing thus the additional work to be done.
For some reason I believe to replace parts on the Hilux with the genuine (Stealer) thing due to the long distances we travel. Do not want a breakdown in mid Bot. you know :D
BeesII wrote:Thanks but I`ll rather dismantle the driveshaft and take it to a Eng. shop for replacement.
100%
What did you pay for the Assembly from the Stealers asblf
- TJV
- Vehicle: 3.0 liter D4D Fortuner,, Roof rack and VHF radio
- Real Name: Theunis
- Club VHF Licence: X 110
Hi Bees
Not sure if it is the same as the IFS's centre bearing, but I changed mine a week or two ago on an IFS DC and as someone said before remove the castle nut (IFS a locknut) and with a three legged wheelpuller pull it off after you marked it. Remember the two propshaft sections need to be on the same spline if you do not want to balance the shaft afterwards. Carefully push the new centre bearing in making sure the orientation is the same as it was with the old one. Fit and tighten the castle nut and fit a new split pin if there is space for one. If you find that it vibrates remove the hole shaft and take it to a propshaft repair shop so that they can balance it. This whole jobby shouldn't take longer than 1 hr.
Enjoy
Theunis
Enjoy
Theunis
- cprinsloo
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
Hi,
Did mine a few months ago. IIRC I didn't even need a bearing puller, the bearing slid right off. Needed a bench vice though to loosen the lock nut.Half hour job...
CP
CP
1998 Hilux D/C Lexus VVTi
- BeesII
- Town: Vereeniging
Thanks for the replies. You`ve convinced me do it all myself. Nice Saterday moning job whilst SWABO do walkabout in mall.
I paid R 1350 ecl vat.
Cheers
Chris
Cheers
Chris
- Town: pretoria
- Vehicle: Hilux 4y dbcab 1989
- Real Name: Roburt Arnoldi
try and takes photos if you can... i need to do mine as well at some stage
- drew3
- Town: Tuli Block
- Vehicle: '01 Toyota Hilux 4x4 Raider 2.7i DC
- Real Name: Drew
Anybody know what size the locknut is for the IFS?
Sent from my SM-A300FU using Tapatalk
2001 Hilux 4x4 Raider 2.7i DC
- Dadz Toy
- Vehicle: 95 Series Prado - Diesel Dog
- Real Name: Richard
- Club VHF Licence: HC 286
drew3 wrote:Anybody know what size the locknut is for the IFS?
SFA is 24mm, should be the saam.
Rich
Rich
- Dadz Toy
Can they do this on the vehicle too, I've heard it said..TJV wrote:Hi Bees
If you find that it vibrates remove the whole shaft and take it to a propshaft repair shop so that they can balance it.
Enjoy
Theunis
Rich
Rich
Be sure to mark the positions of everything you take apart, especially the slip-joint - one spline out and you will have vibration because the phasing will be out - (the "cup end" of each universal at either end of any section of shaft must be oriented at 90° of each other). Even with the ends at 90°, you can still be 180° out of the original balancing position, so mark it well.
- Dadz Toy
I changed mine last week, but before I marked the corresponding spline, in my hast, I gave it a healthy tap with my resin hammer and it shot off hitting me in the face, so I not only have a chipped front tooth but a vibrating propshaft!Mud Dog wrote:Be sure to mark the positions of everything you take apart, especially the slip-joint - one spline out and you will have vibration because the phasing will be out - (the "cup end" of each universal at either end of any section of shaft must be oriented at 90° of each other). Even with the ends at 90°, you can still be 180° out of the original balancing position, so mark it well.
Rich
Rich
Eish! Can't help you much with the chipped tooth ..... resin or gold filling are the only options I can think of.
As for the prop vibration, well if it wasn't vibrating before, then it's probably out of phase or 180° out from the original position. Also check that the centre bearing is properly aligned (propshaft must be in a straight line in the vertical plane).
- Vehicle: Hilux SFA
- Real Name: Rodney
took big hammer to mine and put it back no problems yet until Murphy chirps.
- Dadz Toy
Did you fit a generic or Toyota part?Scott wrote:took big hammer to mine and put it back no problems yet until Murphy chirps.
Rich
Rich
- Real Name: Rodney
generic part
