Steering shaft boot for 01 KZTE d/c 4x4
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Hi Chaps
I have a question for the parts savvy ones amoungst you. Where the steering shaft goes through the firewall towards the steering rack, there is a black metal plate surround with (what looks like a small cv jount cover) that allows the shaft to go through the plate as well as keep water and dirt from entering the cab.
Toyota tells me that one CANNOT buy the "boot" separate and the plate +boot = ZAR850 :evil:
Can someone please point me to another supplier for such a rubber boot, as it is not a safety critical item, I don't mind if it does not come in a packet with a Toyota sticker on it
Thanks in advance.
Thanks in advance.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- subok
- Town: Jhb - Somerset West
- Vehicle: Hilux 3.0 D4D 4x4 D/C - Kitted for overlanding
- Real Name: Kobus
- Club VHF Licence: HC152
Re: Steering shaft boot for 01 KZTE d/c 4x4
Eish - verry old thread. I am looking for the rubber part (boot) for a 2006 Hilux 3 D4D.
Will the R20 Midas universal steering rack boot not work?
- subok
- Real Name: Kobus
I will try this weekend!
- subok
- Real Name: Kobus
I went to Toyota Melrose. The whole unit including the plate is less than R300 !! Ordered.
- louis fourie
- Club VHF Licence: X101
Jan, waar is jy? Ek soek ook een.
- subok
- Real Name: Kobus
Hierdie is vir n 2006 d4d. Johannesburg.
- subok
- Real Name: Kobus
Any advice please on how to replace this item. I have read about keeping the steering wheel in position, but more detail would be appreciated.
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Die ding kom by die "spiral" waar jou hooter en air bag draade op jou stuurwiek in plug. Hy kan net ek dink 5 keer in die ronte draai dan breek hy af (pop huis vol geld) het myne gebreek toe ek die boot vervang het.
Hier is wat ek voorstel as ek reg kan onthou:
1: Lock jou stuurwiel
2: Merk die cupling en die "sliding yoke"
3:Maak die cupling los binne die cab
4:Maak die yoke en boot los
5:Sit nuwe boot op die shaft
6:Sit al die merke weer in lyn en maak alles vas
Hoop ek onthou wat ek moes gedoen het sterkte
- Sliding yoke
- 2014-10-29_144759.png (26.6 KiB) Viewed 1757 times
- subok
- Real Name: Kobus
Drikus,
Baie dankie! ek sal binnekort moed bymekaarskraap om die takie aan te pas.
Kom mens die boute in jou prentjie van onder af of van bo af by?
Btw - waar kry jy die prentjie?
Groete
Groete
