KZTE clutch
WESKUSKLONG
Town: St Helena bay
Vehicle: Hilux KZTE with ARB front locker/Safari Snorkel / 33x12.5x15 tyres / Long range tank / Battery system / Thomas compressor/ 2Engel fridge freezers/Cruise Control.
Real Name: Rudi
KZTE clutch
Post by WESKUSKLONG »
I need some advice on what aftermarket or heavy duty clutch to install on my KZTE because nothing seems to last.
if even tried the genuine Toyota clutch.
The problem is not the clutch that slips but the springs in the clutch plates collapse and then make an very irritating noise.
Some info on the vehicle to get an idea.
2001 Hilux KZTE with 260000km's.
Front mount intercooler with modified turbo downpipe from Francois @4xLux
Front and rear ARB lockers installed.
4" Procomp lift kit with Ironman rear heavy duty leaf springs & Old man emu torsion bars.
2" bodylift
33x12.50x15 Mud terrain tyres on 10j mags.
If anybody can point me in any direction where to get heavy duty clutch.
Thabogrobler
Club VHF Licence: x223
Re: KZTE clutch
Post by Thabogrobler »
Afaik the clutch is 260mm in diameter?
The first Kd also, but then upgrade to a 272mm.
Iirc the 272mm can be fitted but the flywheel needs to be machined. Ask Francois, he should know, otherwise Alan.
Tristin
Town: East london
Vehicle: Toyota hilux
Real Name: Tristin
Club VHF Licence: HC359
Re: KZTE clutch
Post by Tristin »
Evening gents
Exedy does a heavy duty clutch but again your flywheel needs to be machined.A business here in East london sells them and has had many good outcomes🤙
