Hello everyone.
My first post of many. I own a 1989 Toyota Hilux Surf which had its engine changed to a 1KZ engine by previous owners.
I need a replacement diesel injector pipe (from the mechanical pump to nr 3 injector) as what was supposed to be an easy leak fix resulted in the nut's thread being stripped by the guy doing the job. So I got a replacement nut and tried to cut the pipe to replace the nut but the welder brazed the pipe incorrectly.
So now I won't be able to have one made from sample.
What are my options and is there a difference between the electronic and non-electronic pump pipes?
Thanks for any assistance.
1KZ diesel injector pipes
- louis fourie
- Club VHF Licence: X101
Re: 1KZ diesel injector pipes
First check what you will pay at the dealers. I replaced the diesel return pipe some time ago and it was not that expensive.
You can also try N1 4X4. They sell genuine parts
or
Gemini in Joburg, but I don't like going there because of the area.
Sent from my VOG-L29 using Tapatalk
or
- Vehicle: 1989 Toyota Hilux Surf
- Real Name: Prajay
Thank you. Managed to get one at Toyota and Colt Spares on Van Der Hoff road.
