2.5 d4d not starting
DJBasson
Town: Bethlehem
Vehicle: Toyota Hilux
Real Name: David
Post by DJBasson »
Hilux 2.5 D4D blew fusible link.Link was repaired but engine does not start.The diesel pump does not supply feul to the injectors.Can anyone please tell me where to check for power supply to the diesel pump?
Re: 2.5 d4d not starting
Hi David and welcome! :thumbup:
Unfortunately not familiar with the diesels so cannot say definitively where to find it. If you found the fusible link to be blown, then I would assume that you've also checked the fuses in the engine bay. The other places that Toyota likes to hide fuse boxes is behind the kick-panels on the side of the foot wells inside the cab, usually on the driver's side .... then also under the dash behind the glove box - usually against the firewall.
Sorry I can't be of more help, but hopefully one of the diesel guys will be able to tell you exactly. :winkx:
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Post by FIRSTGEER »
Hi David.There is a fuse box behind the removable panel below the steering wheel.This panel just clips into place so it is easy removed.Hope you come right.
Just also wondering .... saw a post here recently in which (if memory serves) the fuse box in the engine bay had to be moved to get to the fusible link. If that's the case, then it might also be possible that one of the connectors in that fuse box became dislodged. Might be worth checking to see that there is power to all fuse clips in the box while ignition is on. :think:
