Let's talk earthing...
- Baasvark
- Town: Virginia
- Real Name: Shane
Besides the obvious problems re starting and electrics, what other effects would there be if your earthing on a DIESEL vehicle was bad..?
Sent from my SM-A720F using Tapatalk
- Town: Reebok Kleinbrakrivier
- Vehicle: 2002 Hilux 2.7i 4x4 s/c + Canopy Caravan; Suzuki Brezza
- Real Name: Brian
Re: Let's talk earthing...
If you have poor earthing and depress the clutch when starting you will eventually destroy your release bearing.
The earth current will always find the path of least resistance and cause some carboning up where it travels which will eventually let you down at the worst possible moment, in accordance with Murphy's Law.
My2cw
My2cw
I don't see how that will affect the release bearing. There is no earth disconnection between transmission and motor when the clutch is used.
Continuity remains through the bell housing and even through the spigot shaft.
- Real Name: Marnus
A bad earth only has to do with electrics and electronics so I am struggling to understand what you are asking. I have seen some very strange and illogical things happening due to bad earth but all ultimately are electric related. A bad earth potentially has everything to do with electric issues. On modern diesels the injection timing is controlled electronically but on mechanical diesel injection systems not. Unless there is an electric diesel cut-off switch.
What are you concerned about?
- Dirka
- Town: Doornpoort Pretoria
- Real Name: Dirk
bad earth = voltage spikes
Ground connections are important for good voltage, and if there is faulty voltage,
the regulator rectifier can run hot and will eventually fail.
If you have the sealed alternator/ generator like me with the regulator inside, say goodbye to lots of $$$$.
You might even blow the ECU or ultimately sit with a burnt out vehicle.
Maybe not a bad question afterall...
- Real Name: Brian
I am speaking from experience with cable operated clutch.
This is one of the reason for my lack of posts someone always knows better
With a cable operated clutch and a bad earth strap between the body and the motor I can see some logic there. The motor and box are insulated from the body by the rubber in the mountings and the suspension / shock bushes complete that isolation. The clutch pedal makes direct contact to the body and transfers that contact to the cable and clutch fork in turn. The fork makes contact at two points, the pivot on the bell and through the release bearing.
So, yes, there is some logic there but I would suspect the the cable ends would be the first to go if the proper earth strap connection is that bad to shunt most of the power through the cable.
What happened in your case and how was it picked up?
- Real Name: Marnus
I don't think Andy was doubting what you said. Just thinking as to how that would be possible. I don't think that he was thinking of a cable operated clutch when posting.
This is very interesting and I would also like to know what happened. On what car was that? I can think that if the earth strap is bad that the current would go through the clutch cable when cranking. Especially on a front wheel drive car like Golf or Opel Kadett. In those instances where the whole cable is metal. Electricity always follows the path of least resistance.
- Baasvark
- Town: Virginia
- Real Name: Shane
Interesting opinions listed so far...
Here's what I experienced:
Starter turned over with a little difficulty. This increased somewhat when I started with the clutch engaged...
Of course at the time I wasn't aware that the earth wire to the engine was totally loose.... as in hanging freely.
There are other wires earthed to the chassis as well so that's why it still started.
What I found interesting was that I had been experiencing a little less power. To the point where I wondered if my turbo was packing up....
This all disappeared when I rectified the earthing problem.
But my kz motor has a manual diesel pump - so the power loss doesn't make sense?
- Real Name: Brian
No idea what happened to my explanation re what happened. Maybe Mods deleted.
That's it I'm out !!
I don't see anything that was deleted in the admin log .... also don't see a reason to delete something that could be useful to someone.
I've had the experience from time to time where I thought I've posted something and it's not there. Either I've omitted to "submit" before returning to the topic or I've returned too quickly before the submission has completed.
If it's not too much of a hassle, please submit again. I was really wanting to read it. Thanks.
- Real Name: Marnus
Very interesting. Does the KZTE not have an electronic fuel cut-off valve that may not have been opening properly or slightly less causing slightly lower injection pressures?Baasvark wrote: ↑Wed Nov 07, 2018 9:17 pm Interesting opinions listed so far...
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
Brian if you are this easily offended then the internet is definitely not the right place for you.brianc wrote:No idea what happened to my explanation re what happened. Maybe Mods deleted.
Trust me this is the "friendliest" forum I'm part of and Andy is by far one of the best meaning good hearted posters on any forum.
We all learn from a good debate , and a far out point of view is usually one that get most of thinking again and in process everyone gets to learn something
Sent from my Redmi 4X using Tapatalk
- Jaws
- Town: Sharonlea
- Real Name: Herman
The black wire needs to be at least as big as the red wire.
I have seen installation where huge positive wires are installed and then negative is done with a wire less than halve the size .
- Baasvark
- Town: Virginia
- Real Name: Shane
I actually don't know. But I did away with the original wiring harness.Mars wrote:Very interesting. Does the KZTE not have an electronic fuel cut-off valve that may not have been opening properly or slightly less causing slightly lower injection pressures?Baasvark wrote: ↑Wed Nov 07, 2018 9:17 pm Interesting opinions listed so far...
Jou SFA nou 'n Kz in? D4D plan nie gewerk nie?Baasvark wrote: ↑Thu Nov 08, 2018 4:25 pmI actually don't know. But I did away with the original wiring harness.Mars wrote:Very interesting. Does the KZTE not have an electronic fuel cut-off valve that may not have been opening properly or slightly less causing slightly lower injection pressures?Baasvark wrote: ↑Wed Nov 07, 2018 9:17 pm Interesting opinions listed so far...
- Baasvark
- Town: Virginia
- Real Name: Shane
Ongelukkig nie. Nie met 'n meganiese pomp nie..... En ek wou nie die elektronika gehad het nie.Thabogrobler wrote:Jou SFA nou 'n Kz in? D4D plan nie gewerk nie?Baasvark wrote: ↑Thu Nov 08, 2018 4:25 pmI actually don't know. But I did away with the original wiring harness.Mars wrote:Very interesting. Does the KZTE not have an electronic fuel cut-off valve that may not have been opening properly or slightly less causing slightly lower injection pressures?Baasvark wrote: ↑Wed Nov 07, 2018 9:17 pm Interesting opinions listed so far...
- louis fourie
- Club VHF Licence: X101
+1Dirka wrote:bad earth = voltage spikes
Lost my ECU and valves on the diesel pump when I replaced the KZTE's clutch some 10 years ago. I removed the engine and when putting it back the earth from the chassis to the engine was loose. A R3000 job costed me R21 000.
In the mean time I got myself a transmission jack.
Sent from my HUAWEI VNS-L31 using Tapatalk
