MAKING AND INSTALLING A FRONT WINDOW SUNSHADE
Members' DIY projects
JAMES399
Vehicle: Toyota Hilux 4x4
Real Name: JAMES
Post by JAMES399 »
I drive home every day facing the setting sun. My sun visors don't cut it, so I decided to install a window tint sunshade on my windshield. I had sunshades on my previous trucks installed professionally, and I hated the way they looked. Just like the truck in this forum's homepage, the shade was curved along the bottom instead of being straight. My '87 hilux was the same way.
With a curved glass, the shade needs to be fitted to the glass to get a straight bottom line. I got some brown wrapping paper, and taped it to my truck
Then i traced an outline of the top of the front window, and cut the tracing out.
On my bench, I found the center of the tracing, and measured down 6.5 inches. I did the same thing 32 inches to either side of center. Then using a 108" steel CB whip antenna as a guide, I clamped it directly over the marks on the tracing, and scribed a line along the antenna.
I cut out the tracing, taped it to a piece of window tint, and cut the tint to size.
Installing the shade was easy, and the final result was exactly what I was looking for.
I thought I would post this just in case any of you guys want to give it a try
- JAMES
pieta.swanepoel
Vehicle: 2017 Toyota Hilux 2.4 GD-6 SR 4x4 SC
Real Name: Pieta
Re: MAKING AND INSTALLING A FRONT WINDOW SUNSHADE
Post by pieta.swanepoel »
Thank you, James. Easy enough to do yourself
Post by Mars »
Good post thanks.
Dowe Koos
Real Name: Hennie
Post by Dowe Koos »
Baie netjies
Return to “Build your own:”
