2013 SRX 16''steel rims and tires sizes
- pieta.swanepoel
- Real Name: Pieta
Hallo,
question regarding tyres for my 2013 SRX with OEM 16' steel rims: what would be the widest recommended tyre one should fit on these rims?
Spec is 205/80R16, alternative is 235/70R16
I would like to fit decent tyres with 75 or 80% profile and stronger sidewall, but am not sure if it will fit the steel rims? Not really looking for wider but higher. And not really looking for a lift either.
245/75R16 tyres seem to be more available?
Else, I should start looking for mags
Thank you
Pieta
Thank you
Pieta
- Town: Stellenbosch
- Vehicle: 2.5 d4d 4x4 Hilux
- Real Name: Hendrik
Re: 2013 SRX 16''steel rims and tires sizes
Hi Pieta
Stel jy nog belang om mags op jou bakkie te sit?
Ek het tans "16 x 8.5 zero offset Aline Rims" op my bakkie. Ek sal verkies om dit terug te verander na die staal rims toe.
Indien jy belangstel kan ons dalk ruil.
- Town: Mooi River KZN
- Vehicle: 96 SFA D/C 4x4 2.4
- Real Name: Malcolm
I got a set of second hand 15" toyota rims and put the 31" tyres on. When I had my hilux . Or else just go with the 245/70 R16 .
2.4 1996 SFA D/C
2.5 2015 hardbody 4x4 S/C
2013 Everest 4x2
2.5 2012 AWD Kuga(SOLD)
yz250 2 stroke
tw 200 farm bike
2013 Everest 4x2
yz250 2 stroke
tw 200 farm bike
- pieta.swanepoel
- Real Name: Pieta
Hendrik, 8.5" wydte rims is te wyd vir my. Soek iets soos 7" want is op soek na hoer profiel band. En dan moet ek breer band ook vat. Miskien is 15" rims die beter opsie
- Town: Roodepoort
- Vehicle: Isuzu KB320
- Real Name: Garreth
I've got a set of 16 inch rims (they are LX Isuzu rims, very well sort after and 265 75 16 BF muds.pieta.swanepoel wrote:Hendrik, 8.5" wydte rims is te wyd vir my. Soek iets soos 7" want is op soek na hoer profiel band. En dan moet ek breer band ook vat. Miskien is 15" rims die beter opsie
Send me a message if you keen for them .
- Hilux Heap
- Town: Brakpan
- Vehicle: '93 Hilux Raider 4x4 DC. Basic offroad frt bumper with Warn Tabor 9k winch, Roll bar, Towbar, std half door fiberglass canopy with roofrack. 2x 65 lt fuel tanks, 31x10.5R15 HT tyres
- Real Name: Andre
Hi Pieta,
I have the 15" white rims on my 93 Hilux DC 4x4. Running 30x9.5x15 BFs (245/70/15). The BF has a higher sidewall than the Wrangler and the Coopers. Might be what you are looking for. The 9.5 is only 245 wide and sidewall180mm high. You can even try the 31x10.5x15 BF (265/15, wall 200mm) or 32x10.5x15 BF (265/15, wall 210mm).
Hope this helps.
Hope this helps.
You only have ONE LIFE!! Live it........................... with a Hilux!!!!
Piet ek dink nie die 15'' pas op die 2010 en ouer Vigo's nie.
My SRX, 2010 model, het uitgekom met 16'' staal rims.
Ek het later 245 bande opgesit
- Vehicle: Toyota hilux 2.5 D4D 4X4 DC SRX
- Real Name: Leon
Hi i have 16" steel rims if you are interested
send me a pic of you rims if you still have them
