Alternator Light stays on
Introduce yourself and Meet the rest of the crowd
Sudesh
Town: Midrand
Real Name: Sudesh
Post by Sudesh »
Hi
I drive a 2005 3.0 d4d and had a problem with the battery, was old over five years, recharged the battery and no luck, the alternator light came on, so replaced the battery, the light was still on and then died permanently. Checked if the alternator was charging on luck, replaced the regulator alternator light came on and refuses to go of please help do i need to replace the alternator.
Re: Alternator Light stays on
Post by CasKru »
It's either your charge indicator wire not connected to the alternator or your diode pack in the alternator has gone.
Sudesh
Town: Midrand
Real Name: Sudesh
Post by Sudesh »
it is not charging checked it out, i will look at the diode pack, do you know if they sell this as a replacement
Post by CasKru »
I found a replacement for my one at a Battery Center but that said I have an older van
Also think it's the diode pack. Try Diesel electric.
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Post by FIRSTGEER »
I had a similar problem with my older d4d (2006 2,5 ) and found the problem with the wiring loom which runs across the bottom front of the engine.The wires had got brittle with age and one of the wires broke off.I simply soldered a small piece of wire to join the brocken wire so not to have any strain on the joint.My electrical fault was on the passenger side of the loom under the engine front.
I hope you come right. Good luck.
Sudesh
Town: Midrand
Real Name: Sudesh
Post by Sudesh »
Hi
Thanks for the advice cheched all out, problem was still there managed to get another alternator original changed it today and fault was gone so i ahd a bad alternator.
thanks
Return to “Meet the People”
