Help please fire on dizzy trouble
- MonsterLux
- Town: Witbank
- Vehicle: 92 Toyota Hilux
Morning gent hope some off the slim manne kan help me.
My lux worked with no problems next morning he didnt want to starts. I have no fire on any four plugs. The main wire from the coil to the dizzy has fire. Can the two components in the photos just stop to work?
Re: Help please fire on dizzy trouble
It's possible the firing module(usually a TP100) is fried, or not earthing properly again the body. That black wire that's been cut is definitely very important. It's the "proper" earth for the firing module. Often a body earth is not good enough and makes the unit overheat and die in time. First try wiring it back up to the batt negative to make sure you have a proper earth.
- MonsterLux
- Town: Witbank
Hi Mr B
Thanx for the feedback. Since I bought the lux the earth was cut and it worked perfectly. This morning I gave it earth to the batery and still no luck.
- LouisZ
Check the dizzy cap. Look inside, is the carbon contact still good/missing?
Check the rotor for burns on the tip and the centre. ----
- MonsterLux
- Town: Witbank
Hi louis
The rotor tip is in great condition and the carbon tip in the middle togheter with the four brass contacts.
My educated guess is then a burnt out TP100. Johan even if it turns out not to be the fault, it's a part thats really worth having in the spares box in our bakkie. Those firing modules are notorious for killing over when you least expect it. BTW, Dicktator make a pretty smart one...
http://www.dicktator.co.za/ignitermodules.html
- MonsterLux
- Town: Witbank
Okey so i replaced the electronic ignition module with a new one and still no fire. Not even on the main coil wire that goes to the dizzy. Swoped the old one back to check and now it is dead also.
When i ground the new one i get a continious spark on the small negative terminal on the coil. Any sugestions?
- MonsterLux
- Town: Witbank
When i check the ohms as per picture i only get a reading on point 1&2 on the old and new one
Have you tried another distributor cap or rotor? Maybe try testing the rotor and cap points for continuity with a multi-meter. Maybe the circuit is burnt or cracked where you can't see it.
- MonsterLux
- Town: Witbank
Mr B
I will try that next the main thing now is i dont get fire on the coil where this morning i had. Can this be a earth problem even if everything is grounded?
- Real Name: Marnus
Meet jy 12 volt op die positief van die Coil? Miskien moet jy die Coil direk van die battery af krag gee om te toets.
