Monroe Shock Part#
- raider
- Vehicle: 96' Hilux Raider 2.4 4x4 SC, 12' Mitsubishi PJS 3.2 4x4
- Real Name: Zubair
Monroe Shock Part#
Using the Monroe catalogue I compiled this table. This is for the Monroe Gas Magnum shocks.
- Monroe shocks.PNG (10.09 KiB) Viewed 2092 times
- Town: Swellendam
- Vehicle: 2005 3.0 D4D D/C
- Real Name: Helgaard
Re: Monroe Shock Part#
Hi SFA owners , hope someone could shed some light.
I am rebuilding a '92 D/C. Monroe AU 161702 will be too short , I think. The shorter(50mm) shock will pull the suspention down by about 15 mm.
So if I use AU 161702 , there will only be 35 mm of extention left.
If I am to drive over an obsticle the shock on the other side will reach the end of it' travel and pick the wheel up from the ground. Is this normal ? Would the shock not get damaged ?
Might it be that the leaf spring are not std.
- Town: Swellendam
Any other shock I can try.
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
I Fitted Gabriel Land Cruiser shocks on my SFA.Baby Cruiser wrote:Any other shock I can try.
Google the specs of the Monroe L/C shock, it might be the better option.
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
- mcw
- Town: krugersdorp
- Real Name: Martin
- Club VHF Licence: X100
Hi Helgaard
Contact Mikem Suspensions they fitted L?C shocks (Gabriel) to my SFA 3 years ago ,have worked fine ever since
if you use SFA as daily driver ,you could fit the more expensive Bilstein shocks
Martin
Martin
- Town: Randburg
- Vehicle: Hilux 2.4 Raider, Suzuki SJ413, Landcruiser FJ40
- Real Name: Murray
I also have the LC Gabriel Safari,(gas) on my SFA. I find the ride as a result quite hard. My Brother has the Old man Emu, non-gas, much softer ride. So the question is who can supply the Gabriel safari equivalent without the gas pressure? Monroe maybe? OLD man Emu are pricey
