SFA import rear wheel bearings
- Club VHF Licence: X93-
Can someone help me with the rear wheel bearing nrs on the SFA import? T think I will get it much cheeper from Timken or SKF bearings than buying it from the stealers.
Re: SFA import rear wheel bearings
I recall that bearing numbers were posted a few years ago but when I did a search all I came up with was bearing numbers for the IFS. The SFA bearing numbers might well be mentioned somewhere but might need different search criteria from what I used.
Maybe someone here knows. If worst comes to worst, you might have to pull the shafts and get the numbers off the bearings themselves. Good luck.
Dawie, contact Louis at 4x4MW Menlyn. He changed Bulldog's bearings a few years ago and should be able to help you.
- Vehicle: Hilux SFA
- Real Name: Rodney
Dawie I done mine about 2 years ago and went to local spares shop and they gave me choice between different makes.I did have the shafts out and as far as I know the Taxis ran the same diff.
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
Dawie, op een van my ou wheel bearings wat ek uit gehaal het staan 6308 2rs, seel se nommer is 49001 en op die houer staan 376m b/kit
hoop dit help.
hoop dit help.
Nico
Kom daardie bearing van die import diff af?
- Vlak vark
- Town: Phalaborwa
- Real Name: Nico
yup Dawie, import diff.daai bearing afgehaal van side shaft wat laas gebreek het. moet nie die collar vergeet nie.
Thanx Nico
