Hi Guys,
I would like to cut out as much as possible losses between my alternator and the battery. I am thinking of installing a wire directly from the alternator to the battery. Which one do I use? The thick white one, or the thinner yellow one.
Regards
Andre
Better charging
- Tonto
- Town: Paarl
- Vehicle: 96 Hilux 2.4 efi DC SFA, Gomad canopy,
- Real Name: Andre
Better charging
- WP_20141217_12_33_42_Pro (Copy).jpg (37.83 KiB) Viewed 1288 times
Re: Better charging
By default you have a cable running directly from the alternator to the battery.
If you are having charging issues chances are your earth connections need to be cleaned and tightened again
- Club VHF Licence: X93-
Re: Better charging
You can also check this link from Cassie.I did that with my alternator and is very happy with it.
http://www.hilux4x4.co.za/hilux-alternator/index.php" onclick="window.open(this.href);return false;
- Tonto
- Town: Paarl
- Real Name: Andre
Re: Better charging
Thanks Guys,
Do you know the function of the 2 wires?
