Flashing Diff Lock Warning Light
Opsmedic
Town: Port Elizabeth
Vehicle: 2001 Hilux KZ TE 4x4 D/C and Suzuki SJ413
Real Name: David
Club VHF Licence: HC 308
Post by Opsmedic »
Hi All
While travelling from Mthatha today with my work bakkie a V6 Vigo the Diff Lock light kept flashing (green). When I stop and switch off it goes away but after driving a while it starts again. I did not go off road and the Diff Lock switch is in the disengaged position. I did some tight turns on loose gravel but it does not seem like the Diff Lock is engaged. Anyone experienced this before?
Dave
Re: Flashing Diff Lock Warning Light
How is the Vigo's locker actuated? Vacuum? Electric?
Post by Mars »
Hy is elektries. As die liggie flits beteken dit die knoppie is gedruk maar die ewenasr slot het nog nie gesluit nie. Dit is nou as daar nie 'n fout is nie. Ek vermoed daar is iets fout met die skakelaar of hy kry 'n kortsluiting by die drade onder op die diff wat hom aanskakel.
David. I would unplug the switch from the harness to see if the light still continues coming on. If it does you must have an issue with the wiring causing a short closing the circuit which engages the difflock. Chech the conition of the plugs and the wires on the diff while you are at it.
Opsmedic
Real Name: David
Post by Opsmedic »
Dankie Marnus ek gaan dit probeer
