2006 Opel Astra Essentia - please help
- Donkey
- Club VHF Licence: X122
Hi
A friend has an Opel with 105k km's on the clock, only due for service in about 5000 k's. In the morning it only starts when petrol pedal is depressed and idles irratic, but once engine is warm after about 5 mins idling comes right and no hassles after that. Has anyone has any knowledge what it could be or know a Opel mechie in the East Rand area?
Thanking you in advance
Tumelo Maketekete
Re: 2006 Opel Astra Essentia - please help
LION matches!!!
- Donkey
Must it be Lion? Or ant other brand will do? Reminds me of a joke - what do you call four Afrikaans okes in a box? I've told this one before.
Tumelo Maketekete
- Real Name: Marnus
Most of these "modern" cars have rather complex vacuum tube systems (If I can call it that). i.e. lots of little tubes going to all kinds of little valves. I have found on cars that are getting a little older that those tubes start perishing or are damaged by technicians when servicing the car and those vauum leaks can cause erratic idling etc. It is very quick and easy to simply check all those vaccum hoses and to replace those that look suspect.
I have had three cars where replacing these tubes made a huge difference.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
I agree with Marnus.
It sounds like it has something to do with the cold idle setup - could even have to do with the air flow sensor related.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Donkey
Thank you for the input guys, will look at these pipes nicely and hopefully it's that
Tumelo Maketekete
- SWARTLUX
- Town: Gauteng
- Vehicle: '05 LEGEND 35 2.7 DC 4x4, Monroe Gas allround, Long range tank, UniQ Chip. Platkar '06 Polo 1.6 Comfortline hatchback
- Real Name: Brain
Try cleaning the idle control sensor aswell with carb cleaner had the same issue on a gsi corsa cleaned the idle control vlavle and problem dissapeared definatly a problem with vacuum and idling sensors.
- Donkey
Thanks Brian, where would this sensor sit? Any pics maybe, please.
Tumelo Maketekete
- SWARTLUX
- Town: Gauteng
- Real Name: Brain
Usually near the throttle body dont now where the opel essentia one sits but asume it would be the same place
Refer to pic A and B below A shows approximate position of sensors just note this may change due to model and engine.
B depicts the sensor you are looking for it will have a cable plugged into it and the senor is fixed under the throttle body just check the part where the connector gets plugged into is the only part you will see
- Donkey
Much appreciated, will give feedback when it's done
Tumelo Maketekete
