Hi All
Can anyone please help
What is the distance between the bump stop and the chassis supposed to be ,and what is the max you can go ,
what is the correct gap on a 2 inch lift and a 4 inch lift Hilux SFA
Advice please
Bump stop distance
- Town: Ellisras
- Vehicle: Toyota 2.2 93
- Real Name: Gary
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Re: Bump stop distance
what car are you reffering to? Hilux IFS?offroad nut wrote:Hi All
Advice please
A 2" lift is neither here nor there IRO the bump-stop .... wouldn't give it a second thought, but IRO a 4" lift I would check with the spring manufacturer / agent / supplier. Most of them will probably tell you that it's OK to stay with the originals, which gives you that extra bit of travel. OME don't recommend any interference with the bump-stop and I see that the Dobinson's kit I have also still uses the originals.
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
IMHO the bumpstop should be set so as to stop the spring from arching overly negatively. I suppose for maximum longevity the springs shouldn't bend into negative arch at all, but that'd be no fun!
Other than that, if you're not running into interference with engine sumps, steering arms or wheel arches I say run em
- Town: Ellisras
- Real Name: Gary
The gap at the moment is about 100 mm with the OME leafs ,so if i fit a 4 inch it should be about 150mm or must i fit extra block on the chassis to keep the gap the same
Vehicle is a 93 SFA Hilux
- Toybox
- Vehicle: Hilex
You shouldn't need to make any differences as far as I can tell
- Town: Ellisras
- Real Name: Gary
