stEFi
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
- Club VHF Licence: X107
stEFi
So I decided to jump at the opportunity that presented itself and bought an EFi setup complete with optical dizzy, coil and Dicktator.
Apart from work, also the reason why I didn't go top Hennops, as the carb setup has been sold and being collected tomorrow :problem:
Stripped all the Fatti's & Moni's as well as the original dizzy Sat afternoon quickly.
Sun afternoon finished the gasket & fitted the bottom part. Also hooked the water pipes that pass through the manifold, except for the thermostat bypass, still need a flexible hose as the original won't fit as well as I would like it.
Then test fitted the top part & modified the hydraulic pipe going from the brake booster to the left caliper to make room for the "branch" for cyl # 4.
Tonight:
Clean tappet cover
Fit optical pickup dizzy + harness
Fit gaskets for top half & bolt down.
Any tips/contacts on an HP pump (preferably Bosch) are welcome. Diesel Electric wants R1500 for the 3 bar universal pump, too rich for me...
Tonight:
Clean tappet cover
Re: stEFi
stEFi
Coming along nicely. Stef!
- Jaco Versfeld
- Town: Western Cape
- Club VHF Licence: X69
Re: stEFi
I got a (High Pressure) HP fuel pump for my 4y from Goldwagon, think it was originally for the VW Kombi/Caravelle. It is still working good after 3 years.
Stef wrote:So I decided to jump at the opportunity that presented itself and bought an EFi setup complete with optical dizzy, coil and Dicktator.
Tonight:
Clean tappet cover
- Jaco Versfeld
Re: stEFi
Hi Cassie,
Ek het ook 'n 6 bar in, net 'n vragie, is die 6 bar nie te sterk nie - ek het iewers gehoor/gelees dat die 6bar dalk kan overfuel en die fuel regulator onder stress sit
CasKru wrote:Stef... gaan met 'n 6bar Bosch. Myne het 3 jaar terug so R650 by Autozone gekos.
Re: stEFi
Dit is waar jou fuel pressure regulator inkom. Myne reguleer hom op 3 bar en sy overflow gaan in die surgetank in.Jaco Versfeld wrote:Hi Cassie,
Mens wil nie 'n pomp of enige device aanhoudend vir meer as 80% van sy dudycycle hardloop nie.
- cprinsloo
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
Re: stEFi
Dis belangrik dat jy of 'n surge tenk met 'n Facet pump loop, of 'n HP pomp binne in die tenk sit of dalk die pyp van die tenk na die pomp heelwat dikker maak (12 mm). Daai HP pompe hou nie van suig nie, as jy hom hoor cavitate gaan hy nie te lank hou nie. Koop maar 'n goeie pomp (Bosch, Walbro etc), dan hoef jy nie weer te worry nie. (Raai uit watse ervaring praat ek?)
As jy jou dissy en engine timing mooi wil instel, kry nog 'n dissy cap en boor 'n gat regoor binne no 1 HT draad, merk die rotor met Tippex dan kan jy mooi sien wat in die dissy aangaan met 'n timing light. Dis nogal belangrik om alles mooi opgelyn te kry.
Voorspoed!
Voorspoed!
1998 Hilux D/C Lexus VVTi
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Louis het vir my gesê 3 Bar...maar ek hoor wat Cas sê...
Het by Goldwagen gekyk, hulle het net een vir Citi 1.4i (4 bar) en 'n BMW ene, altwee in-tank.
Wil wegbly van surge tanks af; die plan is om "in-tank" te gaan of 10mm pyp uit tenk uit met external pomp. Wil ook die oorspronlike pype in die chassis af vervang met 8mm.
Kan 'n 4 bar Denso pomp kry vir R600 maar dis ook in-tank...sal so 'n pomp werk op die SFA tenk? Daar is mos gewoonlik so holtetjie in die tenk waar die pomp staan...
- LouisZ
Re: stEFi
Kyk by die Midas by 18de laan, die 3 bar Universal Bosch(Inline) pomp sal daar so R1195 wees Stef. Kry maar oordentlik.
Chris het jy reggekom so met jou dizzy?
- cprinsloo
Re: stEFi
Hi Louis,4x4megaworldpta wrote: Chris het jy reggekom so met jou dizzy?
Ja, dankie. Die timing is 100%. Al wat ek nog kan dink is dat die vloei dalk nie goed genoeg is teen hoë spoed nie. Sal nog 'n extention pyp bou om te kyk wat die druk is teen hoë spoed/load. Dalk oortuig ek myself om die probleem op te los met 'n Lex......
My fuel map gooi bietjie meer as Cassie s'n op hoë load, so ek kan nie dink dis dat dit te lean is nie. En voor die dyno was die fuel skynbaar bietjie lean, maar toe het hy lekker geloop.
Cheers,
C
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Jy't my gesê laas ja, kon nog nie daar uitkom nie ( jy praat van 18de laan innie Moot?), die local Midas by my het net Huco en dan is dit ook nie HP nie. Ek glo ook maar aan Bosch, alhoewel Denso is ook baie goed IMO.4x4megaworldpta wrote:Kyk by die Midas by 18de laan, die 3 bar Universal Bosch(Inline) pomp sal daar so R1195 wees Stef. Kry maar oordentlik.
Moet eeen kry die week, wil by Saterdag die enjin start
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Making good progress, mainly due to the setup coming off a working 22R conversion.
Last night I fitted the dizzy, coil & harness and mostly did some figuring out.
The main hold up now is the water hose, need to fit that before fitting the plenum chamber; then I can do the brake booster & breather setups.
Some mods to be done to the harness & coil, do not quit like the setup here:
- Willied
- Town: Witbank
- Vehicle: '90 Hilux
- Real Name: Willie
Re: stEFi
Hier is 'n link vir nog opsies op pompe.. Die mense is ook baie hulpvaardig oor die foon..
http://www.spitronics.co.za/cms/prices.php
Ek het die external 3bar Bosch, werk baie mooi!
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Nee kyk die ou met wie ek gepraat het is seker maar nuut...volgens hom hou hulle glad nie external pompe aan nie....Willied wrote:Hier is 'n link vir nog opsies op pompe.. Die mense is ook baie hulpvaardig oor die foon..
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Very little progress last night...
Fitted the water hose and dismantled the harness to re-route the wires the way I would like. Stripped the plug from the orinigal ignitor so that I can do the coil ignitor hookup without cutting into the original harness.
Today sourced a new AMP connector for the TP100 hopefully I'll have it tomorrow; this will get rid of all the joints on the ignitor plug.
- Jaco Versfeld
Re: stEFi
Dit is seker beter om external te gaan. Kan dan 'n ekstra pomp saam ry, en as die huidige ene kalf, is dit vinnig om om te ruil ...
Stef wrote:Louis het vir my gesê 3 Bar...maar ek hoor wat Cas sê...
- Club VHF Licence: X93-
Re: stEFi
Hi Stef
Hoe vorder jy met jou EFI?Start jou bakkie al?
- Rooies
- Town: Strand
- Vehicle: 1994 2.4i (22RE) D/C Raider 4X4
- Real Name: Rudi
Re: stEFi
Dit lyk goed, jy het baie moed om dit self aan te pak. Wanneer start hy. Myne dink ek is meeste van die klein probleempies nou uitgesorteer en n mens kan nie glo hoe lekker loop hulle met n EFi nie.
ROOIES: 1994 2.4i (22RE) Raider D/C - 200 000kms - Brospeed Branch & Powerflow Exhaust
MIKEM Suspension & Gabriel Safari Shocks - "31 BF Goodrich AT - GOMAD Aluminium Canopy
Melvill & Moon Seat Covers - Safari Snorkel - Bushwakka Weekender Offroad Trailer
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
So 5 draaie toe start hy Timing is nie 100% nie maar het nie kans gehad om verder te speel nie.Lollie wrote:Hi Stef
Het Vrydag middag 'n petrol pomp gekry in die moot, en gister oggend moes ek gou 'n paar "odds & sodds" kry by die Autozone. Het so 11h00 begin en die plenum opgesit en vasgemaak, al die vacuum/breather pype gemaak en opgesit en die ignition draad en fuel pump drade gekonnekteer en in die sleeving ingetrek.
Na dit moes ek 'n plek in die dash kry om die ignition op te tel, dit het die langste gevat . Daarna gou 'n blanking plate gemaak vir die gat waar die meganiese pomp was en voilla...
Pomp nuwe drade vir dizzy/ignitor. Moet nou alles sleeve nou dat ek weet dit werk
managed to keep the original brake booster pipe setup with tee for the diff lock
uitstaande:
1)die pomp mount en die tank mod doen (10mm feeder).
2)die timing 100% kry
3)die harnas ordentlik sleeve van die Dicktator harnas af tot by die dizzy.
4)die connectors ook verander op die dizzy & TP100.
5) Dicktator monteer in die dash
6) Dyno
Re: stEFi
Bly om te sien jy vorder so goed.Glo my jy gaan nie n dag spyt wees nie.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Beter nie wees nie, my carb en alles is klaar verkoop Loop al klaar stiller as met die carb setup ten minste.Lollie wrote:Bly om te sien jy vorder so goed.Glo my jy gaan nie n dag spyt wees nie.
Re: stEFi
So far so good Steff!! Almost there!
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Been working late at work so far this week, but managed to get the timing real sweet Had to advance the rotor on the dizzy by moving it to the next slot and turn the housing to the sweet spot.
Now busy fitting the Dicktotor into it's final position....
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Didn't get much done over the weekend, but managed to finish a few things....
Modified the the feed from the tank to 10mm ID
While I had the tank out I gave a quick once over with the spray gun
Made my own bracket for the Dictator; the setup will be completely hidden behind the console
Had a new steel fuel line made at the hydraulic shop yesterday and replaced the original one running along the chassis. Pics to follow.
Also made a bracket for the fuel pump, will finish that tonight
- cprinsloo
Re: stEFi
Mooi man. Dit gaan jou groot satisfaksie gee as jy klaar is!! (Nou klink ek soos 'n Peter Stuyvesant ad)
Weet jy van watse staal daai tenk gemaak is? (Ek het ook een wat ek nog moet insit, lyk soos SS?)
Cheers,
C
Cheers,
C
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Kan nie wag om die ding te ry nie...enjin loop te mooi...dis nou net die pomp setup wat my ophou...
Die LTD se tenk is stainless myne is nog spotless aan die binnekant
Weet nie van die ouer luxe nie, ek weet die '97 Raiders het nog die kleiner tenk, 65l as ek reg onthou, maar ek weet nie of dit ook stainless is nie.
- LouisZ
Re: stEFi
Wat pla op die pomp setup Stefan? Ek doen dit so, van tank 10mm af na plastiek filter 10mm, van daar af deur 10-16mm adaptor na feed op pomp wat op 'n plaat gemount word, net 'n tipe harde rubber gebruik tussen pomp mount en plaat. Dan fit die plaat op die chassis regs agter onder die agter deur. Van die pomp dan deur die HP filter na intake.
- Fuel pump setup.jpg (86.08 KiB) Viewed 6489 times
- cprinsloo
Re: stEFi
Kwaai, dankie. Ek dink die kleiner tenks is nie SS nie, wou maar net vir interessantheid geweet het waarvan daai Limited se tenk gemaak is. Lekker ry!Stef wrote:Kan nie wag om die ding te ry nie...enjin loop te mooi...dis nou net die pomp setup wat my ophou...
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Nee dit pla nie...dis net die bracket se maak en opsit wat ek nog moet doen voor ek my wa kan ry en dan die air intake se adapter van 65 na 70 mm. Het dieselfde setup soos in jou pic, my bracket is net anders. Wou eers u-bolts gebruik (exhaust bolt tipe met die cradle), maar was bang ek maak die pomp seer. My mounting sit ook onder die agter deur, is die beste plek.4x4megaworldpta wrote:Wat pla op die pomp setup Stefan?
Hier is my bracket; nog een verandering dan sal hy perfek wees Dis gemaak van 57mm pyp wat ek net gesny en gebuig het vir die ore.
- LouisZ
Re: stEFi
Lyk goed!! Line die bracket net met rubber, net dat die pomp stiller kan loop. Dan die Pyp. Kan by Volkspares een kry, dit kos vir 'n 70mm-60mm so R190. Dis 'n swarte.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
All done, except the air intake.
Saturday I went to town to get a few odds & ends, finished the pump installation, recrimped the AMP connector on the ignitor, sleeved everything and taped it up with flame retardent tape.
Drove it around the block and... can feel the difference!!
Pump bracket, added a channel at the bottom for stability: Pump fitted, all sides lined with 6mm foam rubber Invested in a molex crimper, well worth the R245, recrimped all the solder joints
Got a 70 to 63mm reducer elbow as well as a 63 mm elbow. Still need to find 70mm & 63mm steel pipe to finish the air intake (volkspares didn't have)
Re: stEFi
Stef daardie elektriese petrol pomp bracket lyk baie mooi
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Dankie oom D; dis die klas van goedjies wat die meeste tyd in beslag neem.Lollie wrote:Stef daardie elektriese petrol pomp bracket lyk baie mooi
Nou net daai air intake dan kan ek hom laat dyno
- JEEPIE
- Town: Roodepoort
- Real Name: Shaun
- Club VHF Licence: X 43
Re: stEFi
lyk netjies
man wat trots is op sy werk
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Lankal Het iewers op thread genoem..eerste keer gestart die 3de Nov; die Saterdag wat verby is die eerste keer gery en gisteraand weer.4x4megaworldpta wrote:Stef loop hy?
Timing ook nou beter, was nog effe vinnig; het "ge-ping" onder lading. Moes die rotor op die dizzy 'n tand of 2 aan skuif vir 'n beter "range" maar dis nou so te sê 100%.
Min tyd gehad die laaste 2 weke agv 'n groot projek by die werk, maar alles is gesleeve, getape, die radio console is aan mekaar en sommer 'n extension gemaak vir die dicktator se serial port ook, so alles is nou klaar behalwe die air intake, het vanoggend die bends gaan omruil vir ander en sommer alu pyp gekry ook so dit sal ook vanaand klaar wees.
Dankie, my vrou reken ek is net vol rioolJEEPIE wrote:lyk netjies
- LouisZ
Re: stEFi
Dit maak 'n verskil ne Stef. Daai ping kan mens ook uitkry om die Trigger angle minder te maak onder die "Main" tap.
Dis net soos jy se, daai klein brackets ens wat mens self maak is gewoonlik die goed wat die lankste vat, mens verander dit maklik meer as 3 keer.
Geniet die EFi!!!
Geniet die EFi!!!
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Alles klaar, idling nog nie lekker nie, maar ek het nie 'n idle control valve op nie. Wonder nog of ek een moet opsit.
Sal bietjie kyk, het die sagteware gedownload. Kan voel daar is potensiaal, sal maar eerder laat dyno volgende week.4x4megaworldpta wrote:Dit maak 'n verskil ne Stef. Daai ping kan mens ook uitkry om die Trigger angle minder te maak onder die "Main" tap.
- cprinsloo
Re: stEFi
Een vraag: daar kom 2 pype van die valve cover af na die manifold toe. Soos ek dit verstaan moet die voorste een voor die throttle wees, en die agterste een na die throttle in die manifold in waar die vakuum is. Joune lyk altwee asof hulle "agter" die throttle is (myne is ook so). Toe myne nog die carb opgehad het was die voorste pyp voor die throttle en die agterste een na die throttle, sodat die valve onder vakuum is.
http://en.wikipedia.org/wiki/Crankcase_ ... ion_system" onclick="window.open(this.href);return false;
Waar is die regte plek vir daai voorste pyp, of gaan dit nie veel verskil maak nie?
Hoop die vraag maak sin.
Cheers,
C
Cheers,
C
- LouisZ
Re: stEFi
Stef die een waarmee ek besig is het 'n soortgelyke probleem, die ICV is nie soseer die enigste probleem nie. Die druk in die sisteem is hoer as 5 bar, so dit beteken die fuel pressure regulator is kapoet.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
cprinsloo wrote:Een vraag: daar kom 2 pype van die valve cover af na die manifold toe. Soos ek dit verstaan moet die voorste een voor die throttle wees, en die agterste een na die throttle in die manifold in waar die vakuum is. Joune lyk altwee asof hulle "agter" die throttle is (myne is ook so). Toe myne nog die carb opgehad het was die voorste pyp voor die throttle en die agterste een na die throttle, sodat die valve onder vakuum is.
Cheers,
C
Voorste ene is net voor die throttle, jy kan die TPS agter hom sien uitsteek Dink nie dit maak 'n verskil nie.
Hy idle mooi as die enjin warm is, net 'n bietjie hoog. As jy die throttle so 'n 'tap' gee dan idle die ding baie laag, wil dan amper vrek. Het gebel vir ICV pryse, maar Goldwagen vra R761...bietjie duur na my smaak...4x4megaworldpta wrote:Stef die een waarmee ek besig is het 'n soortgelyke probleem, die ICV is nie soseer die enigste probleem nie. Die druk in die sisteem is hoer as 5 bar, so dit beteken die fuel pressure regulator is kapoet.
- cprinsloo
Re: stEFi
Ah, OK, sal myne so verander.Stef wrote: Voorste ene is net voor die throttle, jy kan die TPS agter hom sien uitsteek Dink nie dit maak 'n verskil nie.
Maak seker die throttle stop elke keer op dieselfde plek, anders voeter die idling rond. Het jy 'n hand throttle, vinniger om hom op te stel as 'n ICV?Stef wrote: Hy idle mooi as die enjin warm is, net 'n bietjie hoog. As jy die throttle so 'n 'tap' gee dan idle die ding baie laag, wil dan amper vrek. Het gebel vir ICV pryse, maar Goldwagen vra R761...bietjie duur na my smaak...
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Het self gewonder of dit die probleem is...dink die spring trek nie die throttle elke keer terug tot op dieselfde plek nie, miskien is daar 'n probleempie op die kabel. Dis 'n minor om uit te sorteer.cprinsloo wrote:Stef wrote: Maak seker die throttle stop elke keer op dieselfde plek, anders voeter die idling rond. Het jy 'n hand throttle, vinniger om hom op te stel as 'n ICV?
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Woensdag aand het ek weer tyd gehad om te speel...het die sagteware gekry en die laptop gekonnekteer aan die Dicktator.
Nie eintlik veel settings wat mens kan doen nie, het die trigger angle verander en nou loop hy mooi
Sal sien hoe lyk die consumption die naweek.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Took a trip to Warmbaths the weekend of the 25th...man what a difference !
No gearing back to 4th, and there is about a R200 difference in fuel consumption on a round trip. Purrs nicely at a cruising speed of 130km/h.
Last week I sourced an ICV off a Golf II at VW Breakers; fitted it this afternoon.
On the 1st go it revved the motor to 3500 rpm Eventually figured out what settings on the Dicktator to play with & voilla..idling perfect now. Well worth fitting an ICV
- GeorgeJvR
- Town: Louis Trichardt
Re: stEFi
Lekker Stefan nou het jy die pervekte SFA LTD...
Ek mis myne BAIE.
Maar as die IFS verkoop is kan SWAMBO haar nuwe wiele kry en ek my SFA
Ek mis myne BAIE.
Kom wat wil ek bly 'n Bul!
Re: stEFi
Nou maak julle my wonder of ek myne ook moet verander.... :shifty: :shifty:cprinsloo wrote:Een vraag: daar kom 2 pype van die valve cover af na die manifold toe. Soos ek dit verstaan moet die voorste een voor die throttle wees, en die agterste een na die throttle in die manifold in waar die vakuum is. Joune lyk altwee asof hulle "agter" die throttle is (myne is ook so). Toe myne nog die carb opgehad het was die voorste pyp voor die throttle en die agterste een na die throttle, sodat die valve onder vakuum is.
Cheers,
C
Netjiese werk Stef.
- Stef
- Vehicle: '98 LTD
- Real Name: Stefan
Re: stEFi
Ongelukkig nog nie, sal maar die 5l kannetjie moet opkoppel want 80l is net te duur ...en ek het so rondgespeel op die N1 dat daar geen gevolgtrekking van sal kom nie My gevoel reken so 7km/l maar dis seker net om die koste vd conversion te regverdigcprinsloo wrote:Kwaai man!! Jy't nie akkurate brandstof-verbruik syfers nie??
TxCasKru wrote:Nou maak julle my wonder of ek myne ook moet verander.... :shifty: :shifty:
Netjiese werk Stef.
Ja nee, enige dag net so goed soos 'n 2.7i.GeorgeJvR wrote:Lekker Stefan nou het jy die pervekte SFA LTD...
Ek mis myne BAIE.
Het sommer 2 OME blades agter bygesit sodat ons nou behoorlik houding het...
