Suspension upgrade on a KZ-TE
- Donkey
- Club VHF Licence: X122
Hi
I need some advise and please be aware that these ideas are restricted by a tight budget -
In a weeks time the truck is going in for a 40mm body lift - nothing fancy here just to improve entry/departure angles, I am staying with my 31's.
I am also thinking of turning up the torsion bars, in the name of a suspension lift. Will this work and how does it affect normal driving? Will longer shox also help maybe? If so which ones?
At the rear I'm keeping the standard leafs and going the longer shackles route, hopefully Mikem will have. What length should I consider? Bear in mind that an overall increase of 30mm on the suspension for now will be fine for me. Do I stay with standard shox here or put something else longer? If so what?
Will appreciate your thoughts/suggestions.
I heard there's a place that closed down lately, during the Bosvark event, and shox are going for next to nothing. is this true?
Tumelo Maketekete
- Boland4x4
- Town: Plattekloof
- Vehicle: 2005 Toyota Hilux 4.0 V6 DC 4x4 Auto
- Real Name: Jano
Re: Suspension upgrade on a KZ-TE
A simpler solution would be to fit 32" tyres and be done with it. All drivetrain angles stay in OE specs.
Turning up your torsion bars decreases ride comfort on-road and wheel travel off-road (less downward travel because of bump stops). I went the torsion bar route and ended up jumping over most obstacles i.s.o. driving over them.
I doubt you will outflex the rear shocks with the standard leafs, you can try removing a load leaf or two, makes quite a difference.
No mods
- Donkey
Thanx Jano, are 32's a common and readily available size? Are you also implying that there'll be no diff ratio change with 32's?
Tumelo Maketekete
- Boland4x4
- Town: Plattekloof
- Real Name: Jano
Not as common as 31's for sure, but also not expensive. R1930 per tyre fitted for Maxxis Bighorn M/T (tyretraders.co.za)
No ratio change is necessary.
32's + 1" lift on the torsion bars and you will have a very capable rig.
No mods
- Donkey
cool thanx, will advise later which way the cookie crumbles.
Tumelo Maketekete
- Donkey
Any more opinions/suggestions on this guys?
Tumelo Maketekete
32" can be a female dog to get your hands on - Speak to Okkie van Wyk(ovw on forum) and he has 32's but told me 31's are the better option.
You can have the rear leaves re-tempered, but it MAY loose its spring some time in the future. Shackles are a nice, cheap option, but don't over do it - don't know what is max but rather play safe.
Front is a bit more tricky - got mine's torsions set but not very high and the ride is quite harsh, so much that during the last month of the mrs pregancy should did not really want to get in the Hilux! BUT it most likely is not the torsions that's the problem, might be the Camil shocks.
In any case, speak to Darryl at Mikem Suspentions, he is way better qualified on this subject than most of us.
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
If you want quality at a very reasonable price, buy MIKEM leaf springs! Well made (with a long history in the suspension business!) and quality to match! Ride quality (even without load) is good. I promise you I did not regret fitting them to my IFS! If you search, you will find many more satisfied MIKEM customers on THIS site!
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Agreed, and if you plan to leave the Republic, you will have to have them flown in if you need a spare.Thabogrobler wrote:32" can be a female dog to get your hands on - Speak to Okkie van Wyk(ovw on forum) and he has 32's but told me 31's are the better option.
- Donkey
Thabo, Theunis and Thys thank you for your input - to be honest I'm not crazy either about 32's. I'll speak to Darryl and should probably start saving already, eish!
Tumelo Maketekete
- louis fourie
- Club VHF Licence: X101
I'm another satisfied Mikem Customer
- Donkey
Ok guys
Decided that I'll go the ball joint spacer and longer shackles route, for now, so the question is: if the spacers are raising the front suspension by about 38mm, will the standard shock still be usable? I'm guessing the wheel travel is now longer?
Regards.
Regards.
Tumelo Maketekete
- LouisZ
What do you want to space in the front? I think your problem is the back Tumelo. Start with the shackles in the back 1st, your back is already lower than the front, remember if you make the shackles 40mm longer you only get 20mm lift.
- Donkey
Louis the bakkie stands level, I have checked physically,
I'm spacing the ball joints at the front end.
Tumelo Maketekete
- Vehicle: 2002 D/C KZTE 4x4
- Real Name: Robert
Tumelo,
I installed miekm rear springs about 3 weeks ago ,man what adifference I have old man emu shocks all road and std torsion bars that are just turned up slightly. I measured the front droop last weekend and its within the spec that darryl from mikem recommends. my truck aslo now runs level or slightly down hill when empty. ball joint spacers will probably require a longer shock as the distance betwween top and bottom mountings will increase
- Donkey
Thanx Rob
Tumelo Maketekete
- Town: Heidelberg GP
- Vehicle: 2011 Hilux D4D D/C 4x4 (no mods...yet), Hilux 3.0 KZTE D/C 4x4 with minor mods
- Real Name: Rikus
Thumelo,
I had the full Mikem suspension with Bilstein shocks on my KZTE and was VERY impressed.
Apart from 'lifting' the vehicle about 60mm, the ride comfort and off-road performance was magnificent. Travelling mainly on gravel roads coming back from Atlantis last year was especially nice due and gave me much peace of mind.
Having fitted a similar Mikem/Bilstein to my new Hilux and comparing it to my previous Vigo (fitted with OME), I can only say that apart from it being more cost effective, it performs much better than the OME as well (in my opinion of course).
Hope I now totally confused you....
- Donkey
Hey Tjokkie, good to hear from you, you've been very quiet. You're not gonna confuse me, , when fianace allows I will fit Mikem,
Tumelo Maketekete
Hi Tumelo, Mikem's extended shackle is 50mm longer than the normal and should give you about 25mm lift.
see
http://www.4x4direct.co.za/shop/
Remember that Darrell will give you 15% discount if you just tell him you are a club member and give him your forum username.
see
- Donkey
Cool Pieter and thanx
Tumelo Maketekete
- Real Name: Robert
My rear springs cost R5400 and darryl didnt charge for fitment ,he also quoted me R2000 for both torsion bars including fitment, OME torsion bars are alrady about R4000 excluding fitment
I received the spacers. Got quite a shock, had to pay 30% import duties and $45 courier fee.
So the final price is R1,200 (which includes a whopping R100 profit for myself)
There are only 3 sets available
See
http://www.4x4direct.co.za/shop/index.p ... cts_id=234
See
- Donkey
Got the spacers last week already and installed on one side for now, will update soon but so far very impressed to say the least.
Father Christmas must just bring those Coopers and shox
Tumelo Maketekete
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Cool Mine is also in and very impressed.I have a bit more travel now.I still need to get the alignment properly done.The TWT shop struggeld a bitDonkey wrote:Got the spacers last week already and installed on one side for now, will update soon but so far very impressed to say the least.
Nice Donkey, you must tell father Christmas you also need anti-swaybar Disconnects and a front difflock, then your lorrie is unstopable
- george
- Town: Velddrif
You are EVIL :evil: How am i going to explain this to SWAMBOpietpetoors wrote:Nice Donkey, you must tell father Christmas you also need anti-swaybar Disconnects and a front difflock, then your lorrie is unstopable
- Donkey
You see now Pieter? Dis nou die ding met jou, hoe gaan ek begin spaar my maat? Hmmm?
Tumelo Maketekete
- Donkey
You'll have to school me on the anti-swaybar disconnects Pieter, this is Greek to me,pietpetoors wrote:Nice Donkey, you must tell father Christmas you also need anti-swaybar Disconnects and a front difflock, then your lorrie is unstopable
Tumelo Maketekete
- george
- Town: Velddrif
Me tooDonkey wrote:You'll have to school me on the anti-swaybar disconnects Pieter, this is Greek to me,pietpetoors wrote:Nice Donkey, you must tell father Christmas you also need anti-swaybar Disconnects and a front difflock, then your lorrie is unstopable
The swaybar helps to stabalize the vehicle when driving on the road, prevents it from swaying.
But off-road the swaybar limits the downward travel of the control arms.
I do not have a nice picture of the effect, but I see in this month's SA4x4 they explain it very nicely with pictures of a JEEP
The info about these is at
http://www.4crawler.com/4x4/CheapTricks ... connectsV3
- Johannes van die See
A few images.
- Donkey
Thanx Johan for the pics, but what do these help with?
Tumelo Maketekete
- george
- Town: Velddrif
This is what I came up with.Hope it makes sense
You'll find all the answers here........
http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml" onclick="window.open(this.href);return false;
- Donkey
cool will read soon as time allows
Tumelo Maketekete
- Donkey
Last night I got the other side done and please see pics below.
Front driver side - 52.5 cm (before)
Front driver side - 58.5 cm (after) - 6 cm gain
Front passenger side - 54.5 cm (before)
Front passenger side - 60 cm (after) - 5.5 cm gain
Measurements taken from below the wheel arch to the centre of the free-wheel locking hub
Next up of course will be alignment and then the longer shackles at the rear,
Will keep you guys updated on the progress.
Tumelo Maketekete
- Donkey
I read up and it makes sense, how many do you have in stock? It'll have to wait till month end though Pieter.pietpetoors wrote:The swaybar helps to stabalize the vehicle when driving on the road, prevents it from swaying.
Tumelo Maketekete
- george
- Town: Velddrif
nice one. What type of shocks is that?
- swifty
- Town: Sutherland
- Vehicle: Hilux 2.7 SC
- Real Name: Martin
I know that many "experts" will disagree with me, but I recon it is safe to remove the sway bar connects altogether. Before I did the solid axle conversion on my 2.7, I fitted a full Iron Man suspension (torsion bars, leaf springs,shocks and shackles) as well as 32" Coopers. But still the articulation wasn't to my liking. I did a test and removed both sway bar connects. Maybe the 32" tyres and new shocks had something to do with it but I didn't notice any swaying or drifting even at high speed. I even did my own version of the so called "moose test" as well as high speed dirt road testing and the bakkie never felt unsafe. But is it worth the effort? I would say no. I did Babilonstoring trail with the connects removed and in my opinion the gain in articulation was minimal. I still had to use diff lock on one obstacle where the SFA's went without.
2003 HILUX 2.7i SRX S/C; Solid front axle conversion with Cruiser coil springs, 4.88:1 diff ratios, Iron Man rear suspension with extended greasable shackles, Gearmax diff lock, 150 liter feul tank, NudgeM bumper with recovery shackles, BF Goodridge Baja 33x10.5x15 tyres
- Donkey
Let's not go there George came with the bakkie and they must go also.george wrote:nice one. What type of shocks is that?
Tumelo Maketekete
Nice Tumelo
I have two sets of those disconnects in stock but I doubt that they will go very fast.
Tumelo I would first do the rear shackles if I were you. You need to adjust the hight of the vehicle before you can do the alignment. If you do the alignment now you will have to do it again after you changed the rear shackles. Change the shackles, the adjust the front torsion bars so the nose is slightly lower than the rear (about 10mm) and then go for alignment.
Do me a favor and measure the height from the bottom of the rim to the bottom of the wheel arch. Always use the bottom of the rim to the bottom of the wheel arch, it is more accurate than guessing where the center of the hub is.
Martin, yes, there are different opinions about that. Some guys told me you wont feel the difference and others say that the vehicle may have some body roll without the sway bars. Maybe I must test it myself and see because I have not done so yet. I don't want to tell somebody to remove his sway bar and then he makes an accident.
What shocks did you have on yours ?
At the moment my current shocks in front is just long enough for the downward travel with the spacers fitted. If I remove the sway bar the shocks will prevent the control arms from moving down further so there is no use for me to fit the disconnects if I do not fit longer shocks.
- swifty
- Town: Sutherland
- Real Name: Martin
Pieter I had Iron Man Foam Cell shocks. I never checked the travel, maybe that was the limiting factor with the articulation.
- Donkey
Cool will dopietpetoors wrote:Nice Tumelo
Tumelo Maketekete
- george
- Town: Velddrif
must say i had a look at the sway bar connects and personally i dont think it is going to improve to much if you disconnect.You still have that bump stop on the top that will stop the articulation.but it will be good if you can test it Piet
I will jack up my trokkie later today and give feedback
- Donkey
For Pieter:
Previous:
Measurements taken below wheel arch to bottom of rim (265/75x15 tyre @ 2.5 bar):
Driver side: 76 cm
Passenger side: 76.5, both are after ball joints - hope this helps
Previous:
Driver side: 76 cm
Tumelo Maketekete
- LouisZ
Just look at the shocks, it looks if it are at max lenght.
I did not forgot to measure, I just did not have time this week.
I have to replace the front brake pads next week and then will sommer do all the measurements.
- Donkey
:wink2:
Tumelo Maketekete
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
I think there is not much to gain if you do the ball joint spacers and the sway bar disconnects on the IFS, it will make it higher but doesn't help articulation, for that we need to drop the front diff and longer shoks, without this we are going to experience CV axle binding as explained on http://www.4crawler.com" onclick="window.open(this.href);return false;george wrote:must say i had a look at the sway bar connects and personally i dont think it is going to improve to much if you disconnect.You still have that bump stop on the top that will stop the articulation.but it will be good if you can test it Piet
By adding shims to the bump stops you are effectively reducing your downward articulation, BUT IS NECESSARY IF YOU DO NOT LOWER YOUR FRONT DIFF!
Im doing mine tonight and will take some pictures
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
I ve put some ball joint spacers 4 cm and dropped my torsion bars makes a huge difference on my down wards is there any thing spesific i should look at
I am here: http://maps.google.com/maps?ll=-29.619406,31.105969" onclick="window.open(this.href);return false;
Mylux
Mylux
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
donkey what does your van mesure at the back? mine mesured 390mm before the extended shackles and 410mm after that is from the top of the rim to the wheel arch
- Donkey
Will measure and advise you but remember the rear is still standard?
Tumelo Maketekete
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
jip thats what we would like to know, want to see how your kz compares to mine before and after.Donkey wrote:Will measure and advise you but remember the rear is still standard?
- Town: Centurion
- Vehicle: Fortuner 4x4
- Real Name: Frank
Update please
- Donkey
Eish been busy and so forgot, apologies. I can post on Sat morning.
Tumelo Maketekete
