KZTE rear electric window faulty? Help, pls
- Town: Table View - CT
- Vehicle: 4x4 3.0KZ-TE 2002
- Real Name: Lourens
I have problem with KZTE rear electric windows not opening from the relevant door switch.It works 100% from driver door switches, but both rear windows does not open locally(from door switch).
Both went faulty at the same time.Can close with the door switch , but not open.???
Mistery OR is there a quick fix..>>
Any info drawings , etc will help.
THX
Lourens
erasm@netactive.co.za
THX
Lourens
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
Re: KZTE rear electric window faulty? Help, pls
Lourens
Hope this helps. Its the wiring diagram for the windows.
- 031pw.pdf
- Wiring diagram in PDF format
- (43.62 KiB) Downloaded 155 times
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Ali3n
- Town: Roodepoort
- Club VHF Licence: B338
Hi Lourens, I don't know if this may help but my wife had the same problem with her Corolla. We went to Dikhololo for a weekend and we had an ant infestation and somehow the ants found a way into the car and into the window switches. We sprayed the car with doom and cleaned the car but some of the ants died in the switches. This in turn made that the switches made no contact when pressed. Opened the switches and cleaned them out and put them back in. Everything was fine again.
According to my knowledge if everything was working fine before and suddenly does not work then begin with the easiest first. Switches. I would suggest removing a switch which is working and replace with one of the ones that don’t work (plug should be the same) and if that works then you know it’s the switch. If still does not work then all it could be is electrical. A wire might be broken or something but if both back don’t work then might just be switches. Switches wear out over the years and some have a grease like substance inside to prevent short circuits etc and some of this could come in between the contacts so there is no contact. Suggestion is if you are comfortable with opening a switch (a lot of small parts so be careful) then just open it and clean the contacts.
PRESENTLY DISADVANTAGED
- warrenaken
- Town: JHB
- Vehicle: 3.0 KZ-TE 4x4
- Real Name: warren
- Club VHF Licence: X04
- Polarbear2008
Lourens
het jy toe reggekom?
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
- Town: Ellisras
- Vehicle: Hilux KZTE
- Real Name: Francois
Ek sit met die selfde probleem op my enkel kajuit Kzte. Enage hulp of advies sal waardeur word
- Houkswyn
- Town: Parow
- Vehicle: Fortuner 4.0 V6 4X4
- Real Name: Etienne
I had the same issue with my passenger front door. The window wound up but not down.
I opened up the switch and in there are 2 little "plates". One of them wasnt making contact anymore.
I placed them in their correct positions and after that the window wound up and down again.
- pietdevs
- Town: Mosselbay
Lourens my KZ het dieselfde gedoen. Dit was net die skakelaars wat vol stof was. Het hulle uitgehaal en met electric cleaner skoongemaak en niks meer probleme nie. Hoop jy kom reg.
- pietdevs
- Town: Mosselbay
My KZ het dieselfde gedoen. Q20 op die skakelaars gespuit en dis reg. Gewoonlik net stof wat dit veroorsaak. Hoop joune is dieselfde probleem!
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Hi Pieter.moes jy die hele deur paneel uithaal om by die skakelaar te kom?pietdevs wrote:My KZ het dieselfde gedoen. Q20 op die skakelaars gespuit en dis reg. Gewoonlik net stof wat dit veroorsaak. Hoop joune is dieselfde probleem!
- J.C Avis
- Town: Otjiwarongo
- Vehicle: 2002 Toyota Hilux D/c 4x4 3.0 KZ-D-4D. Suspencion lift,160 liter spare tank. Navigator spots. Double battery system. Tour 'trallies'. Spare wheel carrier. Roof rack. Canopy.
- Real Name: Japie
Myne het ook so gemaak,stof,ook contact spray gespuit,als oor. Die swart bracket waarin die switch sit klik net boontoe uit.
J.C Avis
- george
- Town: Velddrif
Gaan dit try.Een van die deure is ook nukkerig by myJ.C Avis wrote:Myne het ook so gemaak,stof,ook contact spray gespuit,als oor. Die swart bracket waarin die switch sit klik net boontoe uit.
Ek het die skakelaar oopgemaak en gevind die kontakte is gebrand. Bietjie skoongemaak en teruggesit.
Ek moes die natuurlik reeds met van die ander skakelaars ook doen. Dit raak makliker hoe meer jy dit doen.
Ek was bang dat ek die "clips" om die skakelaar oop te maak , sal afbreek.Ek het nou geleer en dit gaan makliker.
Lyk vir my dit is 'n probleem met IFS modelle, na die jare en km's moet daar seker darem IETS wees wat ingee.
Ek het navraag gedoen by OEM en die skakelaars is beskikbaar(ek dink R280) ,maar moet bestel word van vêr af.
Dankie vir hulp.
Lourens
Dankie vir hulp.
Lourens
- george
- Town: Velddrif
Hi Lourens.Hoe gaan dit?
Ek het toe sover gekom.Moet ek daai wit housing ook uithaal?
- J.C Avis
- Town: Otjiwarongo
- Real Name: Japie
George,het jy toe reggekom? Ek het myne vandag gedoen,altwee linker deure en regter agterdeur het plaatjies wat aanpak,skoon gemaak en werk weer. Ek het eers getoets of da krag is,toe weet ek dit is die switch. Die regter voordeur het skuif switches,lyk anders,net contact spray ingespuit.george wrote:Hi Lourens.Hoe gaan dit?
J.C Avis
- frik
- Town: Boksburg
- Vehicle: KZTE 3.0 4x4
- Real Name: Frik van Dyk
Guys I had the same problem .Its a very simple and common problem with the Hiluxes. I have put some pictures on the other 4x4 forum . What it basically is . Where your petrol/diesel pedal sits right above it you have to strip what ever you can .
There is a while relay box what ever they call it. All central locking and windows gets controlled via relays from that box "Unit" . What I find is the culprit is your A/C it makes condensate which drips onto this unit.Mine was rusted (Green Copper rust) I took it out clean it sparay Q 20 and walla all my problems gone. A typical thing that happens is you main lights come on by itself also that unit.
Good Luck
Good Luck
