WHAT MAKE OF BATTERY IS BEST FOR ENGEL FRIDGE ?
Korsmans
Town: Durbanville
Vehicle: HILUX DC2.2L 1994
Real Name: Allan
Post by Korsmans »
Greetings
Will have a dual battery system installed in the back of my Hilux to run the fridge
WHAT MAKE/TYPE of 105A battery should i buy or insist upon to be reliable....
Please help
Allan K
Johan Kriel
Town: Okahandja
Vehicle: 2.5 SC 4x4
Real Name: Johan kriel
Re: WHAT MAKE OF BATTERY IS BEST FOR ENGEL FRIDGE ?
Post by Johan Kriel »
The one with the longest guarantee. :D:
AGM batteries is maybe best fitted for such use, but high cycle also do good, but it also depend how you charge the battery.
Johan Kriel
Legend 50
The "medium cycle" Raylite 102ah "Leisure" battery has worked well for my fridge application. They are very reasonably priced by comparison to most others and if I'm not mistaken you get a 2 yr guarantee.
pietdevs
Town: Mosselbay
Vehicle: Toyota Land Cruiser Troopy
Post by pietdevs »
I use a 200Ah Lithium battery. It lasts for more than 10 days running 2 fridges. Spend the money and get yourself a Li battery, you will never regret it. It is good for at least 6000 cycles. I use it on a dual battery system in my bakkie with a National Luna intelligent solenoid charger backed up with a solar panel. It weighs a fraction of a lead acid battery as well. Remember that a lead acid battery's characteristics are very different with Voltage reducing during use in contrast to a Li battery where V stays constant during use.
niclemaitre
Town: Stellenbosch
Vehicle: 99 IFS DC 4x4
Real Name: Nic
Post by niclemaitre »
Lithium is great, HOWEVER, it is significantly more expensive upfront, but probably in terms of rands/cycle, slightly better value for money than Lead Acid/AGM/whatever. You also need to invest significantly more in your charging infrastructure (intelligent DC-DC chargers etc). I recently changed my old lead acid setup with a CTek D250S DC-DC and Solar MPPT and a Ctek AC-DC 10 amp to a Victron setup capable of charging lithium.
I needed a Victron Orion Smart 12/12 DC-DC, a Victron Smart 12/7 AC-DC, a Victron Smart Solar MPPT 100/20 and a Revov Second Life 100 Ah battery. All in, it probably cost around 20 k.
If you stay lead acid you can buy a solenoid and battery for less than 4k total.
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
RobYosh
Town: George
Vehicle: GD6
Real Name: Rob
Club VHF Licence: none
Post by RobYosh »
Do you think if i put a lithium battery in and run it off my alternator and also my solar panel with vectron mppt will be fine ?
niclemaitre
Town: Stellenbosch
Real Name: Nic
For lithium you will need some kind of DC-DC to make use of your alternator.
IFS '99 DC "Benny"
