31x10.5x15 se ander size asb??
- grobbepj
- Town: Alberton
- Vehicle: Hilux legend 35 4x4 3.0kzte D/C
Kan wen van die manne wat meer van tyres as ek weet vir my se wat is die alternatiewe grootte op 'n 31x10.5x15 band grootte. Is dit dieselfde as n 255x70x15? Ek kyk na ander tipe bande v my trokkie en hul kon my nie help in die 31 groottes en hul was self nie helemal seker of die twee groottes dieselfde is nie.
- WESKUSKLONG
- Town: St Helena bay
- Vehicle: Hilux KZTE with ARB front locker/Safari Snorkel / 33x12.5x15 tyres / Long range tank / Battery system / Thomas compressor/ 2Engel fridge freezers/Cruise Control.
- Real Name: Rudi
Re: 31x10.5x15 se ander size asb??
265 x 75 x 15
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
15 inch rim x 25.4 gives you rim size in mm
31 inch tyre x 25.4 gives you tyre size.
The 255 is the width of the tyre and the 70 stands for 70% of the with.
So add the 15 inch plus 70% of the width x2 and you will have tyre height.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- TOYODA
- Vehicle: '89 YN67R with Ford V6 3.0
- Real Name: Tiaan
31X10.5R15 = 265/75R15
255/70R15 het die selfde omtrek as die 30X9.5R15.
- grobbepj
- Town: Alberton
Dankie almal. Het geweet ek gaan vinnig n antwoord kry!!
- grobbepj
- Town: Alberton
Nou vir die ander probleem. Die enigste grootte waarin die bande kom waarna ek kyk is die volgende...
Hou ek verby of is die 265/70/15 amper dieselfde. En wat boet ek in??- Johan Kriel
- Town: Okahandja
- Vehicle: 2.5 SC 4x4
- Real Name: Johan kriel
2 x 265 x .75 + 15 x 25.4 = 778.5mm
2 x 255 x .7 + 15 x 25.4 = 738 mm
2 x 265 x .7 + 15 x 25.4 = 752mm
31 x 25.4 = 787.4 mm
dia of the tyre
dia of the tyre
Johan Kriel
Legend 50
Legend 50
- Thunder02
- Town: East Rand
- Real Name: Neil
And to make things really fun,through in mud terrains ,and those aggressive patterns mess up all the mathematics
www.4x4direct.co.za
www.4x4direct.co.za
- grobbepj
- Town: Alberton
Ja this is quite interesting. Now for the real silly question. Does the 3cm or so larger diameter makes a huge difference other than looks??Thunder02 wrote:And to make things really fun,through in mud terrains ,and those aggressive patterns mess up all the mathematics
There is a huge price difference and I just thought I finally have the thyre I like and can afford just to realise its the wrong size...
- Thunder02
- Town: East Rand
- Real Name: Neil
Well every little bit helps to get the diffs futher away from the ground.But like you said the bigger you go the more money to be spent,body lift and so forth.........
www.4x4direct.co.za
www.4x4direct.co.za
- antlo69
- Town: Pretoria North
- Vehicle: Toyota Hilux 3.0 D-4D, leveling kit, 17" with A/T BFg's, sadly stil some Tupperware, wish list growing by the day
- Real Name: Antonie
What brand of tyres are you going for?
"Must be a Toyota, must be a diesel and must run on BFG's"
- grobbepj
- Town: Alberton
Currently considering General Grabbers AT as I can get a real good price on them, but then have to choose between the 255/70/15 and 265/70/15. Since I realised that I cant get the right size in them I am reconsidering the Hankook dynapros but they will cost me the best part of a R1000 per tyre more....for only 1.5cm larger diameter tyres...???antlo69 wrote:What brand of tyres are you going for?
So back to being very confused.
- grobbepj
- Town: Alberton
Dankie Johan.Johan Kriel wrote:2 x 265 x .75 + 15 x 25.4 = 778.5mm
dia of the tyre
Net om seker te maak ek verstaan jou reg. as ek van die 31x10.5x15 na 265x70x15 gaan dan gaan my bakkie
787.4-752 ~3.5cm laer wees??
Die salesman het gepraat van net1.5cm maar somehow glo ek jou meer :-)
Dit raak n verskil.
- Toppie4x4
- Town: Centurion
- Real Name: Andre
Pieter ek sien Tiger wheel en tyre adverteer hulle Hankooks dynapro vir R1990 elk.
- Toppie4x4
- Town: Centurion
- Real Name: Andre
Dynapro ATM RF10
Tyre Details View Tyre Sizes 30/x9.50RR15
R1995.00 each
R1995.00 each
- grobbepj
- Town: Alberton
Ekt gesien Andre maar dit is net op die 30x9.5x15s...Toppie4x4 wrote:Pieter ek sien Tiger wheel en tyre adverteer hulle Hankooks dynapro vir R1990 elk.
Die 31s is so R2350 en ek kan grabbers kry vir R1400... Dit bly vir my groot verskil. Kan baie ander goed met daai xtra geldjie doen maar wil nie spuit wees op lang run nie..
Weet nou nue meer watter kant toe nie maar moet binnekort besluit. Of ek moet maar net by die Bfgs bly.
- Toppie4x4
- Town: Centurion
- Real Name: Andre
My Hankooks het nou 50,000km op en lyk nog baie goed, het meer as 8mm loopvlak oor, ek is baie tevrede, al nadeel is hulle raas teen lae spoed 60 km en minder.
- Toppie4x4
- Town: Centurion
- Real Name: Andre
30/x9.50RR15
All-terrain tyre for bakkis, vans, 4X4's and SUV's
Innovative tread & sidewall designed to enhance the style of your vehicle
Offers the best grip and acceleration under all road conditions
Zigzag Block Edges provide excellent traction in wet and dry conditions
Stone ejectors in the tread channels help prevent tyre damage and improve handling
Qualifies for the 80 000 km Hankook Tyre Mileage Warranty
- grobbepj
- Town: Alberton
Kan ook nie dink hulle raas minder as die Bfs nie...of mens moet sorg dat jy nooit onder 60 ry nie :-)Toppie4x4 wrote:My Hankooks het nou 50,000km op en lyk nog baie goed, het meer as 8mm loopvlak oor, ek is baie tevrede, al nadeel is hulle raas teen lae spoed 60 km en minder.
My kop en bank sake staan net nie mooi selfde kant toe op die stadium...
- Johan Kriel
- Town: Okahandja
grobbepj wrote: Dankie Johan.
Dit raak n verskil.
Pieter, ja en nee dit is die wiel se deursnit, die bakkie sal die helfte laer wees. Maar dis die teotiese berekening, daai ouens wat die moulds maak se maatbande is nie altyd heeltemal akkuraat nie of hulle kan nie lekker lees nie, so die fisise mates van elke maak en tyre verskil bietjie teenoor die teoretiese berekeninge. So as jy dit fisies meet of die mates van die vervaardiger kry kan dit dalk effens verkil.
Johan Kriel
Legend 50
Legend 50
- Genissie
- Town: Hartenbos
- Vehicle: LC 80, 4500
- Real Name: Andries
- Club VHF Licence: X254
jammer ek is bietjie laat, maar n goeie calculator
size calculator
http://www.kameeldoring.com/tyresize/index.php" onclick="window.open(this.href);return false;
http://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
http://tire-size-conversion.com/tire-size-chart/" onclick="window.open(this.href);return false;
size calculator
- grobbepj
- Town: Alberton
Dankie genissie...Genissie wrote:jammer ek is bietjie laat, maar n goeie calculator
size calculator
Dit help!!
- TOYODA
- Real Name: Tiaan
Jy kan selfs die een probeer:
https://www.1010tires.com/Tools/Tire-Size-Calculator" onclick="window.open(this.href);return false;
- grobbepj
- Town: Alberton
Dankie Toyoda. Dis scary dat die verskil tussen n 31/10.5/15 en n 265/70/15 beteken dat oor n 80 000km tydperk die 265 meer as 1.5miljoen meer revolusie maak as die 31... So die 31 moet net beter kms gee...
